Auto start/stop, do you leave it on or disable it?
Discussion in '3rd Gen Tundras (2022+)' started by SnowRunnerTundra, Jan 10, 2022.
  1. Jan 10, 2022 at 4:26 PM
    SnowRunnerTundra
    SnowRunnerTundra [OP] New Member
    2022 Hyundai Santa Cruz Limited
    I've never owned any ICE vehicle that has that feature, but non-hybrid Tundra has it, so inevitably, I'm wondering what will happen to the truck if I were to just leave that feature on regarding component life span instead of mpg savings?
  2. Jan 10, 2022 at 4:34 PM
    ezdog
    ezdog New Member
    Gateway To The West
    The most annoying feature ever to me.
    Also even more annoying as you need to reset it to off every time you drive I bet?
    I cant accept that the starter will last as long starting all the time and I also can not accept that any gas savings are really worth the trouble.
    Did I mention I hate this feature!
  3. Jan 10, 2022 at 4:41 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I turn it off. Even in the cars I rent. Off. I like to go when light turn green instead of waiting for engine to turn over and then go. It’s the delay for me.
  4. Jan 10, 2022 at 4:43 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That^ I can't believe the starter is happy about working every two blocks instead of twice a day. I also think it's the most annoying feature ever, even when it's extremely seamless it's annoying to hear the stupid thing kicking on and off.
    TK1979 likes this.
  5. Jan 10, 2022 at 4:55 PM
    TF_CC
    TF_CC New Member
    It’s been a common feature on European cars for years and years.
    I actually like it and use it in all of my vehicles - saves gas too and with what we’re paying now for a gallon, every drop counts.
    Hella Krusty, KidMet and TK1979 like this.
  6. Jan 10, 2022 at 5:22 PM
    Dagwood
    Dagwood New Member
    I have this feature on my 2022 Off Road. It has a switch to disable it yet you control it with brake pressure.
    Drove 800 miles so far and only had it turn the engine off once - because I pressed the brake pedal down hard just to see what would happen.
    This feature is not turning the engine on and off at every stop. Only if you push the pedal hard when you are stopped does it shut the engine down.
  7. Jan 10, 2022 at 6:43 PM
    xc_tc
    xc_tc New Member
    I’ve had this feature on a couple of cars. In the Tundra you don’t really need to disable the start-stop if you’re careful with your brake pressure. In a normal stop, I can keep the engine from shutting down. If I want the engine to shut off like at a long red light, I can press the brake pedal a bit harder and the engine will shut off. And I can watch the cross traffic signal for when it turns yellow, at that point I lift off the brake slightly and the engine fires up again in less than 1 second.
    Generally, I like this system except when it’s hot out and the AC starts blowing hot. Some manufacturers like Ford are good about disabling start-stop when it’s hot out.
    raylo likes this.
  8. Jan 10, 2022 at 7:44 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I've had it in a few cars, turn if off every time
  9. Jan 10, 2022 at 8:02 PM
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Most annoying shit ever. You know how expensive starter replacement is?
  10. Jan 10, 2022 at 8:06 PM
    outlaw.taco
    outlaw.taco New Member
    Houston
    Drove another vehicle with this future, it activates whenever I get home so I have to start it to shut it off if that make any sense at all
    Toyota1234 likes this.
  11. Jan 10, 2022 at 8:09 PM
    xc_tc
    xc_tc New Member
    Starters are different for vehicles with start-stop. They spin slower and use different internal components than conventional starters for longer life.
  12. Jan 10, 2022 at 8:11 PM
    RoddersLV
    RoddersLV New Member
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    It’s fairly easy to avoid/ignore it…just don’t depress the brake pedal that extra distance required to trigger the feature.
  13. Jan 10, 2022 at 8:16 PM
    RoddersLV
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    I’ve noted it tends to restart anytime the internal cabin temp drops (what appears to be) even a degree for both Ac and Heater
  14. Jan 10, 2022 at 8:26 PM
    Beast51
    Beast51 New Member
    Surprise, AZ
    2022 Tundra SR5 4x2-Magnetic Gray
    running boards, 20 inch Black TRD Wheels, Falken 20 inch Wild Peak A/T(AT3)tires
    Part of my driving routine now includes shutting off the auto start/stop before I pull out of the driveway...or out of any parking lot
    Jkeown likes this.
  15. Jan 10, 2022 at 8:34 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I thought this would be more of a issue then it really is. In order for the engine to turn off you have to really push the break down hard. And hold it down. Of my 700 miles the truck has shut off 3 times. 1 of those times was on purpose.
    22PlatWCP likes this.
  16. Jan 10, 2022 at 9:20 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    What is it about a starter that it can't last as many duty cycles as a AC compressor, or an alternator, or a power steering pump? What makes a starter so unique that it can't perform the duty of these other parts that are constantly under stress?
    BTBAKER and Mattedfred like this.
  17. Jan 10, 2022 at 9:34 PM
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    I leave the feature enabled. I like it but it is annoying. I always forget to press the brake hard enough to get it to activate. Usually I’m watching lights and traffic so I take my foot off the brake before I need to go an it’s not a big deal IMO.
  18. Jan 11, 2022 at 4:12 AM
    blanchard7684
    blanchard7684 New Member
    This is easily the dumbest automotive feature ever. Remember the automatic seat belts in the 1980s that were more like a horror film's creative way to decapitate people?
    Yeah its worse than that.
    starts and stops are a key way to reduce engine life. And here we have a feature programmed into the system to make it happen.
    Seriously disappointed this is on the 3rd gen but not surprised.
    Since I'm used to getting in the '19 Pro and hitting trac and tow/haul nearly every drive cycle, I've habituated to turning things on and off. But still...OEMs need a clue here.
    The 0.5 mpg it saves isn't worth this torture.
    Jettster, Toyota1234 and Mr Badwrench like this.
  19. Jan 11, 2022 at 4:18 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I would imagine someone will come out with a harness that turns it off permanently so you don’t have to hit the button each time you get in the truck. Kind of like the Taco guys with their “ECT (tow/haul) always on” harness.
    Biggest annoyance in all the rentals I drive every year is turning that feature off each drive.
    doublethebass likes this.
  20. Jan 11, 2022 at 4:31 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I have only driven Rentals with the start/stop feature and it is amazing how annoying and downright dangerous it can be in some vehicles to me and all for the tiny added economy that we are supposed to accept it provides so that the maker can get the corporate MPG claims in line with newest regulations period,there is no other advantage that I can think of at all?
    So I was not even aware that the Tundra start/stop feature is different and to some extent can be controlled by braking pressure?
    Sounds like partial BS to me.
    Funny though I rented a RAV4 the Week of XMas and drove it 1600 miles and now I wonder if that car had this feature too?!
    It never really occurred to me as I tried to remember to turn the S/S off every time I got in the car but I now remember "Erratic" operation and this sure could have been the cause.
    The Rental place of course would not have mentioned it at all and I would not have imagined that the feature had "Evolved" to this point either?
    Great little SUV overall though I thought.
  21. Jan 11, 2022 at 4:43 AM
    xc_tc
    xc_tc New Member
    It’s the brushes. They’re basically carbon blocks that wear down as the motor turns. Once the brushes no longer make good contact with the commutator, there’s no electrical connection to make the motor work.
    Mike59 and 6thyota like this.
  22. Jan 11, 2022 at 4:43 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^.
    I also believe that it requires extraordinary oiling features to keep things "cool" when the engine goes into temporary shut down. As mindlessly stupid as we have ever created as a people.
    Black@Blue19 likes this.
  23. Jan 11, 2022 at 5:36 AM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    Not that I like the feature but I don’t understand the worrying about the starter. I’ve had a lot of vehicles from a lot of manufacturers anything from brand new to 250k+ miles and I can’t even remember the last time I replaced a starter.
  24. Jan 11, 2022 at 5:36 AM
    ezdog
    ezdog New Member
    Gateway To The West
    And this makes you wish your Taco had the feature why exactly?
  25. Jan 11, 2022 at 5:37 AM
    ezdog
    ezdog New Member
    Gateway To The West
  26. Jan 11, 2022 at 5:44 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Thanks for clearing that up.
    I am just not a buyer that this is real and that if it is that you actually realize calculable savings at all vs the aggravation factor it brings me?
    I did get used to it when I had a Prius briefly though too.sort of though it is a completely different thing there.
  27. Jan 11, 2022 at 6:56 AM
    Toyota1234
    Jack
    None of those turn over an engine. They just Engage.
  28. Jan 12, 2022 at 7:16 AM
    RoddersLV
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    Here’s my “one man’s opinion” of this feature as it relates to the Tundra. Due to the necessity of depressing the brake deeper into its travel to actuate the SS feature, I didn’t even realize it existed for several days. I apparently soft brake at stops and the first time it did it was when I was stopped at a light and was reaching back into the back seat area to grab something and did my normal “crush that brake pedal you idiot” before contorting myself into a 6’3” pretzel. I thought I’d somehow turned the truck off.
    Took a moment to realize what it was/I did. I’ve since realized, for me, it’s an unnatural act to depress that brake peddle deeper (that’s what she said) and I’ve essentially ignored it. In addition, and many have pointed it out, it probably won’t even engage during the summer months here in the desert southwest due to cabin temperature demands on the AC.
    Lastly, there’s always someone in this group who will figure out how to permanently disengage it.
    Tundrastruck91 and Dagwood like this.
  29. Jan 12, 2022 at 8:04 AM
    wired
    wired New Member
    David
    2022 Tundra Black SR5
    I had it on my 2018 Rubicon and it was annoying, shutting off the engine at every stop. Seems everyone got a Tazer or some other plug in to defeat it. Apparently on the Jeep it wouldn't engage if the hood was up so a lot of people used that sensor to keep it off. I have found the one on this 2022 Tundra (I have SR5) to be much less sensitive. I can come to a stop at lights or stop signs without engaging the system. You really have to apply 'extra' pressure on the brake at a stop to engage it. Only time I engaged is was in a drive-thru when I was pushing down on the brake as I was straightening my leg to get my wallet out of my pocket. I do wonder if some are more sensitive than others and if it is adjustable.
    Dagwood likes this.
  30. Jan 12, 2022 at 9:19 AM
    tacomaniac
    tacomaniac New Member
    Does anyone know if the Tundra implementation has a secondary auxiliary battery to support the feature? I had a Jeep Grand Cherokee which I disabled every time I started the car and I encountered battery fault messages every few months. Each time, the auxiliary battery (stupidly located underneath the passenger seat) had went bad or had a charging issue. The last time it occurred, the dealer blamed it on me for not utilizing the start stop feature lol. I'm hoping there is no aux battery to worry about on the trucks.
