AuxBeam 8 Gang Switch Panel
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Jul 26, 2021.
  1. Dec 19, 2021 at 6:58 AM
    #61
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    So the ing is 10 amp. Read that it a small style fuse, is a " low profile mini " if that's true will i coming into any issues using a add a fuse connection.??
    pvn.beluga[OP] likes this.
  2. Dec 19, 2021 at 7:36 AM
    #62
    Sonicbluerider
    Dennis
    2019 Tundra
    Problem solved bought both mini an low profile mini .
  3. Dec 25, 2021 at 4:36 AM
    #63
    Sonicbluerider
    Dennis
    2019 Tundra
    Ok hopefully battery was just low when I got home. So shop added my fuze block an he said he put add a fuse on ing . No lights ect added yet. Went to start truck next day.. battery dead. Took truck or a long ride an going to let it parked for a couple days. Fingers crossed. However if dead battery again, where should I start looking? Other than the ing connection..?
  4. Dec 25, 2021 at 8:27 AM
    #64
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Take some photos, I want to see if there is a phantom drain somewhere. That’ll only be the result of your dead battery after the install.
  5. Dec 25, 2021 at 11:52 AM
    #65
    Sonicbluerider
    Dennis
    2019 Tundra
  6. Dec 25, 2021 at 12:43 PM
    #66
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    im gonna just leave this here.
  7. Dec 25, 2021 at 7:49 PM
    #67
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That add-a-fuse doesn’t look to be on IGN.
  8. Dec 26, 2021 at 10:54 AM
    #68
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    gonna need to see how you did that, that looks great!
    raymond_hb likes this.
  9. Dec 26, 2021 at 6:14 PM
    #69
    angkorstrong
  10. Dec 27, 2021 at 10:28 AM
    #70
    Sonicbluerider
    Dennis
    2019 Tundra
    My problem solved. Battery must of been drained during installation. Started right up today yahoooooo
    joseph_womack and raymond_hb like this.
  11. Mar 5, 2022 at 6:35 AM
    #71
    Sonicbluerider
    Dennis
    2019 Tundra
    Ok So 2- 30,20,10 & 5's
    Fuses... i need 3 10's. May i use a 20 amp one or put a 10 amp fuze in place of one of the 5's.
  12. Mar 6, 2022 at 8:32 PM
    #72
    joseph_womack
    Joe
    Louisiana
    you can always put a smaller fuse in one of the larger fused locations, but don't put a bigger fuse in one of the smaller fuse locations
    from my understanding of the auxbeam panel, all the spots are only rated to a certain amperage, meaning the 5 amp fuse section can only take 5 amps (even if you put in a 10 amp fuse)... so if you were to exchange one of the fuses for a 10 amp, it would need to be one of the 20s or 30s
  13. Mar 7, 2022 at 4:03 AM
    #73
    thedonn
    thedonn New Member
    I was thinking of this exact scenario. mine (spod) is always on and has bluetooth so you can turn lights on without having truck on. the system is always on and the backlights can be turned off. it has a low voltage mode default so it is supposed to shut down when the battery gets down to 11.7 I think. We will see if this can be trusted or not. i dont know anythinkg about electronics i picked spod because the switches looked close to coming from the factory.
    joseph_womack likes this.
  14. Mar 7, 2022 at 10:35 AM
    #74
    joseph_womack
    Joe
    Louisiana
    yeah spod is good, maybe even the best for aftermarket switch panels
  15. Mar 8, 2022 at 5:39 AM
    #75
    Sonicbluerider
    Dennis
    2019 Tundra
    Ok so i know nothing. So if I tap a 15amp fuze outlet on my gang of 8 for my 9.5 amp light will I be safe/ not burn it up,??,
  16. Mar 8, 2022 at 11:37 AM
    #76
    joseph_womack
    Joe
    Louisiana
    You can just replaced the 15 amp fuse with a 10 amp, the point is to not take a lower amp fuse and turn it into a higher amp fuse (talking about the factory placement of fuses from auxbeam)
  17. Mar 8, 2022 at 11:43 AM
    #77
    thedonn
    thedonn New Member
    I know nothing about electronics....would there be any benefit to using a smaller fuse?
  18. Mar 8, 2022 at 11:46 AM
    #78
    joseph_womack
    Joe
    Louisiana
    Yes, so if I have a lightbar that only pulls 5 amps and I put in a 30 amp fuse and then I get a power surge (ground issue, sparking, wires touching etc etc) that 30 amp fuse might not break and protect the lightbar, then you would have some 30 odd amps that the lightbar might not be made to handle surging towards in and frying your lightbar
    but if you put your correct 5 amp fuse in for the lightbar and you get a short circuit and it surges, it’ll pop the fuse and protect your electronic device
    (lemme know if you need more explanation)
  19. May 21, 2022 at 2:40 PM
    #79
    Sonicbluerider
    Dennis
    2019 Tundra
    Besides ing for connecting g of 8 whats the best fuze outlet inside cab to hook into? Yes I know I won't get that fuze box cover back on but thats ok.
  20. May 21, 2022 at 9:18 PM
    #80
    joseph_womack
    Joe
    Louisiana
    Hmmm, I actually tapped into one fuse in my engine bay fuse box, I can tell you which one tomorrow…
    some interior fuses you could use would be (I believe off of memory) cigarette, pwr outlet & cargo lamp
    just test with a multimeter which ones come in with key on and ignition vs which ones stay on with the truck off
  21. Aug 23, 2022 at 9:30 PM
    #81
    mav7021234
    mav7021234 New Member
    When you piggyback fuse tapped the AAC/IGN tap in the relay box. Did you just use the same amp fuse in the second slot of the piggyback wire?
    For instance I’m using the Nilight 6 switch panel setup, it’s saying I need to tap into ACC/IGN fuse. It’s a 10 amp fuse for me, do I just put another 10 amp in the second slot?
  22. Aug 23, 2022 at 9:34 PM
    #82
    joseph_womack
    Joe
    Louisiana
    Correct, I’d actually put maybe a 5, I believe that’s what I have on mine… make sure you install the fuse tap the correct way (see photo attached)
    mav7021234[QUOTED] likes this.
  23. Aug 23, 2022 at 10:16 PM
    #83
    mav7021234
  24. Aug 23, 2022 at 10:16 PM
    #84
    mav7021234
  25. Aug 23, 2022 at 10:16 PM
    #85
    mav7021234
    That correct? Sorry for the awkward posting, new to the forums
  26. Dec 5, 2022 at 10:30 PM
    #86
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    Do you have a side pic of the controller mounted in your cabin? I just ordered an auxbeam and have been thinking about that same spot for mounting the control panel
  27. Dec 6, 2022 at 2:43 AM
    #87
    Sonicbluerider
    Dennis
    2019 Tundra
    I put mine on left side of steering wheel on dash panel
  28. Sep 13, 2024 at 4:53 AM
    #88
    PatrolFighter
    PatrolFighter New Member
    Skyler
    Hey, sorry to resurrect this thread. But I have a similar question.
    got a 780 watt light bar from Nilight not realizing that it is at least a 65amp draw (newbie to electrical). I also have the Nilight 8 gang solid state switch panel that has a built in breaker of 80amps.
    The light bar came with its own wiring harness but has a cheapo rocker switch that doesn’t come close to the OEM or preferred look. The wiring harness has an inline 25amp fuse, a relay, black and red leads for the battery, and said rocker switch.
    I don’t think I should cut off everything downstream save the wire leads from the light bar (smaller light pods are just direct wired into the nilight controller as that acts as the relay and power source).
    Due to the draw on this light bar can I direct connect to the battery and then instead of running the cheap rocker switch into the cab just cut the rocker switch and wire that into the nilight?
    The rocker switch has a red, white, and black wires and the nilight controller only has a red and black?
    Thanks in advance.
  29. Sep 14, 2024 at 8:54 PM
    #89
    joseph_womack
    Joe
    Louisiana
    yes you can, however, if the lightbar wiring harness has a 25 amp fuse in it from nilight then the bar isn't actually pulling 65 amps/780 watts because it would blow that fuse every time you turn it on. If your nilight switch panel has maybe a 30 amp or 25 amp fused switch, you could ignore the entire nilight harness for the bar and hook it up to that switch. (just make sure whatever gauge wire you use is thick enough for the amperage)
    Alternatively if you wanted to keep the harness I believe you could just connect the red and black from the nilight harness to the red and black for a switch. I believe the white is another power to illuminate the switch when toggled, but I could be wrong, been a while since I messed with 3 prong rocker switches. Normally the ground on that switch is a gold colored pin; through trial and error you'll be able to get it hooked up, worst case is you'll pop a couple fuses
  30. Sep 15, 2024 at 4:44 AM
    #90
    PatrolFighter
    Skyler
    Yes. You’re right. It doesn’t make sense to me that the product is listed as 780 watts but then only has an inline 25 amp fuse. I’ll try it and see what way works best.
