ATV's utility
Discussion in 'Off-Topic Discussion' started by nowayout, Dec 10, 2018.
  1. Jan 9, 2019 at 1:22 PM
    ZPMAN
    Minnesota
    Yep the strap is a 5 minute fix, the cable is a PITA! The strap I use is good for 1800 pounds, i get it used from a buddy who is an electrician and they use it to pull cables through conduit.
  2. Jan 9, 2019 at 2:28 PM
    nowayout
    nowayout [OP] New Member
    NY
    17 CM
    Do you have to take all the cable off the winch to get it to work? Do you know of any write ups on it or videos?
  3. Jan 9, 2019 at 5:34 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    GREEN is GOOD!!!
    Regular wear and tear maintenance- all I’ve done!! And I abuse them!!
    1F631425-91C5-4B0C-BC46-367D0F63ECEE.jpg E3C81843-54D5-4E9E-98F1-298567196C3C.jpg A73C13F1-FAC3-4610-AB3E-C84C88A5A428.jpg
    05’ Prairie 700 4x4
    98’ KX 250- set up for woods
    Kawasaki “ let the good times roll”
    JM2C
    ZPMAN likes this.
  4. Jan 9, 2019 at 5:34 PM
    ZPMAN
    Minnesota
    I just took off all the cable and as I remember just tied a simple knot. If you go with strap you can put on a lot more on than cable.
    nowayout[QUOTED][OP] likes this.
  5. Jan 10, 2019 at 7:00 AM
    ZPMAN
    Minnesota
    Very similarly to this is what I use.
    https://goo.gl/images/NLm3vK
