Axle Popping Out
Discussion in '2nd Gen Tundras (2007-2013)' started by paulk, Feb 3, 2021.
  1. Feb 3, 2021 at 5:09 PM
    Who did the "professional install?"
  2. Feb 3, 2021 at 5:09 PM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    I believe the RC non-cut lift was a 4” drop bracket for both the 4” lift and 6” lift (stretched). It looks like you have too much lift. I’d buy the 6” RCD Bilstein 5100’s and ditch all the spacers. I used the 5100’s on my last truck with the BDS 7”.
    Here’s the part number, the 5100’s have two clips. One for 4” lift and one for 6” lift.
    F4-BE5-E980-T0
  3. Feb 3, 2021 at 5:13 PM
    paulk
    paulk [OP] New Member
    Paul
    Toyota Tundra Crew Max 2012, Lifted on 36" STT's
    Rack, Lift
  4. Feb 3, 2021 at 5:15 PM
    paulk
    Paul
    Rack, Lift
    @Black Wolf If anything went wrongly here im pretty sure it was my doing. I blew out my front coliovers and replaced them with what i thought was needed with the hope it would be better. I have a feeling the shocks are the problem and those i put in with a friend who has a garage with a 4post lift.
    Black Wolf likes this.
  5. Feb 3, 2021 at 5:16 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I don't know anything about the "eibachs" but from your original pictures it would appear to me that you would have to remove the Toytec preload spacer and then lower the rear end maybe an inch and you would be good to go with an inprovement in your cv angles..
    Hbjeff and Black Wolf like this.
  6. Feb 3, 2021 at 5:18 PM
    I get you, things happen. I like @jeremyd 's advice.
    jeremyd likes this.
  7. Feb 3, 2021 at 5:35 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Yea I'd try dropping the spring perch the the very bottom notch, should lower the lift by an inch or so. If the angles are still too extreme can also just try swapping that top spacer for a shorter one if possible.
    Hbjeff likes this.
  8. Feb 3, 2021 at 6:33 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I would put the smaller spacer on top of the eibachs and remove the big spacer. That lift was designed for 4-6" lift. I think you're around 8" and thats why the CVs are popping out. You need to find a combination of spacer/strut that equals around 4-6" total.
  9. Feb 4, 2021 at 2:55 AM
    paulk
    Paul
    Rack, Lift
    thanks everyone. really appreciate your help here. Ill let you know what i end up doing. ive got to hobble back to the mechanics shop this morning...
  10. Feb 4, 2021 at 6:51 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Good luck. I would just lower those eibachs to their lowest level and see how it goes
  11. Feb 4, 2021 at 7:30 AM
    Vizsla
    Vizsla 2 = 2.5
    Lowering the eibachs alone won’t be much help, still going to have same amount of droop travel.
    Hbjeff likes this.
  12. Feb 5, 2021 at 6:23 AM
    paulk
    Paul
    Rack, Lift
    Well, my mechanic got me the new axel and it is being installed as we speak.. Took a look last night to see how things were going and it seems the passenger side was done and the drivers side is being worked on. He did lower the Eibachs and as I dont have any replacement spacers, we will have to see how it goes. Im guessing the next step after that will be to get either a 2.5" or 3" spacer (i saw rough country has one for not too much $$$) which he said we could do later. I do plan to get an ARB font bumper sometime this summer with a winch and i assume the extra weight will help with bringing the nose down a bit more. I am not entirely sure what is meant by "droop travel" but ill gladly take some additional pictures to see if the axels are still too extreme on angle.
    I really want to also say thank you. You guys have been really quite helpful in this whole process... I love my tundra and want to understand better its mechanics as I do more and more off-roading. My ultimate goal for this truck is to get it to be a perfect overland vehicle with a nice off-road camping trailer in tow and basically use it for weekend getaway adventures. My truck has really low mileage for its year (2012 @ less than 80k miles) and i feel like its a good platform for this purpose. Anyhow, my love affair with this truck is not important... my appreciation for you all helping me is. So yea, thanks... a lot.
    Adam10532 and jeremyd like this.
