Audio Upgrade Recommendations
Discussion in 'Audio & Video' started by Fenway9999, Feb 11, 2020.
  1. Feb 11, 2020 at 11:52 AM
    Fenway9999
    Fenway9999 [OP] New Member
    2019 Toyota Tundra
    Hi All. New to the forum. I have a 2019 Tundra Crewmax that I plan to upgrade the audio system. Most likely will keep the HU, but looking for the best "kit" to purchase for the speakers, amp, sub, and wiring harness. I see a lot of people seem to use ********* or Tech12 so I will look at both, but any other recommendations would be appreciated.
  2. Feb 11, 2020 at 11:59 AM
    AZBoatHauler
    So.Arizona
    Welcome to the forum. I just did a full upgrade through James at Tech12Volts and could not be happier with the result. James was as helpful as everyone says he is and shipping was timely. His price on equipment cannot be beat as he includes all the extra pieces you will need. I removed HU, amp, and every speaker and replaced with a Kenwood HU, and a JL Audio package for speakers, subs, and amp.
    Do yourself a favor and watch lots of YouTube tear-down/install videos to make the installation go as smooth as possible.
  3. Feb 11, 2020 at 12:04 PM
    Fenway9999
    2019 Toyota Tundra
    I did send an email to James, but no reply yet. Does the Kenwood HU you chose have the full capabilities of the stock unit Toyota puts in the vehicles?
  4. Feb 11, 2020 at 12:06 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Check out Crutchfield.com as well. They have a good customer support service as well.
  5. Feb 11, 2020 at 12:10 PM
    AZBoatHauler
    So.Arizona
    I chose a HU that does not have a CD/DVD slot so I lost that ability. In 3 years, I never once put a disc into my Entune unit. Otherwise, when setup with a Maestro RR module you will have access to everything you had before and more in terms of viewing system info and changing settings. If there a particular function you are concerned about losing? The only thing I miss is having a roller knob for volume control but the benefits of the new HU far outweigh that minor issue.
  6. Feb 11, 2020 at 12:17 PM
    Fenway9999
    2019 Toyota Tundra
    I could care less about CD slot actually, as I am the same as you and never use it. More concerned about the dash board interface and keeping it a clean look as well as keeping my Sirius/XM capabilities.
  7. Feb 11, 2020 at 12:28 PM
    AZBoatHauler
    So.Arizona
    All of that functionality is maintained except you will no longer get navigation prompts on your steering wheel micro-display. There is an adapter module for XM to work with your new HU. Here is a pic showing how it looks installed with the Scosche dash kit -
  8. Feb 11, 2020 at 12:34 PM
    Fenway9999
    2019 Toyota Tundra
    Looks fantastic. Maybe I will think about the HU upgrade as well......
    When I get hold of James I will have to ask for a system with and with out the HU change and figure out what I want.
