Autoloc auto window up and down project
Discussion in '2.5 Gen Tundras (2014-2021)' started by SiberianTundra, Mar 3, 2019.
  1. Feb 7, 2020 at 5:16 AM
    #91
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Basically what you're doing is sending the window's "UP/DOWN" signal from the switch to the new window controller box instead of straight to the window motor. The Controller box is then determining what way it sends the window and holds the contact inside it until the window has reached the top or bottom limit.
  2. Feb 17, 2020 at 4:40 PM
    #92
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Started poking around with a tester and window stopped working :censored:
    Not sure what I did but seems like I fried a fuse. Passenger window will not go up or down after I use tester and poked at the connections. I tested switch on other windows and it works all I can close window with main switch on driver side. So for sure it is a fuse.
  3. Feb 18, 2020 at 5:30 AM
    #93
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I have never seen a separate fuse for each window. sounds like you got something else going on.
  4. Feb 18, 2020 at 8:39 AM
    #94
    SiberianTundra
    Greg
    War Machine
    No it is a fuse for sure. Might be a global fuse. Since the switch works on the rear window and window by it self works from master switch.
    Leaves only a fuse. Might not be for each window. But a fuse non the less.
    However I will continue to verify wires once I fixed passenger window.
  5. Feb 19, 2020 at 5:44 PM
    #95
    SiberianTundra
    Greg
    War Machine
  6. Feb 20, 2020 at 4:02 PM
    #96
    DASH_RIPROCK
    DASH_RIPROCK New Member
    Dasche
    2019 Tundra TRD Offroad
  7. Feb 20, 2020 at 4:17 PM
    #97
    SiberianTundra
    Greg
    War Machine
    ok ordered extension cable for power windows switches. Its on its way next week arriving Tuesday. Then I will splice it all up and plug and play module should work following the help I got from @Rebel Tundra Man
    stay tuned
    Rebel Tundra Man and WFD473 like this.
  8. Mar 8, 2020 at 3:08 PM
    #98
    jamestada
    jamestada New Member
    James
    2020 Tundra TRD Sport 4x4 Magnetic Grey
    Fox 2.0 Front/Rear 18" Fuel Beast wrapped in Nitto Terra Grappler G2
    Hi All,
    Just completed this install on my 2020 Tundra TRD Sport. Stock only had driver side auto down so I've installed on ALL 4 windows. Installation is a breeze.
    Here is the set I purchased: Autoloc 9863
    The instructions it comes with are horrible, but the same company has the pdf (autwc1000.pdf) attached to this post on their website.
    A couple tips before getting into the wiring:
    1. If you've got some skinny hands, you do not need to remove the door panel to complete the install. Just use a trim removal tool to pry the switch module off the door.
    2. The driver's door has a ground wire going to it, all other doors do not. So for the ground wire from the Autoloc module, you must ground it to the door. There is a bolt that is visible after you remove the switch module. If you can't get to it, you'll have to remove the door panel.
    Wiring:
    • Front - Driverside
      • Cut: LIGHT BLUE and BROWN
      • Autoloc BROWN -> Switch LIGHT BLUE
      • Autoloc GREEN -> Door LIGHT BLUE
      • Autoloc WHITE -> Switch BROWN
      • Autoloc BLUE -> Door BROWN
      • Autoloc BLACK -> Tapped to Door WHITE/BLACK
      • Autoloc RED -> Tapped to Door PINK
    • Front - Passenger
      • Cut: RED and BLACK
      • Autoloc BROWN -> Switch RED
      • Autoloc GREEN -> Door RED
      • Autoloc WHITE -> Switch BLACK
      • Autoloc BLUE -> Door BLACK
      • Autoloc BLACK -> Grounded to door
      • Autoloc RED -> Tapped to Door BLUE
    • Rear Doors - Both are the same
      • Cut: RED and GREEN
      • Autoloc WHITE -> Switch GREEN
      • Autoloc BLUE -> Door GREEN
      • Autoloc RED -> Tapped to Door YELLOW
    • Rear Window
      • For the rear window, there is no power supply there. You'll need to bring it to the auto up/down module. I used the power that is going to the rear door that you tapped into for the door.
      • To get to it, remove the bolt holding down the seat-belt, then remove part of the weather striping from both front and rear that is holding the lower trim piece and pry it off, it is held on by trim retainer clips.
      • Then simply use a multi-meter to figure out which is the constant power. You'll need the truck to be turned on.
      • Remove the rear passenger side seat, there are four bolts holding it down. I just leaned the seat forward instead of pulling it all the way out.
      • You'll see a wire loom going into the rear cab wall with two wires. From here it's wired the same way as the rear doors.
      • Autoloc RED -> Brought from rear door.
  9. Mar 8, 2020 at 3:58 PM
    #99
    TUNDRAPROGUY2017
    TUNDRAPROGUY2017 New Member
    Illinois
    2017 TRD PRO Crew Barcelona Red Metallic
    Awsome!
    SiberianTundra[OP] likes this.
  10. Mar 8, 2020 at 4:25 PM
    #100
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Awesome, great info. Do all four switches on driver's door auto-up/down now?
    Edit: I ask b/c I read somewhere that one Autoloc is needed for every button.
  11. Mar 8, 2020 at 5:03 PM
    #101
    :thumbsup:
  12. Mar 8, 2020 at 5:04 PM
    #102
    Great first post.
    Welcome from NY.
  13. Mar 8, 2020 at 6:30 PM
    #103
    SiberianTundra
    Greg
    War Machine
    My Hero!
    Wow amazing job!
    KTJO 4x4 likes this.
  14. Mar 8, 2020 at 6:43 PM
    #104
    biebs96
    PA
    Any info on how to do this on the crewmax rear window??
    YotaMan and big_jarv like this.
  15. Mar 8, 2020 at 7:17 PM
    #105
    jamestada
    James
    You'll need one for each door. The auto up/down will work from the door's switch and from the driver's switch console. So you'll need 4 in total. 5 if you also want to do the rear window.
  16. Mar 8, 2020 at 7:26 PM
    #106
    Will the drivers door have auto up/down control for the front passenger side window if one is put on that window? Or is it only each door that has the module that can control only that door?
  17. Mar 8, 2020 at 7:28 PM
    #107
    jamestada
    James
    Didn't think about the rear window! Maybe I'll tackle this later, but I'd imagine it's very similar. There should be at least 4 wires on the motor's connector:
    1. Positive Up
    2. Positive Down
    3. Constant Positive
    4. Ground
    If I ever decide to do this mod, I'll update my post. Thank you all for the positive feedback on the post. The forum has been pretty helpful when researching things for my new truck and I just wanted to share. This very post is what inspired me to do this mod for myself!
    LogCabins likes this.
  18. Mar 8, 2020 at 7:30 PM
    #108
    jamestada
    James
    Yep! The Auto up/down works from the driver's door or from the door it's installed on.
  19. Mar 8, 2020 at 7:31 PM
    #109
    So from the drivers door I can auto up/down the passenger door?
  20. Mar 8, 2020 at 7:33 PM
    #110
    jamestada
    James
    Yes.
  21. Mar 8, 2020 at 7:34 PM
    #111
    :thumbsup:
    Thanks :hattip:
  22. Mar 8, 2020 at 7:44 PM
    #112
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  23. Mar 8, 2020 at 8:21 PM
    #113
    TUNDRAPROGUY2017
    Illinois
    Wish I owned AutoLoc stock!
  24. Mar 8, 2020 at 9:48 PM
    #114
    SouthWestGA
    SouthWestGA New Member
    Somebody needs to make a plug and play harness adapter for this mod!
    KTJO 4x4 and SiberianTundra[OP] like this.
  25. Mar 8, 2020 at 10:23 PM
    #115
    SiberianTundra
    Greg
    War Machine
    Totally agreed !
    1lowlife and YsoSeRiouS! like this.
  26. Mar 8, 2020 at 10:51 PM
    #116
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Someone needs to do it to the rear window.. that is a must
    YotaMan likes this.
  27. Mar 9, 2020 at 3:30 AM
    #117
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Paging @KTJO 4x4 :D
  28. Mar 9, 2020 at 7:27 AM
    #118
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Fantastic write up! been following this for a while waiting for this...guess i will be ordering me some modules.
  29. Mar 9, 2020 at 8:40 AM
    #119
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Did you replace the actual switches with the same ones the drivers window has?
  30. Mar 9, 2020 at 3:12 PM
    #120
    jamestada
    James
    No, the module gets installed between the switch and the window motor.
    1lowlife likes this.
