Auburn LSD or ARB Air Locker?
Discussion in 'Performance and Tuning' started by Cuzin Eddie, Feb 16, 2017.
  1. Feb 16, 2017 at 8:59 AM
    Cuzin Eddie
    Cuzin Eddie [OP] New Member
    Shane
    2014 CM Black Platinum 4X4
    TRD Supercharged * BDS 4.5 level with Fox Shocks * AMP running Boards * Bed Rug, Spyder Headlights with HID Conversion * 46 Gal TransferFlow Fuel Tank * Fuel 2 Piece Hostage Wheels * 35" Toyo RT's * Backflip Bed Cover * Pioneer Avic NEX8200 with Amp, Speakers & Subs * Trailer Tow Mirrors * N-Fab Bumper Bar with 30" Vision LED Light Bar *
    Anyone have any experience with these? I spoke to Keith and he has pointed me towards the ARB. Is there anyone that regrets the Auburn????
  2. Feb 16, 2017 at 9:02 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Never had the auburn, but I've had many ARBs in my life. I highly recommend them. It depends on your intended use for the truck. The lsd is a set it and forget it type thing. The ARB you'd have to turn on/off and plumb airlines. Although, you could get on-board air if you went ARB.
    Black Wolf and ColoradoTJ like this.
  3. Feb 16, 2017 at 9:13 AM
    Cuzin Eddie
    Shane
    Keith has had experiences with glazing the clutches in the Auburn....I don't want that happening!!! I just want traction when it is needed. Would love to hava the diff locked to hook up better with the Supercharger.
    ColoradoTJ likes this.
  4. Feb 16, 2017 at 10:26 AM
    Being SC'd, go ARB. Keith is giving you solid advice. Careful locking the ARB on the street. Essentially you just made a spool. Drag racing is fine, just don't lock or unlock under hard throttle.
    It is a shame Yukon Zip lockers are not available for the Tundra. That is how I would go if available. Best warranty on the locker/broken parts (2000.00).
    Joe Dirt and Wynnded like this.
  5. Feb 16, 2017 at 10:50 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Go ARB, you can't turn off a LS if you get into a situation where it could be hampering you.
  6. Feb 16, 2017 at 11:21 AM
    Cuzin Eddie
    Shane
    And I will be putting the 4.88 gears in it at the same time. I will go ARB!!!!
    aperezsh, tat2ude39 and ColoradoTJ like this.
  7. Feb 16, 2017 at 1:29 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    These are two different animals that's for sure.
    It boils down to what you are using the truck for, having a LSD Auburn would be the best for daily driving in all weather, sometimes having the rear locked would not be a good idea, example: icy situations where you would need that slip to happen like going around a corner and you wouldn't want the rear end to kick out or hitting a patch of ice going down the road and having a potential of kick out. The LSD is designed to slip in situations like that so an accident does not happen.
    The ARB locker engages the rear end to be locked at all times until disengaged which would be better for offroading and needed that extra grip to get out of that hairy situation.
    Both are super solid options and have pros & cons.
  8. Feb 16, 2017 at 4:12 PM
    Cuzin Eddie
    Shane
    Isn't true though...if you spin your tires too much that it can glaze the clutches in the LSD and make it basically useless?
  9. Feb 16, 2017 at 4:25 PM
    I would look at what the LS is rated for. Some of the SC guys haven't had long term luck with the LS
  10. Feb 16, 2017 at 4:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If you abuse something, by say "spin your tires too much", then it will break. Always pick the right tool for the job.
    T-Rex266 and ColoradoTJ like this.
  11. Feb 16, 2017 at 5:08 PM
    http://www.tundraheadquarters.com/blog/the-auburn-pro-lsd-for-the-toyota-tundra/
    There are cone style clutch mechanisms, but not like a posi-trac or a clutch material.
    Here is the G80 locker in the back of my GMC HD. It has clutch mechanisms.
    http://www.eaton.com/Eaton/ProductsServices/Vehicle/Differentials/mlocker/index.htm#tabs-4
  12. Feb 16, 2017 at 5:30 PM
    Cuzin Eddie
    Shane
    Don't get me wrong....I DO NOT beat my truck!!! But it will be a long cold day in heck before I let some jelly burner or even worse a Titan out run my little Black Beast! Oh and don't forget the Ecoboosts...crap my Brother In Law thinks his walks on water! And I use to be a General Manager of a Ford dealership for almost 10yrs.
  13. Feb 16, 2017 at 5:31 PM
    So looking at the Auburn, the cone style clutch engages in the differential housing....from what I can see. Kinda crappy these only have 1 year, 12K mile warranty and cannot be rebuilt.
    Looking at the ARB, they now have a 5 year warranty. Not bad if you ask me. I have damaged an ARB before, and parts are available for rebuilding/fixing. The extra money sucks, but I would rather have the best for what is offered.
    J4RR3N4 and AxelsHumanDad like this.
  14. Feb 16, 2017 at 6:30 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    One of the reasons mine is still new in the box downstairs and not in the truck.
    I know many could jump in and say they have many tens of thousands of reliable miles on them. I just backed away from putting that much effort into something that might not last as long as the truck.
  15. Feb 16, 2017 at 6:32 PM
    For a stock power truck, I would doubt you would have an issue for many years.
  16. Feb 16, 2017 at 7:34 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    The ARB air system and lockers are high, high on my want list. Please update with what you decide on!
  17. Feb 16, 2017 at 10:30 PM
    Don't get me wrong, ARBs have issues as well. Some of mine over the years, and I have owned 6 in different axle applications:
    -air lines crimped, burnt, cut. Make sure you have a splice with you at all times. I also left plenty of line in a coil under the vehicle (zip tied up) so when something happened, it was a quick fix.
    -solenoids going out. Carry a spare.
    -fuses for your system
    - had a compressor seal go out once and wouldn't build air pressure. The o-ring was bad. Lucky for me, I was running a D44 with lockout hubs. The o-ring seal for the hub fit nicely on the compressor. I just left it since it worked so well.
    - using your ARB compressor to air up tires should be an emergency application only. To air up a 35" tire from 10-13 psi to normal operating pressure would take forever on just one tire. One can literally order a pizza and eat it before all 4 tires are aired up.
    - O-ring going from copper tube into ARB can leak. That blows.
    Drill and tap the differential housing. This is actually very easy to do. Just keep in mind where it needs to be and clearances.
    Currently, I don't run any air lockers and been very happy with that decision, but my rig is off-road only.
    Wrongside and GNTundra like this.
  18. Feb 17, 2017 at 5:07 AM
    Glock17
    Glock17 New Member
    Helena, Al.
    2016 TRD PRO
    Fab Four bumpers, Warn Zeon 10, Line X, Toytec lift, Rugged Tri fold cover, Cooper SST, Weathertech liners, Weathertech vent guards
    I take an aubarn around six every morning.
  19. Feb 17, 2017 at 5:27 AM
    Proctologist time
  20. Feb 17, 2017 at 7:37 AM
    Toytec Lifts
    Denver, CO.
    Haven't had any issues with ours :spy:
    jc153 and T-Rex266 like this.
  21. Feb 17, 2017 at 7:45 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Might want to wait till March 1 for the ARB :spy:
  22. Feb 8, 2019 at 12:56 PM
    fishmando
    fishmando New Member
    False, mine it toast with stock power 35s and under 4k miles on it :D (Auburn Pro Series)
    pearlpower likes this.
  23. Feb 8, 2019 at 2:06 PM
    I wouldn’t say that’s normal. Definitely an exception to the rule, unless you were trying to rock crawl with a LS.
  24. Feb 8, 2019 at 8:42 PM
    fishmando
    Haha, no sir. I got into some snow parking lots a handful of times, but my truck is far from a rock crawler. Daily duties in the winter months, doesn't get driven all that much the rest of the year.
  25. Feb 8, 2019 at 8:45 PM
    Interesting. Did you ever get down to the root cause of the failure?
    This is not normal, but you do have a lot of snow in your area.
  26. Feb 8, 2019 at 8:49 PM
    fishmando
    It's going back to Auburn soon (they do have good customer service) and I'll probably get a free replacement, which will go in. As for the root, maybe they can uncover that. I don't want to have to baby the thing, my car runs an adjustable osGiken Diff. The posi in the car has worked flawlessly for years with lots of thrashing,
  27. Feb 8, 2019 at 8:54 PM
    Tag me on here when you get the results. Besides a faulty installation, must have been some defective parts.
    Glad this company is standing behind their products.
  28. Feb 8, 2019 at 9:00 PM
    Grumpy Uncle
    Pat
    CO
    I have had mine in for a year now and have had no issues. Works as advertised.
  29. Feb 8, 2019 at 9:01 PM
    This is what I always hear. First time on a 4000 mile failure.
  30. Feb 8, 2019 at 9:04 PM
    Grumpy Uncle
    Pat
    CO
    The guy you reccomend to do my install said, that it is pretty crucial to install them correctly. That's why he needed an extra day to do mine. I have about 9000 miles on it now.
    Black Wolf likes this.
