Axle nut torque and wtf is up with these wheel bearings?
Discussion in '2nd Gen Tundras (2007-2013)' started by Rob371, Aug 25, 2018.
  1. Aug 25, 2018 at 1:44 PM
    Rob371
    Rob371 [OP] New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    Had I known what a pain in the ass it was I would have taken time to photo all the steps and post them here. This was on my 2007 tundra.
    Just swapped out right front wheel bearing. Apparently nobody offers this as a hub assembly like 99% of the rest of the world does. And when you buy the bearing assembly the parts guy doesn't mention you should also buy the seal that goes up against the wheel flange because you'll probably destroy it during disassembly. Spent half the day figuring out what to use to press it apart. Can't fit it in the press, can't fit bearing splitter around it, can't remove the screws that hold hub assemblyKIMG2107.jpg to the steering knuckle because they hit the wheel flange. After trying several pullers I used the one in the photo successfully. When pulling it apart only the outer bearing on the spindle comes off. At this point I decided to cut the inner bearing off the spindle because I didn't have the seal and didn't want to wait until Monday to find out I'd have to order it for Tuesday. If I had the replacement seal then a bearing splitter would have been much easier.
    So now I am ready to put it back on the truck and from what I've seen on threads and other forums is Axle Nut Torque is 249 ft lbs. Of course out of five torque wrenches I own the biggest one I have goes up to 200 ft lbs. Anybody else got that spec as 249?
  2. Aug 25, 2018 at 1:55 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    That's accurate.
    You can rent a 250lb torque wrench from auto zone or oriellys
    ColoradoTJ likes this.
  3. Aug 25, 2018 at 2:18 PM
    Rob371
    Rob
    2007 Tundra Crewmax
    Some images of the assembly. The old bearing assembly on left minus the bearings I didn't want to dig from trash. You can see the screws hit the wheel flange so they are captive until pressed apart. The seal I referred to is indicated by pencil in 2110 photo. I can mock up the puller assembly tomorrow and snap a photo. I'm bagging it for today.
    Darkness, Trd307, ColoradoTJ and 2 others like this.
  4. Aug 25, 2018 at 2:22 PM
    Rob371
    Rob
    2007 Tundra Crewmax
    Thanks. Hadn't thought of that. One of the guys at work has one I can borrow but he wasn't around today. I'll snap a pic. It's a beast of a torque wrench. Things gotta be about four feet long. I think it's a 1 inch drive.
  5. Aug 25, 2018 at 2:51 PM
    Rob371
    Rob
    2007 Tundra Crewmax
    Not quite four feet.:benchpress:
  6. Aug 25, 2018 at 8:55 PM
    Twinky
    07 double cab work horse
    250'lbs of torque... That would approximately be 5ft cheater on a 3/4 breaker bar with socket seated on axle nut resting on a jack stand. Me bouncing on the far end of cheater bar about 3 - 3.5 times.
    So they seriously dont sell the hub assembly with a bearing already pressed?
    Thats crazy.
    Darkness likes this.
  7. Aug 26, 2018 at 10:42 AM
    Rob371
    Rob
    2007 Tundra Crewmax
    I tried a couple different vendors. Both had the same story. I searched online also. Several manufacturers to choose from but not as an assembly. I opted for the Timken.
    Here's a photo of the setup I used to split it.
    equin likes this.
  8. Aug 28, 2018 at 1:57 PM
    Rob371
    Rob
    2007 Tundra Crewmax
    Mother of torque wrenches. Crappy last few days. Broken fasteners, broken brake line, threads rounded off and rethreaded. Wheel bearing growling noise is gone but high pitched whirring noise still present. It's definitely coming from the front right but not sure what the source is. I guess I'll turn up the radio and run it until something fails. Headed to Tennessee next month. 2,000 mile round trip towing a 24 foot enclosed trailer. Unloaded on the way down, overloaded on the way back.
    dcsleeper408 likes this.
  9. Aug 28, 2018 at 3:12 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Thank you for sharing this knowledge and I appreciate your determination!!!
    Rob371[OP] likes this.
  10. Aug 29, 2018 at 7:50 AM
    stealth09
    stealth09 New Member
    Canada
  11. Aug 29, 2018 at 10:53 AM
    Rob371
    Rob
    2007 Tundra Crewmax
    Good to know. I checked with three local vendors. They all offered the same version, just different brands and different quality of different brands. I purchase a lot of parts so I get pretty good discounts locally. I'll be ringing some bells on this. Either way, the additional expense would be worth avoiding the aggravation. It's the difference between an hour job and a half a day job.
    831Tun likes this.
  12. Aug 29, 2018 at 11:02 AM
    stealth09
    Canada
    Ya I looked all over the place and I believe they just recently started offering this.
    Now the pain in the ass is the rears, which I haven't done yet. I have the parts, just not the proper tools to press out/in the bearings...
  13. Aug 30, 2018 at 3:29 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  14. Aug 30, 2018 at 3:43 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I installed a set of preassembled hubs about 8 months ago from I think Rockauto, I think I cheaped out (had a lot of things I was fixing at the time) but they’ve held up to everything so far. I ordered from the Marion guy that @computeruser6 posted a link to for my wife’s FJ, He basically takes a cheap hub and a good quality bearing to make affordable assemblies, he’s just very slow.
  15. Oct 30, 2018 at 7:43 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    So this still has to be pressed in???
  16. Oct 30, 2018 at 7:51 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Yes.
    Old hub needs to be split from the old bearing.
    If you can return, get this one. Preassembled. Makes life much easier if you aren't familiar with pressing.
    I once pressed the hub and bearing together.. forgot the damn bolts in between. :facepalm:
    831Tun and joonbug like this.
  17. Oct 30, 2018 at 7:54 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    so mad. I hear this womb womb womb and honestly people are saying I'm crazy its tires re worn out. Which is true. But it does get a little louder when I turn the direction of the sound. HELP ME LOL
    dcsleeper408[QUOTED] likes this.
  18. Oct 30, 2018 at 7:54 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I can press it but I figured this would be easier than the bearing itself that's why I got it
  19. Oct 30, 2018 at 7:56 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    you can try moving that tire to another corner and see if the sound moves. When you get it up on the jack stands check if there is any play with the wheel on. Push Left/right and Top/bottom.
  20. Oct 30, 2018 at 7:59 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I did that. But I only moved front tires. Didnt rotate front to back. And there is absolutely no play no joke!!!
  21. Oct 30, 2018 at 8:03 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Give front to back a try. One side at a time and see if that makes a difference.
  22. Oct 30, 2018 at 8:06 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I will NOW lol I'll be back tomorrow for the results!
  23. Oct 30, 2018 at 8:07 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    hope its just the tires! good luck.
  24. Oct 31, 2018 at 8:13 AM
    Rob371
    Rob
    2007 Tundra Crewmax
    The real pain is pressing the old spindle out. Getting it jigged up in the press was a bitch. In hindsight, leaving the assembly on truck and using a ten pound slide hammer with hub flange adapter would probably be easier but it took a lot of press to get it moving.KIMG2110.jpg Make sure to get the inner seal as indicated in my previous photo. You will likely damage it during removal.
    Trd307, dcsleeper408 and Watt maker like this.
  25. Oct 31, 2018 at 8:16 AM
    Bmxrider1331
    Brendan
    NEW JERSEY
    Or get the whole assembly like stated above?
    15whtrd likes this.
  26. Oct 31, 2018 at 8:21 AM
    Rob371
    Rob
    2007 Tundra Crewmax
    Yeah, definitely do that. The difference is 90 to 120 minutes to replace as an assembly or all freaking day screwing around with pullers, slide hammers and a press.
    249 pound feet torque on the axle nut.
    dcsleeper408, Watt maker and 15whtrd like this.
  27. Oct 31, 2018 at 10:52 AM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    They’ve been selling the whole assembly for years. There’s actually a few different companies that make them. Sorry you had to go through all that lol.
  28. Oct 31, 2018 at 10:53 AM
    LEKS
    Makaha
  29. Oct 31, 2018 at 11:02 AM
    stealth09
    Canada
    I just wish there was an easy way to do the rears... I am going to take my axle out and get a shop to press out/in the bearings.
  30. Nov 1, 2018 at 5:27 AM
    Rob371
    Rob
    2007 Tundra Crewmax
    Yeah, I know that now. Two parts suppliers I normally go to both had same option, without spindle, available from three different manufacturers. After learning they are available I went back and told them. Going into it I didn't think it was a big deal until I realized I didn't have a way to hold it in the press. Since the screws are captive you can't get a bearing splitter to fit in there.
