Aux back up lights
Discussion in 'Lighting' started by Pudge, May 9, 2018.
  1. May 11, 2018 at 11:00 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Attached diagram will show you how to have them on a switch and come on with vehicle in reverse using a SPDT Bosch style relay.
    If you have no need for the switch (see the second diagram), just purchase a SPST Bosch style relay and it won't have a pin 87A, so the wires going to it and the switch won't be there.
    Pudge[QUOTED][OP] likes this.
  2. Jul 25, 2018 at 7:08 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Hey Chris love the way u set it up. I just got same lights myself and was thinking bout doing same. Are the lights holding up well? Any issues with water or going out ect? Want to be sure before I drill holes and make mistake. Any help greatly appreciated. Tia.
    TXRailRoadBandit73 likes this.
  3. Jul 25, 2018 at 7:09 PM
    I still need to do this!
    mgm16trdpro[QUOTED] likes this.
  4. Jul 25, 2018 at 7:26 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I did not either. I swapped the reverse light bulbs in tailights to LEDs. I also have backup leds on boat trailer along with surge brakes that are wired to reverse circuit. Never had an over load. I put leds in cargo light and it gives me all the light I need to hook up trailer. If I need more I can just set brake, turn key to on and put in reverse. No need for switch and all the extra wires.
  5. Jul 26, 2018 at 3:06 AM
    Cuzican
    Cuzican New Member
    Louisiana
    No problems yet, lights are holding up great, no water, or bulbs out. I've been so happy with them that I put a set on my work truck and I've got a set I'm adding to my 20' flat bed trailer, so it'll finally have some reverse lights.
  6. Jul 26, 2018 at 3:59 AM
    Cuzican
    Cuzican New Member
    Louisiana
    I never specifically mentioned it, but to mount them to the hitch, I drilled and tapped the hole and just bolted the inner mount to the hitch. The outer mounting bracket is not one that came with the light, it is just a piece of either 3/4" or 1" aluminum flat bar that I bent a right angle in, mounted it to the bumper, to see where the hole needed to be for the light, removed it, drilled the hole and cut it to length.
    mgm16trdpro likes this.
  7. Jul 26, 2018 at 7:17 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Great mod! Adding this to my list.
  8. Jul 26, 2018 at 2:26 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Nice I think I have the same set
  9. Nov 30, 2020 at 5:04 AM
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    Is there an option to mount some lights around license plate?
    I thought the bumper ends are metalic, but mid section is plastic.
  10. Dec 7, 2020 at 10:29 PM
    Eleventeen
    Eleventeen New Member
    Louis
    2016 Black CM Tundra
  11. Dec 8, 2020 at 5:16 AM
    AlexJet
    AlexJet New Member
  12. Dec 9, 2020 at 8:52 PM
    Eleventeen
    Louis
    the rears are wired to a SP9100 and to the reverse lights via toggle in the cab
  13. Dec 9, 2020 at 8:54 PM
    Eleventeen
    Louis
    the aux reverse lights are from Westin. got them used for like $30 I think. the reverse bulbs in the tail lights are from ALLA Lighting on Amazon. first pic shows stock vs. the change. very bright fro sure. I'll get a night pic and post up soon
  14. Dec 9, 2020 at 8:57 PM
    Eleventeen
    Louis
    sorry one more detail... I used the stock rear bumper, took it off, cut the holes for the lights, Line-Xed the bumper then reinstalled.
  15. Dec 12, 2020 at 6:20 PM
    Cuzican
    Cuzican New Member
    Louisiana
  16. Dec 13, 2020 at 8:47 AM
    AlexJet
    AlexJet New Member
  17. Dec 20, 2020 at 12:13 PM
    Eleventeen
    Louis
    Here it is
  18. Dec 20, 2020 at 1:25 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Has anybody just taped into the 7 pin trailer plug? There is a reverse light circuit to that plug correct?
  19. Dec 20, 2020 at 1:42 PM
    #49
    Yes, I tapped into mine.
