Auto headlights shut-off with turn signal
Discussion in 'Lighting' started by renlo, Mar 19, 2018.
  1. Dec 17, 2018 at 2:25 PM
    ktothemann
    ktothemann New Member
    2015 Silver Tundra 1794 Edition
    You might be onto something. In October, I got a SnugTop Rebel topper installed. Obviously, that gets wired into the third brake light. I never noticed this issue prior to that.
  2. Dec 17, 2018 at 2:32 PM
    prlauren
    prlauren New Member
    I’m also going to replace the 100 dollar ambient light sensor on the center dashboard just for sh!ts n giggles. I ordered the sensor and should have it in on Tuesday. I will keep you updated. It wouldn’t hurt to unplug it for a few weeks an see if the aftermarket has anything to do with it.
  3. Dec 18, 2018 at 4:41 AM
    prlauren
    prlauren New Member
    Ok it happened again to me this morning. I even had the aftermarket third brake light disconnected. Well today I should receive the new ambient light sensor. If it does it again after that then it’s either in the headlight stalk or even worse would be the BCM Module.
  4. Dec 18, 2018 at 12:24 PM
    prlauren
    prlauren New Member
    Ok here goes nothing with the ambient sensor I will let you know if it resolves my problem in a few days.
  5. Dec 18, 2018 at 1:52 PM
    JoelTundra2015
    JoelTundra2015 New Member
    Joel Kennison
    Toyota Tundra 2015 Platinum
    Hello Everyone, my Toyota Service Department called me today and explained Toyota engineering is aware of the current issue and they are ordering a part recommended. Once I get the new part number I will share.
    My Toyota Dealer:
    Autonation Toyota Haward
    Joel
    pdiddy likes this.
  6. Dec 18, 2018 at 1:53 PM
    JoelTundra2015
    Joel Kennison
    If we collectively can't get Toyota to fix the problem we should be contacting NTSB to get a Recall started.
    prlauren likes this.
  7. Dec 18, 2018 at 2:23 PM
    prlauren
    prlauren New Member
    Great because I am in changing parts mode. I just changed ambient sensor. Next I was going to change headlamp switch. Hope we get an answer
  8. Dec 19, 2018 at 4:16 PM
    Bonecrusher
    Bonecrusher New Member
    2106 Tubdra 1794
    None
    Found this forum after google search of this problem. Just want to add my 2016 Tundra 1794 to the list. Bone stock truck and intermittent issue, just happens randomly. Hope someone posts a fix!
    BC
  9. Dec 19, 2018 at 4:27 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Wow this is a crazy issue. Hope you guys get it resolved and please do share the outcome. I am curious to see and also to help any other future people that may encounter the same issue.
  10. Dec 19, 2018 at 4:54 PM
    Medging
    Medging New Member
    2016 silver sky metallic platinum
    18inch fuel wheel, nfab step bars
    i have a 2016 platinum that has only done this 3 or 4 times in the last year and a half. Bone stock as well with lights. Add me to the list!
  11. Dec 19, 2018 at 5:07 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Add me to the list, same problem...17 1794 stock lights. Happens with right turns usually, sometimes left. Almost everytime I drive it.
  12. Dec 19, 2018 at 5:13 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    I have the same damn issue with my 2017 platinum. So you just have the do the above once and magically goes away or every time we get in our trucks? I have the new 2018 headlight mod with ihacker harnesses. I will try this tonight hope this fixes our issue. IMO it feels like the turn signal stick is bad or something is shorting back there. BTW this only happens with my left turn signal.
  13. Dec 19, 2018 at 5:17 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    All my lights inside, out, front and back are all VLEDS or toyota. Seems this problem occurs even with completely stock set ups. I am pretty sure if I take to my dealer they won't be able to replicate or fix anything fml.
    JoelTundra2015 likes this.
  14. Dec 19, 2018 at 5:20 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    So this problem only occurs on platinum and 1794 trims?
  15. Dec 19, 2018 at 5:23 PM
    prlauren
    prlauren New Member
    Yeah mines a 2017 1794 edition with 18,000 miles. Happens randomly for me and noticed when right signal goes on. I tried replacing the cheapest part first which was the ambient light sensor on dash board, but problem happened again today so it’s not the sensor. I talked to my mechanic. He said it could be in the signal stalk or a module or the BCM. He would do the same thing I’m doing by replacing the cheapest part first unless I can replicate it consistently for him to diagnose. I connected my computer scanner to the truck and no error codes.
  16. Dec 19, 2018 at 5:27 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    My gut is telling me it's the signal stock. Electrical problems are the hardest things to track down fml. I just figured out why my accelerator was cutting out thanks to another forum brother on here. Now I gotta deal with this crap lol
  17. Dec 19, 2018 at 5:35 PM
    prlauren
    prlauren New Member
    I work at a body shop and I looked up the signal stalk. It says the signal stalk is 161 bucks and an hour to put in. Usually an hour labor is more like a half hour if you know what your doing. Only problem is if it’s the headlamp stalk n u replace it the problem could come back unless they fix the issue with a new headlamp stalk part number which would supersede the old.
  18. Dec 19, 2018 at 5:54 PM
    cjim46
    cjim46 New Member
    2014 tundra platinum
    Hi everyone! I have a 2014 platinum with the same problem. I have noticed that every time this has happened I was at a stop with the left turn signal on and when I finished turning and the turn signal cancelled is when the lights went out. I have no aftermarket add on anything so that rules that out. I am a ASE auto technician and am thinking the problem is in the multi-function switch, but have not been able to prove it as of yet, seeing how that is what is common with the problem with the lights and turn signals. I will let you all know what I find out if I find out.
  19. Dec 19, 2018 at 7:10 PM
    #49
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Any of you guys with this issue notice when the right turn signal turns off, the left turn signal turns on for split second?
  20. Dec 20, 2018 at 7:30 AM
    #50
    prlauren
    prlauren New Member
    No. Not for me. Right turn signal then it’s lights out.....but randomly.
  21. Dec 20, 2018 at 8:34 AM
    #51
    pdiddy
    pdiddy New Member
    2017 platinum
    not me
  22. Dec 21, 2018 at 8:48 AM
    #52
    JoelTundra2015
    Joel Kennison
    POSSIBLE FIX FOUND
    Good Morning Everyone, Well my Toyota dealer worked with Toyota Engineering and they have claimed to have found a resolution to our problem. Time will tell of course but this is the part which was replaced on my 2015 Toyota Platinum Tundra:
    Part:
    1 84140-0C081 SWITCH ASSY HEADLAM
    Joel
    pdiddy likes this.
  23. Dec 21, 2018 at 9:00 AM
    #53
    JoelTundra2015
    Joel Kennison
    This is what my Toyota Report says
    CAUSE:
    DIAG DIAGNOSIS
    8232 WT
    39043 INTERMITTENT OPEN CIRCUIT 1.50 PERFORMED INSPECTION OF HEADLIGHTS AND DASH LIGHTS GOING OUT WHEN USING TURN SIGNALS. INSPECTED FOR AFTERMARKET EQUIPMENT. NO AFTER MARKET PARTS INSTALLED. CUSTOMER HAD THIS CONCERN AT MILEAGE 30356. RO #704602. CUSTOMER CONCERN WAS NOT DUPLICATED AT THAT TIME AND NO REPAIRS MADE. OPENED TAS CASE #183520215 AND SPOKE WITH TAS AGENT. TAS AGENT ADVISED TO REPLACE HEADLIGHT SWITCH WITH UPDATED PART. PER TAS AGENT REPLACE HEADLIGHT SWITCH ASSEMBLY. ADVISE CUSTOMER TO DRIVE AND MONITOR.
  24. Dec 21, 2018 at 9:02 AM
    #54
    prlauren
    prlauren New Member
    It’s not a fix. Just a temporary fix by replacing the headlamp signal stalk switch with the part that’s already the problem. I will upload the parts breakdown from my database.
  25. Dec 21, 2018 at 9:05 AM
    #55
    prlauren
    prlauren New Member
  26. Dec 21, 2018 at 9:16 AM
    #56
    JoelTundra2015
    Joel Kennison
    You have replaced all of those parts and it still happens?
    Joel
  27. Dec 21, 2018 at 9:50 AM
    #57
    prlauren
    prlauren New Member
    I just replaced the ambient headlight sensor. Next I was going to change headlamp switch. I’m almost positive it’s the switch. But I only have 18,000 miles on my truck. This problem with the lights started at 17,000 miles. Usually if a part designed for a vehicle has a new part # it supersedes the old then it’s an updated part. I don’t think I want to replace the headlamp switch with the same switch that I’m taking out with the very same part number. Makes no sense. The problem is not fixed.
  28. Dec 31, 2018 at 10:30 AM
    #58
    COMNT
    COMNT New Member
    2017 Tundra Platinum
    You can add me to the list as well. Glad to see there might be some traction on this issue. My 2017 Platinum has the same issue and it doesn't matter if it's in auto or manual. I too do not have any aftermarket add ons. My dealership was supposed to reach out to Toyota, but haven't heard back yet. Thanks for all the updates on this!
  29. Jan 3, 2019 at 8:07 AM
    #59
    Meplusthree
    Meplusthree New Member
    2014 Toyota Tundra 1794 edition
    My 2014 1794 Edition is doing the same thing. I too have no aftermarket add ons. The first time this happened was in October and the temperature was above 65 degrees so it doesn’t seem to be just when it is cold. I plan on calling my dealership today to give them the info I found here.
  30. Jan 8, 2019 at 7:16 AM
    #60
    COMNT
    COMNT New Member
    Left my truck with the dealer Friday and the QC manager drove it home over the weekend. He was able to replicate the headlights cutting out and they contacted Toyota and got approval to replace what parts they think are bad. I'm supposed to have my truck back on Friday, I'll update everyone with the list of parts they replace. Hope it solves the issue.
    pdiddy likes this.
