AZ BS
Discussion in 'Arizona' started by Rextinkleton93, Jan 31, 2018.
  1. Mar 3, 2018 at 2:31 PM
    #391
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Ive got a stock PRO with the predator steps(which compromise the clearance a little bit) you think i'd make this through ok?
  2. Mar 3, 2018 at 10:59 PM
    #392
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    A local guy on the AZ Facebook page says you pull the ABS1 fuse and 4x4 still works. A trac and auto lsd and all that stops working obviously though since it’s dependent on the abs system. He says he pulled his months ago and still 4 wheels almost every weekend.
    I also despise abs in the dirt. I’ve been controlling brakes in the dirt for like 35 years and I hate when the truck decides to just stop slowing down.
    I plan to test this, and if it works, I’ll mount a switch in the cab to control a relay that will interrupt the abs fuse. When the truck turns off and back on, abs will be on for regular driving (safety), but you can flip this switch to immediately turn abs off. I should be able to flip the switch off and get atrac and auto lsd back too. I don’t know if that will require an ignition cycle though for the ecm to perform the abs system ready function.
    TRON and 831Tun like this.
  3. Mar 4, 2018 at 7:59 AM
    #393
    Rextinkleton93
    Rextinkleton93 [OP] New Member
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Keep me posted man. That shoulda like what I need!
    KevinK[QUOTED] likes this.
  4. Mar 4, 2018 at 4:12 PM
    #394
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I haven't done the whole loop in probably 4 years but at least 3/4 of the trail if not all of it can be done in 2 wheel drive. You need clearance but nothing crazy. We can find you some fun spots to test your pro.
    Sunnier likes this.
  5. Mar 4, 2018 at 5:14 PM
    #395
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Anyone else from Tucson besides @Help and I going?
    Brian0414 likes this.
  6. Mar 4, 2018 at 6:40 PM
    #396
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    We did a quick prerun today with a few trucks.
    Mine is "stock" height in the rear (clapped out Icon enhancement leaf pack...literally I sit exactly stock with my leaf pack and larger tires.....)and I dragged my hitch in one area, otherwise no issues.
    Need a good, aggressive tire - stock or the like might get chewed up a bit with possibilities of catching a flat. Few sharp rocks here and there along the way, little rocky (no significant bolders) for the most part not bad.
    **I'm going to ask that this run be limited to 14 additional people only** I would like to run 3 groups of 5 with about 10minutes between groups.
    Certain sections are single track with limited space for maneuvering around oncoming traffic. Hence wanting to keep it spaced a little in smaller groups.
    Please let me know if your interested in leading a geoup, trail is easy to navigate.
    I dont know how people do it, scheduling events like this.....but please join the AZTG FB page and get into the group. I started the event there and the event from here on out will be updated on that page for updated meeting time/group departure times and stuff of that nature .
    Thanks
    blue16 and Sunnier like this.
  7. Mar 4, 2018 at 7:39 PM
    #397
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Anyone running w/o their hitch? That thing gets in the way. But MCM Matt says we need some sort of stiffener back there.
  8. Mar 4, 2018 at 8:04 PM
    #398
    n2deep
    n2deep Pavement Princess
    Yeah you need to brace the rear frame and probably box the frame. Otherwise you will find out the flex is a bit much if you push the truck. I took mine off and added a high clearance bumper but not enough bracing.
    Sunnier likes this.
  9. Mar 4, 2018 at 8:11 PM
    #399
    Sunnier
    Sunny
    San Diego, CA
    Did he explain why?
  10. Mar 4, 2018 at 8:48 PM
    #400
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Got my ADS stuffs on just in time to test em out :dancingbacon::dancingbacon::dancingbacon::dancingbacon:
  11. Mar 4, 2018 at 9:33 PM
    #401
    n2deep
    The hitch ties the frame together at the end of the flexy C channel frame with a beefy piece of steel.
    Here is a video of the bed flex. The tiregate probably didn't help since a 100lb tire was sitting on it.
  12. Mar 6, 2018 at 7:03 AM
    #402
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    @boardude I was thinking about it. Never been before.
    boardude[QUOTED] likes this.
  13. Mar 6, 2018 at 9:51 AM
    #403
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks like @14burrito is capping the amount of trucks so you guys should claim your spots on the AZTG recent event post
    Help[QUOTED] likes this.
  14. Mar 11, 2018 at 3:10 AM
    #404
    zackbremer
    zackbremer New Member
    Da Z
  15. Mar 11, 2018 at 3:11 AM
    #405
    zackbremer
    Da Z
    guna go up sat morning to CK and spend the night, cabin rentals are cheap and so are the drinks
  16. Mar 11, 2018 at 5:42 PM
    #406
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Looks like it hit the cap in just a few minutes Lol maybe I will be quicker next time so I can make the list
  17. Mar 13, 2018 at 5:24 PM
    #407
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks like there's two more spots.. I think he's only going off people that pm him or post their confirmation
  18. Mar 13, 2018 at 7:29 PM
    #408
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Well heck I am in
    boardude likes this.
  19. Mar 13, 2018 at 11:40 PM
    #409
    KevinK
    Tundras to Sedona
    Tundras to Sedona
    Location is confirmed!
    (34.8995578,-111.6526972)
    Top of Schnebly Hill Rd
    https://goo.gl/maps/MxJ79MxANgq
    We’re working on the registration page where you can preorder shirts and raffle tickets.
    blue16 likes this.
  20. Mar 14, 2018 at 9:27 AM
    #410
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Fixing my coilover, haha.
    blue16 and KevinK like this.
  21. Mar 14, 2018 at 10:23 AM
    #411
    KevinK
    Tundras to Sedona
    What happened to it?
  22. Mar 14, 2018 at 10:24 AM
    #412
    d0zer
    2017 MGM Platinum
    Filling it back up with oil :D
  23. Mar 14, 2018 at 10:36 AM
    #413
    KevinK
    Tundras to Sedona
    OH! Hahahah!
    Someday I swear I'm going to be able to keep people's names straight. But today is not that day. :rofl::anonymous:
    d0zer[QUOTED] likes this.
  24. Mar 17, 2018 at 2:55 PM
    #414
    KevinK
    Tundras to Sedona
    Registration is live!
    This is free to attend, but registering helps us keep our permits right and plan the trail runs. You can also pre-purchase your shirts and raffle tickets.
    TUNDRAS TO SEDONA - Home
  25. Mar 27, 2018 at 4:44 PM
    #415
    Sunnier
    Sunny
    San Diego, CA
    Howdy, Neighbors!
    I'll be headed out soon to do a family road trip (mostly pavement and "tourist friendly" dirt roads and nights in hotels). I'm hoping for some up to date info on road conditions with regards to weather and construction.
    Specifically, is the 64 open and easy traveling this time of year? Thinking of going from the S. Rim of the Grand Canyon East on 64, north on 89 to 160 up into Monument Valley. Also want to know anything I need to know about the 191, the 264, and best routes in and out of Chaco Culture National Heritage Park. We've got our route set with regards to lodging, but figured I should ask you local experts for updated travel info, cautionary tales....
    I'll sure appreciate any advice you throw my way. Thanks, Guys!
    @KevinK @boardude can you help me by tagging anyone you know lives up that way...?
  26. Apr 11, 2018 at 9:45 AM
    #416
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Who all is planning on attending overland expo west in May? Anyone start a thread over here to get a group campsite figured out?
    @TRON @PLC721 @blue16 @KevinK
    TRON, KevinK and blue16 like this.
  27. Apr 11, 2018 at 9:45 AM
    #417
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    I havent thought about it much lol but I might be down, last year was alright lol
    Rextinkleton93[OP] likes this.
  28. Apr 11, 2018 at 9:05 PM
    #418
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I need to check see if on call that weekend
  29. Apr 11, 2018 at 10:44 PM
    #419
    KevinK
    Tundras to Sedona
    Hey sorry I just saw this. Did you take your trip already?
  30. Apr 11, 2018 at 10:48 PM
    #420
    KevinK
    Tundras to Sedona
