Back Up Home Generator Question
Discussion in 'Home Improvement' started by texasrho83, Sep 7, 2023.
  1. Sep 9, 2023 at 8:30 AM
    #61
    What has been the longest you have been without power?
    Our last bad wind storm some people in town were out for 7-9 days. Out in the county where I live, the longest has been 2 hours once in the past 5 years.
  2. Sep 9, 2023 at 8:32 AM
    #62
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Dang! All this time I never realized I was one of "those certain kind of people" because I have a Generac. Don't know whether to have hurt feelings or feel proud LOL.
    Gene_in_FL, GODZILLA and Mater like this.
  3. Sep 9, 2023 at 8:34 AM
    #63
    NewImprovedRon
    Ron
    NW Arkansas
    Right after we had it installed, we lost power for a full 24 hours. We never missed a beat powering our entire home including 2 AC units. We have also lost power a number of times because there is a lot of new construction going on around us and it seems that someone is always screwing up the utility power by cutting/digging.
    Fotnot and ColoradoTJ[QUOTED] like this.
  4. Sep 9, 2023 at 8:56 AM
    #64
    With the addition to our home and the hot tub it got me thinking about resizing a whole home generator again.
    Ouch.
  5. Sep 9, 2023 at 9:19 AM
    #65
    Ever consider a couple large 100 lb propane tanks? That would give you max power, fuel for a long time, and you could put the tanks on an RV tank switch when one runs out. The 100 lb tanks are 150.00.
  6. Sep 9, 2023 at 9:25 AM
    #66
    Check out Project Farm test on fuel stabilizers. I was a little shocked.
  7. Sep 9, 2023 at 10:19 AM
    #67
    blenton
    blenton New Member
    I know it’s a rookie question, but how reliable is natural gas in an extended power outage?
    We’ve never had NG until now so I’m used to dealing with propane tanks, but I’m more concerned about heating the house in the middle of the winter than running the AC in the summer (we have a basement that stays cool, and I’ve honestly never had AC until we moved a few years ago). Thinking about sizing a genset that will run off NG or LP; I have a buddy that works at the propane company and rental tanks are dirt cheap, but if NG is reliable might as well stick with that rather than get a conversion kit for the furnace and water heater in the event of a prolonged outage.
    Gene_in_FL and ColoradoTJ like this.
  8. Sep 9, 2023 at 10:40 AM
    #68
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I did. Hell I was even thinking to bury one big one. Wife is against the idea of having a tank in town.Don't know the code on that either.
  9. Sep 9, 2023 at 10:41 AM
    #69
    18" TRD Off Road Wheels
    They can't say "no" if you don't ask for permission. :evil:
  10. Sep 9, 2023 at 10:41 AM
    #70
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  11. Sep 9, 2023 at 10:43 AM
    #71
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've lived much of my life by that credo....I've realized that I've spent more money in the subsequent aftermath :laugh:
  12. Sep 9, 2023 at 10:47 AM
    #72
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    nothing personal
    it’s for those that want a turnkey solution
    there is better equipment out there, but generac flooded the market with Chinese grade material. So there is only one viable solution these days
    I have a 22kw generac. And a 12yr old brigs and Stratton 20kw
    the b&s has been near flawless. The generac has failed twice. Not the motor or genset. The janky Chinese electricals failed
    texasrho83[OP] likes this.
  13. Sep 9, 2023 at 10:53 AM
    #73
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll add- if I had my druthers, I’d use a brigs and Stratton. Or Koehler nat gas gen set
    and use a simple transfer case
    get a unit that can power all your shit. Forget about all that load shedding crap. That is what has failed me.
    use upc’s on all your important crap.
    ColoradoTJ likes this.
  14. Sep 9, 2023 at 11:21 AM
    #74
    100 lb tanks are not that big. You see them in RV parks all the time.
  15. Sep 9, 2023 at 11:23 AM
    #75
    I was looking at B&S units today. They are definitely not the cheapest option. In fact, more expensive than the Generac units. Not that the b&s should be cheaper..since these are quality units.
  16. Sep 9, 2023 at 11:26 AM
    #76
    Mostly has to do with this...
  17. Sep 9, 2023 at 11:31 AM
    #77
    NG is very reliable unless a whole region is out of power (like multi statewide power outages) due to pumping stations. In the last 22 years I have only seen this being an issue once at my work and almost had to shut the power plant off completely. We require 689-740 psig, so not your typical household pressure of .25 psi.
  18. Sep 9, 2023 at 11:36 AM
    #78
    Oh and you TX members that have whole house standby generators...good call. Your power grid is on level two emergency during peak times.
  19. Sep 9, 2023 at 12:08 PM
    #79
    blenton
    blenton New Member
    Thanks. That's good to know. I wasn't sure how widespread a power outage had to be for the NG system to suffer, but assumed it would need to be a very large region considering the basics of how the NG distribution system works.
    I've also been looking at Koehler and B&S gensets. 20KW ought to suit my needs just fine, even if I decided to kick the AC on. My house came set up with a 60 amp interlock kit at the panel for smaller generator use in a pinch, but I'm thinking a dedicated automatic NG/LP setup would be great.
  20. Sep 9, 2023 at 12:14 PM
    #80
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Do you use that during a power outage? :monocle:
    ColoradoTJ[QUOTED] and Mater like this.
  21. Sep 9, 2023 at 12:15 PM
    #81
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I know. My Dad uses a 200-250 gallon tank at his place and it ain't that big
  22. Sep 9, 2023 at 12:17 PM
    #82
    LMAO. I never use it. However, in the winter it can turn into a rather large chunk of ice. There goes 15k...
  23. Sep 9, 2023 at 12:24 PM
    #83
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well I think during the next outage, a pic of you in that thing with a glass of whiskey and a cee-gar would be appropriate
    Mater, NWPirate, e30cabrio and 2 others like this.
  24. Sep 9, 2023 at 12:28 PM
    #84
    You will never see me in a hot tub. They are nastinesses....
    e30cabrio likes this.
  25. Sep 9, 2023 at 12:35 PM
    #85
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah but if you own it it's just your nastinesses
  26. Sep 9, 2023 at 12:44 PM
    #86
    Are you trying to see @ColoradoTJ 's nastiness?
  27. Sep 9, 2023 at 12:54 PM
    #87
    Mike59, NWPirate, e30cabrio and 4 others like this.
  28. Sep 9, 2023 at 1:06 PM
    #88
    SD Surfer
    Bruce
    So Cal
    Well that took a turn.
  29. Sep 9, 2023 at 1:10 PM
    #89
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Our grid only gets short on electrons when the wind stops blowing, but that’s another story.
  30. Sep 9, 2023 at 1:18 PM
    #90
    Yep. You have 6200MW reserve and 12000 MW wind.
