***Automatic Traction Control Disabler***
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Sting Ray, Jan 16, 2018.
Thread Status:
Not open for further replies.
  1. Feb 9, 2018 at 2:51 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    More parts just showed up, if you are interested you better hurry, I think i have 2 that aren't spoken for yet.
  2. Feb 10, 2018 at 7:00 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    I am interested! Just had a financial setback with needing a new water heater today, but after taxes I will PM you.
    Sting Ray[QUOTED][OP] likes this.
  3. Feb 10, 2018 at 8:02 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Sounds good!
  4. Feb 13, 2018 at 4:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  5. Feb 14, 2018 at 4:14 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I have 3 left, who wants one?
  6. Feb 19, 2018 at 7:45 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  7. Feb 23, 2018 at 5:11 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Parts arrived quickly and Ray had excellent communication. Will report back after install!
    Sting Ray[OP] likes this.
  8. Feb 23, 2018 at 7:48 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Awesome! I'll pm you my cell in case you have any issues or questions with install
  9. Feb 24, 2018 at 3:28 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Awesome. Thanks
  10. Mar 4, 2018 at 7:10 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  11. Mar 10, 2018 at 7:08 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Many thanks to Ray for his patience with me (old fart) while I was attempting to hook his harness up in my 2010. Got it done this morning in just a few minutes after locating an 'Ignition-On' hot wire. The Switch Wire on my 2010 is Yellow and there's a good ground location right next to the Truck's harness. Now, 'I' get to decide when I need Trac-Control, (by Turning It On) just like it should've come from Toyota!
  12. Mar 10, 2018 at 7:12 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Good stuff. Glad you are happy! Thanks again.
  13. Mar 10, 2018 at 8:33 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Still need to install mine. Always too busy to do anything for myself .
  14. Mar 10, 2018 at 8:41 AM
    CMB
    CMB New Member
    Cecil County MD.
    Ha! I know THAT feeling! Just got time today to get mine done. Had a "false -start" last weekend, when I couldn't locate a 'hot ignition-on' wire. Did a search and along with Ray's advise, I got it done. My 2010 has a small 'bundle' with a connector that's right next to the Trac-Control Switch that you unhook for access. In that bundle was my Blue "hot" wire.
  15. Mar 10, 2018 at 12:30 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    If anyone is in need I have more parts in hand.
  16. Mar 10, 2018 at 3:57 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    whats an F-16 crew chief doing playing with wires?! :facepalm::boink: :wink:
  17. Mar 10, 2018 at 5:03 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Lol, the pointy heads and spark chasers can't fix everything....
    ‘19pro and wigsplitter[QUOTED] like this.
  18. Apr 3, 2018 at 1:40 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Got mine installed works great! Free bump.
  19. Apr 3, 2018 at 3:29 PM
    #49
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Thank you sir! I appreciate it!
  20. Apr 12, 2018 at 7:29 PM
    #50
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  21. Apr 12, 2018 at 7:40 PM
    #51
    WTF?!?! Too cool!!!
  22. Apr 30, 2018 at 11:14 PM
    #52
    kb7uxe
    kb7uxe New Member
    2017 Tundra crew Max
    none
    I might like one.
    2017 Tundra CrewMax 5.7L 4X4
    Dan. kb7uxe
    ps any idea how to disable the "one touch start " and DRL's ? ??
  23. May 1, 2018 at 5:32 AM
    #53
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    To disable your drl is as simple as deppinning a wire from a connector under your dash. Which just so happens to be accessible when you install the TCD. I’ll pm you.
  24. May 17, 2018 at 10:09 AM
    #54
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    What if you don't want the nannies auto off on start up, but instead want an "Off Road" button on the dash that would disable the nannies when the button is pressed? Could that be rigged as well?
  25. May 17, 2018 at 10:11 AM
    #55
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Not sure...
  26. Jun 22, 2018 at 8:38 AM
    #56
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    So is the trigger for the button a positive or a negative trigger for the signal that gets tapped to the brown/yellow wire (depending on model year) off the TC button?
  27. Sep 10, 2018 at 10:01 PM
    #57
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I think I'd like to get one of these. Still making them?
  28. Sep 10, 2018 at 10:43 PM
    #58
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    That what am looking for can you pls send me the link by inbox of paypal so i can go ahead and pay for it
    Plus will you ship this part for me to united arab emirates / dubai
    Let me bro and i will need along with it the things y wrote so my any electrical guy can do this for me .
  29. Sep 10, 2018 at 10:51 PM
    #59
    CMB
    CMB New Member
    Cecil County MD.
    Ray,have you made any headway into getting this to work on 2nd Gen trucks?
  30. Sep 11, 2018 at 5:27 AM
    #60
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes you can find them on my website www.harmoncustoms.com thanks!
Thread Status:
