Audio system upgrades
Discussion in 'Audio & Video' started by Tankkiller308, May 23, 2018.
  1. May 23, 2018 at 8:28 PM
    Tankkiller308
    Tankkiller308 [OP] New Member
    Louisiana
    2018 blazing blue TRD tundra
    Done: Remote start, Pocketed Fender Flairs, Audio system upgrade, DV8 bumper Pending: Exhaust Cutouts, cold air intake, Color matched Grill insert, Warn Zeon 12k, Duel battery, long tube headers, cab high cover
    Im getting a new 2018 tundra (supposed to have delivered a week ago and is still sitting in huston) and im often making 10 hour drives by myself so one thing right away im upgrading the audio system. So what im looking at is a pioneer 4200next with maestro to compliment a sub system (undecided as i hate too loose all the storage under the seats). Is there any functionality that i would loose? Is the upgrade worth it audio wise and is it hard to install properly?
  2. May 23, 2018 at 8:54 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA....
    Norfolk757 likes this.
  3. May 23, 2018 at 10:15 PM
    Welcome from Texas
  4. May 24, 2018 at 3:21 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    I recommend placing the sub or subs behind the back seats. Since the back seat doesn't fold down you don't lose any storage really. And because they don't fold down it's almost like an extra layer of security if you truck is ever broken into since someone doing a smash and grab wouldn't be able to get to the sub/s without removing the back seats. Here is the company I went with and some example of enclosures:
    https://www.shop.tech12volts.com/category.sc?categoryId=125
    ********* has some similar enclosures.
    I had originally only planed on getting one sub myself but since there was no real loss of storage behind the seat and the enclosure for 2 subs was close or the same as a single, and one more sub was only going to be $130-$150 more, I went with 2 and I am glad I did. By having 2 subs and with a bass volume level knob installed, I have complete control of the amount of bass being heard. While I don't drive around blasting the bass as loud as possible all the time, on certain songs that have a nice bass line I can turn up the bass and jam then turn it back down when that song is over.
  5. May 24, 2018 at 5:10 AM
    Tankkiller308
    Louisiana
    I was worried about behind the seats as there is not much room back there but hay if someone has already done it then i should be fine, did you do two 10s or two 8s?
  6. May 24, 2018 at 5:32 AM
    Cfincke
    San Antonio
    2 10" subs in box behind the back seat of a 3rd gen crewmax
  7. May 24, 2018 at 5:36 AM
    Tankkiller308
    Louisiana
    Nice, where did you mount the amp, and is that a custom box or do you have a reference company you use.
  8. May 24, 2018 at 5:39 AM
    Cfincke
    San Antonio
    The box and subs I ordered from tech12volts. The sub amp is under the driver seat and my door speaker amp is under the passenger seat.
  9. May 24, 2018 at 5:41 AM
    Tankkiller308
    Louisiana
    I will have to give them a try, did you keep the stock head unit?
  10. May 24, 2018 at 5:45 AM
    Cfincke
    San Antonio
    Yes I kept the JBL entune head unit. Have a JL fix86 processor because of the JBL stock system is horrible. I actually have a new processor arriving tomorrow that will replace the fix86 and allow me to remove the stock amp as well.
    smslavin likes this.
  11. May 24, 2018 at 5:49 AM
    Tankkiller308
    Louisiana
    Hallelujah, i didnt think there was a fix for the stock head unit The low quality audio was the reason i wanted a new head unit.
  12. May 24, 2018 at 6:10 AM
    Cfincke
    San Antonio
    Do you have the JBL entune system or the regular entune system? If you have the regular system, it is even easier to upgrade.
    For the regular system, you can remove the factory amp and you are not required to install a processor.
    For the JBL system, the factory amp has to remain even if you have an aftermarket amp to power the door speakers. The factory amp does not produce a good signal, so a processor is required to produce a flat full range signal.
    The new processor I have coming tomorrow is brand new and has built in functions that will finally allow the removal of the factory JBL amp while allowing me to keep the factory headunit.
    Note: there is a huge difference between actual JBL equipment and the JBL branded Toyota stuff.
  13. May 24, 2018 at 6:26 AM
    Cfincke
    San Antonio
    Pudge likes this.
  14. May 24, 2018 at 6:37 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    what did you get?
    @Tankkiller308 i will write up some info later today.
  15. May 24, 2018 at 6:44 AM
    Cfincke
    San Antonio
    Ordered this and the corresponding wire harness: http://maestro.idatalink.com/product/product/product_id/574
    "Maestro/Rockford Fosgate 8 channel digital signal processor. The DSR1 combines the legendary Rockford 3-SIXTY processor and Maestro AR to simply replace many factory amplifiers."
    smslavin[QUOTED] likes this.
  16. May 24, 2018 at 6:45 AM
    ZPMAN
    Minnesota
    I am no audio expert but the sound improvement i got from just a head unit from Phoenix Android was money well spent over the stock JBL system.
  17. May 24, 2018 at 6:55 AM
    ZPMAN
    Minnesota
    Has anyone ever tryed to modify a stock JBL head unit? Or from what I've heard, see what was changed from the older (2013) systems?
  18. May 24, 2018 at 6:58 AM
    Tankkiller308
    Louisiana
    Thanks everyone, i have the system that comes with the TRD package which i have been told is the second of three tiers (getting any information has been a crap shoot about what it is or isnt). I was told it was the head unit and now the amp, lol. Ill have to swap amps when i add the sub amp see if it does the trick.
  19. May 24, 2018 at 7:07 AM
    Beerdude77
    I have the Non JBL system so I don't know if that makes a difference or not, but when I ordered my amp, subs/box from tech12 I asked about the fix86, he said I didn't need one because my amp (JL RD900/5) already had speaker level input and the 86 didn't clean the signal up. He said I would need some sort of digital sound processor to do that. When I started pricing those out I found they were not much cheaper than a new head unit. I really wanted Android auto also so I chose to upgrade the head unit to clean up the sound and gain Android auto. I'm very glad I did now even though it cost more
  20. May 24, 2018 at 7:14 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You probably have the Entune Premium then, which is good.
    I'm a little late to the party, and everyone has laid out some great information. I'd recommend getting in contact with James at tech12volts (there's an email address on his website), and let him know what you have in mind and he will give you a good price on it.
    As far as keeping the head unit or removing it....its up to you. I wanted to keep the factory look and still have a baller stereo so i kept the stock head unit and added a fix86 (link to my build in my signature).
  21. May 24, 2018 at 7:21 AM
    Tankkiller308
    Louisiana
    Im thinking ill be going with the fix86 then, and ill shoot him an email later today, im sitting in the dealership rn trying to figure out why my truck is 8 days past ship date when it was done on may 6th. Soon as i get it ill be ordering my stuff. Still gotta figure out what subs to slide in the box but i think ill be good to go
  22. May 24, 2018 at 7:29 AM
    Danimal86
    Daniel
    Sacramento, CA
    What speakers and amp are you thinking of going with?
    The jl 10tw3's are a good option for subs. I went with the jl stealth box that has two of them and the thump!
  23. May 24, 2018 at 7:35 AM
    denverd1
    denverd1 New Member
    East Texas
    2014 1794 Super White 4x4
    3/1 lift, rims and tires
    any way to shove a 12" or 2 behind the back seat? Not opposed to moving the seat forward a bit, shouldn't be too hard to fab up. especially since there's a mile of room back there!
  24. May 24, 2018 at 7:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    You can fit 2 12's behind there no problem....assuming they are shallow mounts.
  25. May 24, 2018 at 7:46 AM
    Tankkiller308
    Louisiana
    Im not sure what subs i was gonna poke around the forums too see what everyone was using. I was going to try sticking my alpines from my old f-150 in there but it doesnt fit.
  26. May 24, 2018 at 7:49 AM
    denverd1
    denverd1 New Member
    East Texas
    Have shallow mounts improved SPL? I haven't heard a thin vs regular side by side with similar power, but always just assumed they'd be sub par vs a regular sub.
    I'd really prefer a 12" vs 10 or 8. but I suppose a few well powered traditional 8"s could work.
  27. May 24, 2018 at 8:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    Fords usually have 6x8's....is that what they are? I ran 6.5" components in all the doors, just have to get speaker adapters.
  28. May 24, 2018 at 8:05 AM
    Cfincke
    San Antonio
    I have JL 10w1 subs. I could not afford the price of the 10tw3. 12s can fit behind the seat, just have to be shallow.
  29. May 24, 2018 at 8:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    Mine sound great. combined, they are rated for 800rms, i'm only putting probably 400rms to them and its enough to shake my side mirrors with the windows down.
    I wouldn't go with 8's. Get 10's if you listen to everything, 12's if you listen to a lot of rap.
  30. May 24, 2018 at 8:15 AM
    denverd1
    denverd1 New Member
    East Texas
    I would normally agree with you, but got a friend with a 3 or 4 8s and his truck pounds. Not sure of his power setup. 10's rumble, 12's hit hard. No rap, but do like some EDM occasionally. leaning toward shallow 12's
