AZ BS
Discussion in 'Arizona' started by Rextinkleton93, Jan 31, 2018.
  1. Aug 1, 2023 at 6:58 PM
    #3271
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I can & I have an ARB compressor under the hood so not a problem, thanks.
  2. Aug 1, 2023 at 7:01 PM
    #3272
    e30cabrio
    I do, I'll get a reading, thanks
  3. Aug 3, 2023 at 6:17 AM
    #3273
    e30cabrio
    My pyrometer was awol, a new one came late last night, I just measured the surface of the spare & resonator not running in the garage, both are 101. I need to go out in a few hours & will take readings after I drive a bit.
  4. Aug 3, 2023 at 9:05 AM
    #3274
    e30cabrio
    Short 2 mile trip, Current ambient is 99. Numbers are as follows. Resonator is 250, spare closest to the resonator is 125, tires I was driving on are 123-130. thinking I'm ok.
  5. Aug 6, 2023 at 9:45 PM
    #3275
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  6. Sep 21, 2023 at 10:09 AM
    #3276
    AZBoatHauler
    So.Arizona
  7. Sep 21, 2023 at 10:12 AM
    #3277
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The I96 is a spring under leaf pack so you'll need a SUA kit. Depending on your load weight etc you may want to up to the HD version. I have the normal i96 and it's fine until I load all the camping gear in but that's not very often.
  8. Sep 21, 2023 at 10:19 AM
    #3278
    AZBoatHauler
    So.Arizona
    I was worried about carrier bearing and brake lines if I step to the 2” lift HD pack -
    With the shackle that would be just over 3.5”. It looks like the only leaf pack that doesn’t go under the axle tube (I think) says it’s a no go for crew max trucks… :notsure:
    https://deaverspring.com/product/tu...eaf-spring-2-inch-lift-rear-shackle-required/
  9. Sep 21, 2023 at 10:24 AM
    #3279
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I think you won't need the shackles but I could be wrong. Deaver also has custom packs. How much weight you got back there? We've got the deaver pack off the old mans rig that's spring over. But might be a little heavy since designed for gear in the back.
    Tripleconpanna likes this.
  10. Sep 21, 2023 at 10:27 AM
    #3280
    AZBoatHauler
    So.Arizona
    My rig is heavy AF but not a ton in back. Daily driving it’s about 6800-6900lbs. Loaded for a weekend or towing it’s probably in the 7,500-7,700 range.
    reywcms[QUOTED] likes this.
  11. Sep 21, 2023 at 10:30 AM
    #3281
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    His leaf pack would work for ya.
  12. Sep 21, 2023 at 10:30 AM
    #3282
    AZBoatHauler
    So.Arizona
    Let me know what we need to do - that’d be sweet.
  13. Sep 21, 2023 at 11:15 AM
    #3283
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    k37s from deaver aren't rated for the weight over the rear axle with the extra mass of the cab and more rearward, especially loaded. You're in u748 territory. this is the route that I went because of the extra 300+ish pounds between chase rack and 2 37s which at this point basically live in the back of the truck.
    the leafs are longer overall and absolutely require longer shackles to support. I believe the accepted consensus is the TC/SDHQ is the route to go with it, but I disagree and the longer length of the camburg's is necessary to support the increased length of the pack, eyelet to eyelet of camburg is 6" on center.
    for carrier bearing drop...Ekstrom has spacers for 3-4" that will work well.
    I implore that you look into longer shocks that support the extra droop travel you will get:
    @AccuTune Offroad custom length https://accutuneoffroad.com/product...r-2-5-series-remote-reservoir-1-5-3-lift-dsc/ rear shocks.
    IVD RxT
    Shock relocation (camburg or T/C) with 12 inch stroke shock.
    Other Items:
    Plan accordingly for bump stops and/or extensions to minimize leaf setting induced by negative arch at bump.
    extended rear brake lines are non-negotiable if you are using anything other than a direct OE length shock.
    Limit straps are highly recommended.
    Also look into the SDHQ trac bars for noticeable performance increase and to help prevent premature leaf setting from axle wrap...
    https://www.tundras.com/threads/bigghertz-dztlimo.101679/#post-2604985
  14. Sep 21, 2023 at 11:48 AM
    #3284
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    U748, totally forgot about those great pack.
    AZBoatHauler likes this.
  15. Sep 21, 2023 at 11:56 AM
    #3285
    Vizsla
    Vizsla New Member
    Been disappointed in one way(or more) with every mail order leaf spring I’ve owned. Might be too far for you, but be better to have exactly the spring pack you want made here in Phoenix, and then have the ability to service/make changes?
    http://www.valleyspringservice.com/index.php?main_page=index
  16. Sep 21, 2023 at 12:09 PM
    #3286
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    That was my plan at some point, but just decided to give the deavers a shot. Leafs are a maintenance/consumable item in my opinion, so when that time comes I'll revisit it...or even better full cage and back half with links.... :rofl::der::rofl:
    reywcms likes this.
  17. Sep 21, 2023 at 12:14 PM
    #3287
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Valley Spring made the replacement rear leaf springs for my son's 1960 Oldsmobile almost 20 years ago. They allowed me to watch the whole process. It was cool!
    Highly recommend them for any vehicle or setup.
  18. Oct 6, 2023 at 10:34 AM
    #3288
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
  19. Oct 6, 2023 at 7:43 PM
    #3289
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    That sounds like the intro to The A-Team, except with chihuahuas
  20. Oct 6, 2023 at 10:02 PM
    #3290
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    I think my dogs are too lazy to join a crew...
    DJenerated[QUOTED] likes this.
  21. Oct 9, 2023 at 4:34 PM
    #3291
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I might have some extra firewood from our cottonwoods that got cleaned up over the weekend. Anyone want to come by and grab some?
    AT x AT, coTony, reywcms and 4 others like this.
  22. Oct 13, 2023 at 9:34 AM
    #3292
    coTony
    Tony
    Montrose, CO
    Man I am freaking out... my son went in for knee surgery and when they took the tube out he had a bad episode that made his lungs fill with blood and fluid. He is in ICU with Doctors everywhere in his room and he has a catheter and heart monitors. He is coughing up blood and fluid.
    He is a Marine that chased Bin Laden for years, came home and is now a Deputy Sherriff and works at the Prison for a second job. Nothing but good and serving the public all his life now fighting in the hospital over a knee surgery. This is just not right. Come on Jason, you got this!!!
  23. Oct 13, 2023 at 9:37 AM
    #3293
    BeauDacious
    Beau
    14 DC 4x
    Prayers and best wishes for the fellow Jarhead.
  24. Oct 13, 2023 at 9:56 AM
    #3294
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sending prayers your way!
  25. Oct 13, 2023 at 9:56 AM
    #3295
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I know he's going to pull through bud. I hope it's sooner then later. Wishing you guys the best, let me know if I can help with anything.
    coTony[QUOTED] likes this.
  26. Oct 13, 2023 at 9:58 AM
    #3296
    TaquitoBandito
    Joel (AKA Bif)
    He’s a Marine. He’ll make it through. Sending good thoughts your way in the hopes for a speedy recovery.
  27. Oct 13, 2023 at 10:18 AM
    #3297
    Prayers sent.
  28. Oct 13, 2023 at 10:24 AM
    #3298
    WBW
    WBW Resident lurker
    Bruce
    Prayers sent for your son and the rest of your family, including you! Scary situation for certain. Please keep up posted. I'm close by if you need anything.
  29. Oct 13, 2023 at 10:50 AM
    #3299
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Thinking of your son and your family, Tony. I’m right down the road if there’s anything I can do to help.
  30. Oct 13, 2023 at 10:51 AM
    #3300
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Sending the best wishes to your family
    coTony and Tripleconpanna like this.
