Auxiliary Backup Lights
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Apr 13, 2020.
  1. Nov 19, 2021 at 3:34 PM
    Here is the Vleds license plate light. Register an account and use code New15 and you will get 15% off of your order or wait a few more days and they should have a BF sale which is either 15 or 20%....I can't remember which one that it is.
    https://www.vleds.com/shop-products/lp-series.html
  2. Nov 19, 2021 at 3:43 PM
    My Rigids came with a switch like that.
    Lil Steve likes this.
  3. Nov 19, 2021 at 4:33 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So your works with the reverse lights and also a switch?
  4. Nov 19, 2021 at 5:49 PM
    Yes......designed that way by Rigid. They are the SR-M Pro with diffused lenses. Expensive but awesome. I think I got them from AutoAnything.
  5. Nov 19, 2021 at 10:48 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if you want backup lights tied to reverse with a switch.. just wire to the reverse signal and a switch to interrupt the signal..
  6. Nov 20, 2021 at 4:34 AM
    Yep...I believe that is how the Rigid harness is set up. I remember tapping the reverse at the taillight.
  7. Nov 20, 2021 at 4:49 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I want to be able to turn on the lights even if I'm not in reverse and also turn on when in reverse.
  8. Nov 20, 2021 at 4:55 AM
    That is what he is referring to.....an On/Off/Auto scenario.
  9. Nov 20, 2021 at 5:50 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Oh got it like a 3 way switch, I wanted to use like a normal on/off switch as I would use the cargo button or a aux gang panel.
  10. Nov 20, 2021 at 5:56 AM
    Cthulhu
    I used the same lights as @Lil Steve; they come with a template. Yes it's scary cutting into the bumper, and you need to be very careful when cutting around the backup sensor wiring, but worth it. They throw out a ton of light, and they can be tapped into your reverse light circuit without tripping the fuse.
    JDM FTW[QUOTED] likes this.
  11. Nov 20, 2021 at 5:59 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    the on/auto/off senario would be a challenge indeed best *easiest* bet is put *whatever you* consider the best and brightest bulb in your rear assy and then mount *whatever you* consider the best cube aftermarket light *wherever you* consider the best location and tie it into your cargo light for a quick push when needed
    there are other ways but may be out of your comfort zone
  12. Nov 20, 2021 at 7:43 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    That is exactly what I was thinking just didn't know if anyone did it before.
    NewImprovedRon likes this.
  13. Nov 20, 2021 at 7:46 AM
    Punk1974
    J.P.
    thank you to whoever showed me hand mans page where i snapped a pic of those hir bulbs
    Gunship Guy and des2mtn like this.
  14. Nov 20, 2021 at 8:54 AM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
  15. Nov 27, 2021 at 6:33 AM
    JDM FTW
    JDM FTW New Member
    VA
    2021 AG Limited TRDOR
    Punk1974[QUOTED] likes this.
  16. Nov 27, 2021 at 7:39 AM
    Punk1974
    J.P.
    the originator of thie hir mod is the crashnburns taco guy that a memeBer sojorner?? here posted up about rev bulbs. i cant find his threqd but you might search it here he references alot to crashesnburns link you posted.
    i’m installing some 9005 to 9011hir upgrade bulbs in some hi beams in a car soon based on some reading of a little tab removal. hir burns hotter on the wire using the same wattage due to reflecting coating without bad effects. read amazom reviews of the philips bulbs for headlights.
  17. Nov 29, 2021 at 1:42 PM
    skywalker474
    skywalker474 New Member
    san diego
    06 DC 4x4 trd
    Nilight lights from Amazon and a split harness.
    Waterjet some rubber gaskets for the pod lights. I used blue tape to set level and easy to write on when cutting the bumper pockets.
    Covered the entire harness with corrugated sleeve for a factory clean look.
    Ps, i drag hitch enough on mild trails, ide never run em hanging under the bumper imo, unless ya never go offroad
  18. Nov 29, 2021 at 6:21 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Any pictures in dark?
  19. Dec 11, 2021 at 4:28 AM
    #49
    JDM FTW
    JDM FTW New Member
    VA
    This just popped up on my feed in Facebook. Anyone using this?
  20. Dec 11, 2021 at 5:00 AM
    #50
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I wouldn't want to use that if you're worried about departure angles or offroad at all (which obviously not everyone is/ does). Super easy to drag the hitch offroad on a first gen, ask me how I know.
    FrenchToasty likes this.
  21. Dec 11, 2021 at 6:23 AM
    #51
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    someone should try, I was thinking the same. Then I realized the rear of the housing may hit the bumper and point the light at the ground.
    des2mtn likes this.
  22. Dec 11, 2021 at 6:29 AM
    #52
    10 blue trucks
    04 4WD RCLB
    It would just take a maybe 4 inch extender between the light mounting stud back to the clamp hole. Overall not worth it IMO. I want to cut holes in shit.
  23. Dec 11, 2021 at 7:21 AM
    #53
    des2mtn
    Shady Grove
    Tonto cover
    I can also see trailer chains getting banged against the lights.
    Punk1974 and NewImprovedRon like this.
  24. Dec 13, 2021 at 11:27 PM
    #54
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Lil Steve and Tundra2 like this.
  25. Dec 14, 2021 at 5:10 AM
    #55
    I'm not gonna say what this looks like because it'll be obvious to some, if not many.
    But I will say, I'm pretty sure I know the inspiration....
    alb1k[QUOTED] likes this.
  26. Dec 14, 2021 at 8:25 PM
    #56
    alb1k
    Left Coast
    It's good
    LOL, I can't see it. Does look like my next light though :)
  27. Dec 15, 2021 at 8:06 AM
    #57
    If you don't recognize what this is or what it looks like installed, let's just say ... it's not an earring, but it does install in a similar spot to a receiver on the back of our trucks. And I really can't unsee this every time I look at the pic a couple posts up. Because it's hilariously identical.
    txagg likes this.
  28. Dec 15, 2021 at 8:53 AM
    #58
    alb1k
    Left Coast
    It's good
    Lol, but what are the lumens?
  29. Dec 15, 2021 at 9:41 AM
    #59
    Not sure on lumen count. Based on what I've seen, it tends to make a lot of lights go on for some people, but I'm sure I'd be seeing stars and lightning bolts if someone tried to install on mine!
  30. Dec 16, 2021 at 12:26 AM
    #60
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Fixed it for ya. LOL
    alb1k[QUOTED] and shifty` like this.
