Audio assistance needed please
Discussion in 'Audio & Video' started by HoppyEOD, Oct 2, 2019.
  1. Oct 2, 2019 at 4:04 PM
    HoppyEOD
    HoppyEOD [OP] New Member
    2019 TUNDRA SR5
    Hello first post/question yall.
    Im upgrading from factory sound sytem. Keepin head unit and replacing everything beyond it. Ihave hit a snag. Looking at posted pin outs feom factory amp, i see the colors of my wires do not match what is posted.
    I am trying to go from factory amp to sound processor to aftermarket amps.
    Does anyone have a real and true pinout from the factory amp? I could really use the assistance. Any advice appreciated.
    2019 Tundra SR5 4X4
  2. Oct 2, 2019 at 4:10 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Some searching will likely convince you to replace the factory amp. Search for OEM Audio Plus, Tech12Volts and Taco Tunes here on the site. Those are the main three people use. FYI, I'll be going the OEM Audio Plus route for my next mod.
  3. Oct 3, 2019 at 6:24 AM
    FUBAR
    FUBAR New Member
    2019 Tundra TRD crewmax
  4. Oct 3, 2019 at 6:34 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I just finished my upgrade at the end of August or so.
    Question - do you have the JBL system? Going to assume "NO" since its an SR5.
    I have a 2016 SR5, non jbl
    If you DO NOT have the JBL system, you do not need the factory amp, just remove it and use the sound processor and the other amp and you should be fine. since I just finished mine, I can assist the best I can just shoot me a PM and I will try.
  5. Oct 4, 2019 at 6:24 PM
    HoppyEOD
    2019 TUNDRA SR5
    Not to sound like an idiot but, how do I PM. Yeah, i know sad but i can explain
  6. Oct 4, 2019 at 6:44 PM
    purplenova
    Tom
    Ohio
    Top right - inbox - start new conversation
  7. Oct 4, 2019 at 6:49 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Post #11
    https://www.tundras.com/threads/supes-2018-mgm-sr5-cm-sport-build.38149/
  8. Oct 7, 2019 at 12:32 PM
    purplenova
    Tom
    Ohio
    Check your inbox -sent you a PM .
