Auburn LSD question
Discussion in 'Performance and Tuning' started by Broncobroke, Jan 30, 2018.
  1. Jan 30, 2018 at 5:22 AM
    Broncobroke
    Broncobroke [OP] Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    This has probably been beat to death but i am going to ask anyway. I am getting ready to pull the trigger on one for 2017 Tundra. Is there a down side to having one? I can't see one.
  2. Jan 30, 2018 at 5:29 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What exactly are you looking for as far as performance out of a mechanical LSD? Basically I'm asking why are you looking at getting an Auburn LSD.
    Do you have aftermarket Wheel and Tire larger Tire setup?
  3. Jan 30, 2018 at 5:56 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Tagging in for info. Waffling between ARB air locker or Auburn LSD for the next 'big' mod. :)
    Sunnier likes this.
  4. Jan 30, 2018 at 5:56 AM
    Broncobroke
    Charlie
    Piedmont, NC
    My last Tundra was an 06 which had lsd. I am planning a 3" lift but have not decided on brand yet. I do not do hard core off road driving, however I do spend a lot of time in deep sand and old logging roads and forestry roads. At some point in time I am considering an arb for the front. Just wondering if there is a down side to the Auburn.
    Sunnier likes this.
  5. Jan 30, 2018 at 6:17 AM
    Broncobroke
    Charlie
    Piedmont, NC
    Please tag along. Several guys on here have Auburn in the rear and ARB in the front. Seems like a great combinaHaving had numerous old Bronco's I like to think that I have learned a few things (Obviously not). Just trying to keep something from biting me in the arse down the road. Nowatamean?
    Black Wolf, ColoradoTJ and Wrongside like this.
  6. Jan 30, 2018 at 6:46 AM
    The only downside to a mechanical limited slip is it should have came from the factory equipped with one on a Tundra and it will cost you some money getting it upgraded.
    Toyota would have had the perfect truck in my book. I would still give it a 90/100 though.
    Deep sand and logging roads....sold! I would be buying one ASAP.
  7. Jan 30, 2018 at 8:22 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Is the auburn an auto lock or manual/air lock?
  8. Jan 30, 2018 at 8:25 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I seem to remember reading that it’s not exactly recommended to do an front air locker on an IFS vehicle. I could be wrong though.
  9. Jan 30, 2018 at 9:15 AM
    Broncobroke
    Charlie
    Piedmont, NC
    The Auburn is a limited slip differential. If the ARB is a problem with IFS then I wouldn't do it. I'll save that for another thread. Just trying to see if there are any downsides to doing this mod with the Auburn. I can't think of any with my limited knowledge.
  10. Jan 30, 2018 at 9:18 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t see any downside with the Auburn in the rear. Other than it’s not a true locker if you ever really needed it. I think my ultimate would be an ARB rear locker with an Auburn in the front.
  11. Jan 30, 2018 at 9:38 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    The only downside to my Auburn is it's still in the box downstairs. Two trucks later and I haven't installed it. :notsure:
    Black Wolf, aperezsh, Sunnier and 3 others like this.
  12. Jan 30, 2018 at 9:50 AM
    Broncobroke
    Charlie
    Piedmont, NC
    That sucks. Probably gone out of style :)
    Sunnier and AxelsHumanDad like this.
  13. Jan 30, 2018 at 10:05 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't think there's a downside other than expense. For hard core wheeling maybe a locker is better. But lockers don't work well on snowy, icy roads and the lsd will shine.
    SoCal619, joonbug and AxelsHumanDad like this.
  14. Feb 1, 2018 at 7:25 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I found the auburn part number for the rear LSD. Anyone know the number for the front?
  15. Feb 1, 2018 at 8:47 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    there is none
    zcarpenter92 likes this.
  16. Jun 19, 2018 at 9:25 AM
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    Perfect setup manual locker in the rear and LSD up front. I die more each day no one comes out with a front LSD.
    15whtrd[QUOTED] likes this.
  17. Feb 6, 2019 at 5:19 PM
    fishmando
    fishmando New Member
    I've got a Q. I have an auburn and with Nannies turned on it always seemed to eventually grab on both sides. Now I'm trying to drive with the Nannies all the way off, if my front tires get into the snow going up my driveway, and my rear gets on the icey sidewalk, I can stand there and burn rubber with one tire (unintentionally!) anyone else having issues getting your auburn LSD to lock up?
  18. Feb 7, 2019 at 3:24 AM
    muisejt
    muisejt New Member
    clutch pack is worn out I'd say
    15whtrd likes this.
  19. Feb 7, 2019 at 4:54 AM
    timsp8
    NY
    I don’t know a lot about it, but to test it could you jack up the rear and try to spin a tire to see if they both spin the same way? I think if they do it works and if not something is wrong.
    15whtrd likes this.
  20. Feb 7, 2019 at 7:35 AM
    fishmando
    I would think, but it's got 3k miles on the thing!! Thanks for the response
  21. Feb 7, 2019 at 7:35 AM
    fishmando
    Wow, I never would have thought of that. Here I am doing burnouts on ice as a test. I'll try that!
    BabyBlackYota likes this.
  22. Feb 7, 2019 at 8:33 AM
    muisejt
    muisejt New Member
    both wheels should be spinning together all the time so something is wrong with it or you don't have an Auburn LSD.
    15whtrd likes this.
  23. Feb 7, 2019 at 5:47 PM
    timsp8
    NY
    Does it have a failsafe where if one tire goes from stationary to spinning really fast the lsd doesn’t engage so it doesn’t tear up? Seems like it would be hard on the differential if one is spinning really fast and it tries to engage. Or maybe it’s like 4wd and just takes time to get everything lined up to engage.
  24. Feb 7, 2019 at 5:55 PM
    What's being left out here is that the "auto LSD" with our trucks that is a selling point for Toyota....SUCKS. The Auburn Gear LSD is a huge improvement. Of course the ARB locker would be ideal depending on your use. The best solution would be for Toyota to have standard on the next true gen Tundra.....................Eaton Detroit Locker....hands down......
    Joe Dirt likes this.
  25. Feb 7, 2019 at 8:57 PM
    muisejt
    muisejt New Member
    It's always engaged but allows some slippage so the wheels can turn at different speeds when going around a corner
  26. Feb 8, 2019 at 7:35 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    When youa accidentally spin just one tire with an Auburn it’s ruined forever.
    When you first get an Auburn it’s nice n tight. After you play with it for a while it wears out and get very loose. And less fun:(
    My Auburn’s usually are fun and tight for about 2 weeks. Then just going around a corner in the rain results in a one tore fire.
    They don’t last very long.
  27. Feb 8, 2019 at 11:56 AM
    fishmando
    WTF! Are you serious! You just broke my heart, the labor on these (installation + master rebuild) is nothing to laugh at. If you aren't yanking my chain, than mine is f*cked and I've only had it for 10 months!
    15whtrd likes this.
  28. Feb 8, 2019 at 11:56 AM
    fishmando
    Man I'm so bummed right now...
    15whtrd likes this.
  29. Feb 8, 2019 at 12:05 PM
    15whtrd
    15whtrd Mr. Blonde
    No shit. I had a limited slip in my Dodge that stayed tight for a long time. And I used that thing. Sounds like an auburn is a inferior design. Why even bother putting it in at that point. I’d rather let the computer figure it out or spend real money on an air locker.
  30. Feb 8, 2019 at 2:53 PM
    timsp8
    NY
    I had one in my old 2010 with a supercharger and it lasted me for years. Still worked good after running it hard on the street with the sc. can you explain how it’s done after only 2 weeks?
