Auto headlights shut-off with turn signal
Discussion in 'Lighting' started by renlo, Mar 19, 2018.
  1. Nov 11, 2019 at 5:22 PM
    #91
    16RC5.7
    16RC5.7 New Member
    2016 Platinum Crewmax
    Bakflip F1, TRD Pro Grill, Color match mirrors and handles.
    Yes. My lights haven’t been off of Auto since Ive owned the truck. It’s only happened twice so far but I’m wondering if it will start to be more frequent
    Pudge[QUOTED] likes this.
  2. Nov 11, 2019 at 5:41 PM
    #92
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm the same way. I leave them on auto. It has happened to be a total of 4 times I think. Each time i was stopped or slowed at an intersection of some kind and signaling left in cool-cold weather. Most recent was about a week ago and hasnt happened since, last year it was 3 times in about a weeks span and then a full year before it reared its head again. Very very odd
    Edit: you're the first one to have the issue with retrofits, I have 18 OEM LED conversion with a very good harness from ihacker and a few people have had this with completely stock lights and electronics all together. I think it's an issue with the light/blinker stalk but I can't prove it
  3. Nov 13, 2019 at 6:18 AM
    #93
    MisterMoose
    MisterMoose New Member
    2016 Black Tundra Platinum
    Adding one more Tundra to the mix. 2016 Platinum. No mods. Dealership maintenance only.
    Below 40 degrees. Headlights on auto. Signal left, turn left = lights out.
    I haven't figured out specifically what kind of manipulation restores the light nor am I able to reliably reproduce the issue. I have scheduled a service appointment in two weeks. I'll use these videos (thanks!) as evidence as well as proposed corrective measures.
    Man I hope I included electrical in my extended warranty. . .
    I also plan to report this to the NHTSA as well.
    Thanks all.
    Pudge likes this.
  4. Nov 14, 2019 at 3:56 AM
    #94
    SikYota
    SikYota New Member
    Northport, AL
    2014 Platinum
    7" bds suspension lift with fox coilovers 37/13.50r20 cooper discover stt pros 20x10 -24 fuel mavericks with machined faces Nitro 4.88 gears Ekstrom design tie rod ends Zone carrier bearing drop Amp research steps Retrax pro bed cover http://www.gearinstalls.com/Chris2014Tundra.htm http://www.gearinstalls.com/Chris2014Tundrafront9.htm https://youtu.be/2P3yKKwG1ig
    Same issue here. 14’ platinum, auto headlights on, cold mornings, blinker triggers event. Trouble shooting- if the issue is in the stalk(inside the truck) then why does the cold weather have an effect on it? I mean, I have my heat blasting so it’s not like the stalk is cold when the issue happens.
  5. Dec 5, 2019 at 11:28 AM
    #95
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    I filed a complaint with Toyota, all they could tell me was to go to a dealer. I managed to trigger mine today when smacked the top of my steering wheel.
  6. Dec 5, 2019 at 12:58 PM
    #96
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Happened to me this morning for the first time. 2017 1794 just over 25,000 miles. Early morning, about 50 out, lights on auto (2018 or 19 Pro Headlights with iHacker harness) I was going about 45-50 and was just merging right with right blinker on. I know about this problem because it happens on my friend 14 Platinum with no mods.
  7. Dec 11, 2019 at 5:53 PM
    #97
    YetiXing
    YetiXing New Member
    My 1794 does this. Dealership can’t find a problem. Any fixes yet??
  8. Dec 11, 2019 at 5:55 PM
    #98
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    I think the fix is to replace the stalk with another stalk that will do the same in a couple of years.
  9. Dec 11, 2019 at 6:09 PM
    #99
    YetiXing
    YetiXing New Member
    Are there any videos/instructions on changing. Thanks.
  10. Dec 11, 2019 at 6:13 PM
    #100
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
  11. Dec 11, 2019 at 6:16 PM
    #101
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    You should also file complaints with the NHTSA and Toyota, maybe if enough of us do they will do a recall.
  12. Jan 3, 2020 at 5:50 AM
    #102
    thunderklees
    thunderklees New Member
    Danny
    2017 White 1794
    Hello. I had the same issue a few times in my 2017 1794. I submitted my VIN. Has anyone found a solution to this issue yet?
  13. Jan 3, 2020 at 6:17 AM
    #103
    spiketundra
    spiketundra New Member
    17 1794 CM
    DiamondBack Cover, TRD Rear and Front Sway Bar, Driver Side Grab Handle, Spray in Bedliner, AMP Power Step
    I just submitted a complaint as well. On youtube GearRunner has a video and hopefully a fix (signal stalk) that the dealership did. Thought mine was just in colder temps but it did happen in the mid 60's.
    thunderklees likes this.
  14. Jan 24, 2020 at 4:29 PM
    #104
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    Unfortunately this has now happened to me too. It makes me feel slightly better to know I’m not the only one, but doesn’t change that fact that now I’m driving wondering when it will happen again. Will someone rear end me, will I lose my way around a corner, or etc. It’s 2 times now in the past week, turning left, lights on auto setting, 1794 crew max, ‘19 pro leds, ihacker harness. Can not replicate on purpose.
  15. Jan 29, 2020 at 2:03 PM
    #105
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Replaced my combination switch today. I disected the old one and do not see any point of failure.
    spiketundra likes this.
  16. Feb 15, 2020 at 5:08 AM
    #106
    BigRedFireEngine
    BigRedFireEngine New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    Does the replacement switch appear to be updated at all? And can I ask how hard of a job was it to swap them?
    Thanks
  17. Feb 15, 2020 at 5:54 AM
    #107
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    The switch looks identical. I had toyota do the work so that it would be covered. They charged me 1 hour of labor.
  18. Feb 15, 2020 at 6:05 AM
    #108
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Just a thought, could this be battery related? Seems to be on 4-5 year old(end of battery life span) vehicles in cold weather. Maybe voltage is dropping??
  19. Feb 15, 2020 at 6:18 AM
    #109
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    I dont think so, as I had replaced the battery and the same issue before and after.
  20. Feb 15, 2020 at 9:35 AM
    #110
    Scud
    Scud New Member
    Working on it :-)
    Happened to me again last night. Left turn, 43 temp. First time it happened it was right blinker. Strange
  21. Feb 16, 2020 at 6:05 AM
    #111
    spiketundra
    17 1794 CM
    Do not think it is the battery. Mine has been replaced and still has the issue. Anyone hear back from NHTSA? I submitted a claim over a month ago and they wanted more information e.g., video, proof of going to dealership, etc. Since providing that information it's been crickets.
  22. Feb 23, 2020 at 2:26 PM
    #112
    Brophinator
    Brophinator New Member
    2016 tundra 1794
    Add me to the list of people with this problem, 2016 1794, it's my wife's, not sure if it happens with right left or both signals but all the lights go out at random when using signals on auto headlights
  23. Feb 26, 2020 at 8:23 AM
    #113
    gsbtx19
    gsbtx19 New Member
    I purchased my 2016 Platinum in December and this has happened to me at least 4 different occasions. I submited a complaint to the NHTSA as well.
    Angry Gunny likes this.
  24. Mar 19, 2020 at 6:00 AM
    #114
    fmellish
    fmellish New Member
    2016 Tundra Platinum
    This happens to me a few times a month, I'd say (2016 Platinum). Mostly when I turn left, but I think it's happened on a right turn too - I honestly can't remember. I just replaced my battery about a month ago and it had no impact on this issue. It's annoying, unsafe, and disappointing that Toyota won't recognize the problem.
  25. Mar 19, 2020 at 6:13 AM
    #115
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Its been about two months since I replaced the headlamp switch, I have not had this issue since.
  26. May 26, 2020 at 10:23 AM
    #116
    Vanskippy#91
    Vanskippy#91 New Member
    2017 Blue Tundra CM Platinum
    I have a 2017 Platinum and have been experiencing the same issue for the last year or two. Because it is an intermittent issue, I have not wanted to go to the dealership to have it addressed. The warranty will be expiring at the end of this year, so I am going to take my Tundra in this week. Thank you to all have posted to this thread. I will point out the stalk replacement comments to the dealership when I go in and will update with their response.
  27. May 27, 2020 at 6:40 AM
    #117
    Wagwan
    Wagwan New Member
    Jay
    2017 Toyota Tundra 1794
    None
    Add me to the list of victims. I recently purchased a 2017 Toyota Tundra 1794 with 23,000 miles and it happened twice within two weeks. I was not aware of so many others having the same problem. In reading the post, it looks like it is only affecting the 2016/2017 model years. Replacing the stalk sounds like it might be the answer, my work around has been not using the auto function on the stalk.
  28. Jun 2, 2020 at 3:41 AM
    #118
    spiketundra
    17 1794 CM
    If you submitted a claim to the NHTSA have you heard anything? Crickets on my end. Thanks in advance.
  29. Jun 2, 2020 at 6:31 AM
    #119
    Wagwan
    Wagwan New Member
    Jay
    None
    Nothing other than an acknowledgement form NHTSA that they received my complaint.
  30. Jun 2, 2020 at 9:11 AM
    #120
    spiketundra
    17 1794 CM
    same
