Auxilary Lights Install on First Gens
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, May 18, 2022.
  1. May 18, 2022 at 12:15 AM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    So I just made the decision of buying a pair of auxiliary lights to put on my truck and was curious as to how people wired theirs up because I honestly have no clue. I've seen some people have what looks like aftermarket buttons inside the cab to turn the lights on too and am curious as to how they did that. Can anyone clue me in on this stuff? It's just a 12V wire so I assume that'll work with my 12V battery. Thanks yall:)
  2. May 18, 2022 at 2:37 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  3. May 18, 2022 at 9:55 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Do you have the lights yet, and where are you looking to install? Some lights should come with a full harness and switch which will make things a lot easier.
    des2mtn likes this.
  4. May 18, 2022 at 1:14 PM
    evanhmn
    State of Taxes
    Lights haven't been delivered yet, but I plan on putting them where the windshield meets the hood if that makes sense. One on each side as you typically see with a lot of auxiliary lights.
  5. May 18, 2022 at 1:32 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The simplest (and crudest) way to accomplish this is it's own fused circuit with a switch and relay, wired directly the battery.
    Hopefully the lights you ordered should come with a wiring harness. If you're not confident making your own, or connecting the wiring to existing circuits in the truck, you can buy one. The two components your wiring harness needs to have 1. A fuse, ideally within the first foot of your wiring from the battery/ power source. 2. A relay.
    A wiring harness like this will work, you'd will need to run wires into your cab for the switch. You will also need to crimp terminal rings to connect to the battery, and crimp/solder the connectors on the lights to the leads on your wiring harness.
    https://www.amazon.com/Nilight-Wiri...1-1-5985efba-8948-4f09-9122-d605505c9d1e&th=1
    Kimosabe and evanhmn[QUOTED][OP] like this.
  6. May 18, 2022 at 8:14 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  7. May 19, 2022 at 9:36 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    What lights did you get? I'm sure someone here is familiar with them or has tried them.
    I'm definitely familiar with where you want to put them. I used these brackets from Rago and have been really happy with them.
    If your lights don't come with a wire harness then I think the harness and instructions from @des2mtn is the way to go.
    des2mtn likes this.
  8. May 19, 2022 at 1:50 PM
    evanhmn
    State of Taxes
    I just ordered some "Amazon special" lights I found that seemed to work pretty well in a youtube review I watched. Brand is called BigLion. I'm pretty sure the lights come with mounting brackets and a wiring harness but depending on whether I end up worrying about the brackets stripping paint, I will most definitely check those brackets out. Thanks man
    Kimosabe[QUOTED] likes this.
  9. May 19, 2022 at 1:59 PM
    des2mtn
    SW
    Tonto cover
    Good luck, if you run into any issues we'll be here.
    I have the Rago Fab brackets linked above too. They're pretty great.
    evanhmn[OP] likes this.
  10. May 22, 2022 at 10:52 PM
    evanhmn
    State of Taxes
    Thought I'd give yall a little update on the light situation. Rather than drilling holes in my hood for some 40$ lights, I found a nice spot to put them down on my front bumper. Wired them up, ran a switch inside the cab, and placed it in the fusebox nicely, and it's all good.
    So here's a pic from the front of where the lights are mounted, and no I didn't put that dent in the bumper :,(
    And theres a picture of my headlights/highbeams on.
    And lastly heres a picture with just my auxilary lights on. For 40 bucks, I think they do a pretty good job :)
    Casper421, des2mtn and 912 like this.
  11. May 23, 2022 at 1:41 AM
    NickB_01TRD
    Nick
    KY
    As long as you have an inline fuse off the batt then looks good and pretty bright too.
    I still really recomend the light bar in the cutout in the bumper if you wanna get wild with lighting.
    evanhmn[QUOTED][OP] and des2mtn like this.
  12. May 23, 2022 at 5:36 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    The lights i put on my titan are too low to help when the grass is too tall. They work great for lighting the road, but when you’re looking for deer that arent on the road yet, they’re lacking a little.
  13. May 23, 2022 at 7:04 AM
    des2mtn
    SW
    Tonto cover
    Good job! If you ever want to put lights in the previously planned location however, the Rago mounts we suggested don't require any drilling.
    evanhmn[QUOTED][OP] likes this.
  14. May 23, 2022 at 7:39 AM
    Casper421
    In the woods
    06 DC
    Watch yourself @evanhmn lighting can become an expensive mission if you let it take over! Come join the bright side!
    abcinv and evanhmn[OP] like this.
  15. May 23, 2022 at 3:58 PM
    evanhmn
    State of Taxes
    I plan on getting a light bar as well, just was starting with couple small ones first :) Thanks for the advice too, that pocket on my bumper must be filled!
  16. May 23, 2022 at 3:59 PM
    evanhmn
    State of Taxes
    That thing looks cool as hell. I want enough lights on my rig that I can confidently blind passersbys who have their high beams on, oh and also to go offroading at night
  17. Jun 15, 2022 at 2:40 PM
    evanhmn
    State of Taxes
    Just an update to the thread as I installed a couple more lights :)
