Backup camera and reverse light stopped working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrlumens, Nov 13, 2019.
  1. Nov 13, 2019 at 5:54 AM
    Mrlumens
    Mrlumens [OP] New Member
    I installed some aftermarket tail lights on my 15' sr5 and tested them, they worked fine. After I got them all installed I went to test again and my back up camera won't turn on and my reverse lights won't turn on. Any ideas on the issue?
  2. Nov 13, 2019 at 6:14 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Check your fuses
    NewImprovedRon and 15whtrd like this.
  3. Nov 13, 2019 at 6:19 AM
    Mrlumens
    That was my first guess. Not sure which fuse would power both the back up camera and the tail light reverse lights. Any idea?
    And deeper, why would it pop in the first place?
  4. Nov 13, 2019 at 6:35 AM
    Mrlumens
    Thanks so much! I'll check them out. Fingers crossed it's just a fuse and that it won't pop again.
    NewImprovedRon likes this.
  5. Nov 13, 2019 at 6:47 AM
    Mrlumens
    Smart man. I should have done that. And will in the future. I'll find out within the next 2 hours.
  6. Nov 13, 2019 at 1:24 PM
    Mrlumens
    Ok so it was 24 that was blown the 7.5, fixed the back up cam!....but what happened before I changed it on my way to work was a check engine light and my in dash display says traction control off, pressing the button was no change.
  7. Nov 13, 2022 at 10:23 AM
    Evan Bernabe
    Evan Bernabe New Member
    Evan
    2017 Tundra
    Hey I have a problem that is the same one as yours. I already found the blown fuse that fixed my back up camera and reverse lights but the check engine light is on and the traction off is on. Have you fixed the problem yet?
  8. Nov 15, 2022 at 7:08 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Have either of you tried disconnecting the battery terminal to reset the electrical components since blowing the fuse?
  9. Sep 20, 2023 at 11:16 AM
    A.Llamas_YotaMama
    A.Llamas_YotaMama New Member
    Alex
    2005 Toyota Sequoia
    Hi guys, so I don’t have a tundra but I have a first GEN Sequoia and I heard they are very similar to the first GEN tundras. I have been experience a similar issue. Every time I go into reverse it pops. The gauge fuse and my reverse lights are also not working, I replace the fuse every time it pops, and it fixes the turn signals, the air conditioner, the speedometer, but it’s not fixing the actual reverse lights. I’ve been doing some digging, and I seen that it could be the neutral safety switch since I have an automatic transmission but I’m not sure what else it could be. … my aftermarket reverse back up camera is also not working.
