Auburn Pro Series LSD
Discussion in 'Performance and Tuning' started by Stevie442, Sep 22, 2018.
  1. Feb 14, 2020 at 2:24 PM
    #91
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Yup. Saving for this...
  2. Feb 14, 2020 at 3:16 PM
    #92
    ZPMAN
    Minnesota
    You just need a cheep digital caliper for shimming a dial Indicator for backlash and a 1/4" 0 to 80 in/lbs spring steel beam tourq wrench for setting pinion bearing preload. For the front diff I had to make a special tool for setting the back lash because you have to measure it through the oil drain hole. You could get all the tools for $100 to $200.
    Hbjeff[QUOTED] likes this.
  3. Feb 14, 2020 at 3:30 PM
    #93
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    DOn't need to worry about the pinion bearing or pinion shims if not changing gearing.
  4. Feb 14, 2020 at 5:52 PM
    #94
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What I want is a durable street-friendly limited slip.
    Saltyhero13, NE_WARRIOR and MS22 like this.
  5. Feb 14, 2020 at 6:54 PM
    #95
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Surprised Torsen hasn't released anything for the 10.5. They seem to supply Toyota/Lexus LSDs for some time now. My ISF Torsen was awesome and plan on picking one up for my wife's IS350 here shortly.
    Hbjeff likes this.
  6. Feb 14, 2020 at 8:00 PM
    #96
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    I have not found that, been looking too...
  7. Aug 12, 2020 at 4:56 AM
    #97
    Rex Kramer
    Georgia
    This is the first vehicle that I have owned with any sort of computerized traction control, so I have another question.
    Do I need to turn OFF the VSC / LSD in order for the Auburn PRO to work properly?
  8. Aug 12, 2020 at 7:07 AM
    #98
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Yes is the most comprehensive answer. Meaning, stock with no computers, your truck will be simply an open diff, and with the Auburn without computers you will solely be relying on the Auburn for slip control.
    The other side to that is if the Auburn is doing it's job and not letting the tires break loose, then, with nannies on, the computer won't sense a slip and you still move forward.
    I would always turn the computer off if you want the most driver interaction/control.
  9. Aug 12, 2020 at 5:54 PM
    #99
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Im just thinking out loud, but the auto lsd can only help the auburn i think
    most situations, the auburn will maintain traction and the auto lsd will never kick on.
    now if you get some slippage, the auto lsd will control that tire and allow the auburn another chance
  10. Aug 12, 2020 at 6:57 PM
    #100
    Rex Kramer
    Georgia
    I have been researching the installation of an LSD in my 2007... I have a Kazuma/TRD LSD in my 2002 and love it. Auburn Gear makes an LSD for 2nd Generation Tundra trucks, but I found the information available online was inconsistent - so I reached out to Auburn Gear.
    I think you will find the answers to my questions interesting....
    I asked what gear oil they recommended:
    We recommend an 80/90 wt. NON-Synthetic oil which we offer, p/n 504107, and our additive, p/n 504102. The additive comes with our units when purchased new.
    We do not recommend any type of synthetic oils, TransX additive or any oils that already have an additive in them. I also do not recommend Lucas. All of these will cause noise that can be severe in our units because of design.
    I asked why I could no longer find a Pro LSD for the Tundra:
    We only offer this in the High Performance. It will be as good as the Pro considering the size of this unit and strength to begin with. The biggest difference between the HP and the Pro is spring load.
    I asked about the different spring loads:
    We never offered the Pro Series for the 2007 and up Toyota Tundra.
    Spring Pre-Load H.P. Series 840 lbs.
    Spring Pre-Load Pro Series 1800 lbs.
    BlueTundra2019 likes this.
  11. Aug 18, 2020 at 10:47 AM
    #101
    Rex Kramer
    Georgia
    What are the OEM part numbers for the carrier bearings, shims and whatever else is needed to install an LSD?
  12. Aug 18, 2020 at 10:48 AM
    #102
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you’re just changing the diff shouldnt all the shims stay the same? The pinion shim wont be un done so thats good.
    I just bought an auburn for my 2wd ill look for install soon
  13. Aug 18, 2020 at 10:52 AM
    #103
    Rex Kramer
    Georgia
    I have read that you should replace the carrier bearings, because they tend to break when removed.
    I also just ordered an Auburn, so I am researching what I need to install it correctly.
    Hbjeff[QUOTED] and TX210Tundra like this.
  14. Aug 18, 2020 at 12:54 PM
    #104
    TXTundra2722
    2015 Black Tundra
    I just bought it all from nitro gears. 5.29 master kit (everything needed and included) and the Auburn pro
    Rex Kramer and Ckatz53 like this.
  15. Aug 18, 2020 at 2:30 PM
    #105
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    That's very interesting since I have a Pro for mine. I purchased from justdifferentials.com along with carrier bearings. The part was AG5420134-PRO. I used Auburn additive with Valvoline non-synthetic 80w-90 as recommended. They also recommend 7,500 mile diff oil changes which the mechanic who installed it and I thought was a little excessive since I don't romp on it. I did it at 15k, and no issues. Still locks up when I have tested it on dirt.
    Rex Kramer[QUOTED] likes this.
  16. Aug 21, 2020 at 2:51 PM
    #106
    Rex Kramer
    Georgia
    4 quarts?
  17. Aug 27, 2020 at 12:07 PM
    #107
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Yep rear seemed to take under 4 every time I refilled it in my regear debacle.
  18. Mar 7, 2021 at 5:53 AM
    #108
    Rex Kramer
    Georgia
  19. Mar 7, 2021 at 5:58 AM
    #109
    Rex Kramer
    Georgia
  20. Mar 7, 2021 at 6:09 AM
    #110
    Rex Kramer
    Georgia
    I'm not sure, but it sounds like multiple names for one LSD.
  21. Mar 7, 2021 at 8:43 AM
    #111
    fishmando
    fishmando New Member
    Sweet I see the moderators took down all my content in this thread...
  22. Mar 7, 2021 at 8:50 AM
    #112
    fishmando
    That's what I was afraid of, while I contemplate ordering a second one.
  23. Mar 8, 2021 at 11:29 AM
    #113
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
  24. Mar 9, 2021 at 5:37 AM
    #114
    fishmando
    Yes to CONFIRM, this is the same exact PN I got from Just Differentials, my failed unit was from February 2018
  25. Mar 9, 2021 at 5:38 AM
    #115
    fishmando
    Also, enjoy the hell out of the 5.29s - the single best mod for these trucks IMO!
  26. Mar 9, 2021 at 6:48 AM
    #116
    Downytide
    GTA
    Did you reach out to them or Auburn to see if there's any warranty claim? or would they repair it for you?
    I'm excited for the 5.29, the headers already did wonder to the truck so can't wait for the gears to be installed and broken in.
  27. Mar 9, 2021 at 6:56 AM
    #117
    fishmando
    The moderators deleted most of my posts, but yes Auburn was actually awesome about the warranty situation.
  28. Mar 9, 2021 at 6:58 AM
    #118
    Downytide
    GTA
    Good to hear Auburn stood up for it, I don't do any or much rock crawling, so I figure I should be ok with Auburn for now.
  29. Mar 10, 2021 at 4:18 PM
    #119
    fishmando
    Mine went in 2.5-3k miles of street driving! But they did test it and confirm that there was an obvious assembly error. That being said, most folks who drive their trucks daily get about a year out of them.
