AZ BS
Discussion in 'Arizona' started by Rextinkleton93, Jan 31, 2018.
  1. Jun 22, 2021 at 11:18 AM
    #1141
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Bob_Wiley and AT x AT[QUOTED] like this.
  2. Jun 22, 2021 at 11:31 AM
    #1142
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    How many miles on your truck now?
    I'm under 9,xxx miles now and don't expect to do a transmission fluid change for a hot minute (pun intended). When I do, I'm considering using AmSoil. Here's a post referring to it: https://www.tundras.com/threads/nervous-for-trans-fluid-change.89701/#post-2259860
    Looks like it's easy peasy steps here: https://www.tundras.com/threads/nervous-for-trans-fluid-change.89701/#post-2259805 and https://www.tundras.com/threads/where-is-the-transmission-fill-plug.90567
    I think it would be A LOT easier if you had access to a lift to get the truck off the ground.
    All said and done, you just need to make sure that the fluid levels are correct.
  3. Jun 22, 2021 at 11:35 AM
    #1143
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    127k here's the drippings from the hockeypuck warmer (cooler)?
    The job is easy, the hardest part is getting it to the right temp to test it's full & cleaning up the mess that will happen from the drain/removal of the pan/install of the filter.
    I did it 4x on my 2005 X5 from 30k to 120k no problems at all. I'm just a bit burnt from the 2k transmisison job.
  4. Jun 22, 2021 at 11:37 AM
    #1144
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Jun 22, 2021 at 12:45 PM
    #1145
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    That looks pretty close to what I get in my 2010 (thermostat NOT pinned open though). I watch the trans/coolant temps on my Bully Dog, which, I was told, monitors the pan temp, not the convertor temp.
    Example: Towing the boat (roughly 5k lbs) home from the lake the other weekend, ambient temp was 106. Trans was usually around 194-196 and would reach as far as 201. Coolant would stay right around 198/199. This is towing thru the hills at 60mph, tow/haul engaged, S4 selected and shifted to S5 in the flats.
  6. Jun 22, 2021 at 1:22 PM
    #1146
    e30cabrio
    Thanks, I think I'm fine and see no reason to worry I'll be under temp.
  7. Jun 22, 2021 at 1:23 PM
    #1147
    AT x AT
    Jimmy
    Mods, what mods?
    You get to a point in your life where it's just worth it to pay someone else to do the job. With that said, it sounds like you are at that point. I don't have any recommendations on where to do it, but if you get the itch to do it yourself, let me know. Two half-brains make a whole one. :rofl:
    WBW and e30cabrio[QUOTED] like this.
  8. Jun 22, 2021 at 1:26 PM
    #1148
    e30cabrio
    Thanks, I called Petes, the shop that did my r&r and that fixed the glass transmission in my 2001 Acura CLs in 2008. First they said they have too much business to do any maintenance for the foreseeable future, when I asked what they would charge they asked what I had (I started with that) they said they would not do it.
    That's scary.
  9. Jun 22, 2021 at 4:18 PM
    #1149
    AT x AT
    Jimmy
    Mods, what mods?
    Holy crap. At least they were honest that they didn't want to take your money and do a half assed job. Sounds like you have a tranny flush in the future. :p
  10. Jun 22, 2021 at 4:21 PM
    #1150
    e30cabrio
    The reason they are too busy is they do great work. It's just scary to think a place that only deals with transmissions don't want to take the liability. (my take)
    I work a few miles from Camelback Toyota, I'm going to see what they say. If I'm doing it I want to replace the filter also so there's that.
  11. Jun 22, 2021 at 7:10 PM
    #1151
    e30cabrio
    The Dude and AT x AT like this.
  12. Jun 23, 2021 at 7:06 AM
    #1152
    e30cabrio
    I give up, what is this????
    Azblue and WBW like this.
  13. Jun 23, 2021 at 7:20 AM
    #1153
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Yuma AZ, and military.
    AZ_BO likes this.
  14. Jun 23, 2021 at 7:36 AM
    #1154
    AT x AT
    Jimmy
    Mods, what mods?
  15. Jun 23, 2021 at 7:53 AM
    #1155
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    a god send?
    Azblue, e30cabrio[QUOTED] and WBW like this.
  16. Jun 23, 2021 at 8:10 AM
    #1156
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    If you're 4x4, wouldn't hurt to pick up a 12pt 32mm socket for front axles too ;)
    -JS
  17. Jun 23, 2021 at 8:32 AM
    #1157
    AT x AT
    Jimmy
    Mods, what mods?
    Hot damn. I learn something new everyday on this forum.
    Looks like a trip to Lowe's is in my future to ogle over the hand tools.
  18. Jun 23, 2021 at 8:42 AM
    #1158
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It figures the first day in a year that I need to get somewhere during rush hour it rains. Just dropped my truck off at Westcott Designs to get the front lift redone though :bananadance:
  19. Jun 23, 2021 at 9:29 AM
    #1159
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    After 113 days since I placed my order...the final piece of the suspension package is close!
    -JS
    Bob_Wiley, e30cabrio, AT x AT and 2 others like this.
  20. Jun 23, 2021 at 9:30 AM
    #1160
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Isn't that how life works though?
    -JS
  21. Jun 23, 2021 at 9:35 AM
    #1161
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  22. Jun 23, 2021 at 9:35 AM
    #1162
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Winning!
    e30cabrio likes this.
  23. Jun 23, 2021 at 10:11 AM
    #1163
    e30cabrio
    I have all those specialty sockets from my X5. Luckily BMW uses the same sizes.
    The reason I burned my arm is the 24mm is long so I had a hard time getting my 1/2 inch long socket wrench on it and was between the front driveshaft & cat.
    Saturday gonna be another fun day under the truck!
  24. Jun 23, 2021 at 10:22 AM
    #1164
    Taco-Blender
    AZ
    2010 DC 4x4
    It looks like you have a reverse leak issue with your pool. I'd call the pool company ASAP.
    We had a little bit in Tucson last night too. Just enough to float all the dust on the truck :mad:
  25. Jun 23, 2021 at 11:04 AM
    #1165
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    :rofl::rofl::rofl:
  26. Jun 23, 2021 at 1:12 PM
    #1166
    Azblue
    The Dirty T ( ^_^)_且
    Not fair, I didn't get a god damn drop at my house.
  27. Jun 23, 2021 at 1:35 PM
    #1167
    e30cabrio
    Still raining in Laveen. Of course, the filters for the pool came when it was pouring. So I waited to R&R the f00kers.
    Now it seems the damn brain for the pop up head cleaner is going out. Instead of two at a time opening, I have 4-6 which causes poor pressure. God, I hate that hole in the ground money goes to die!
    lol
  28. Jun 23, 2021 at 2:01 PM
    #1168
    AT x AT
    Jimmy
    Mods, what mods?
    When it rains, it pours!
  29. Jun 23, 2021 at 2:02 PM
    #1169
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I hit all of it driving from North Phoenix to Chandler. Hopefully it's helping with the fires up north.
    Azblue[QUOTED] likes this.
  30. Jun 23, 2021 at 3:01 PM
    #1170
    e30cabrio
    I like rain.
