ATV/UTVs and accessories
Discussion in 'Off-Topic Discussion' started by caboose, Mar 17, 2017.
  1. Feb 9, 2022 at 5:01 PM
    #481
    18" TRD Off Road Wheels
    That's awesome! Excited for you!
  2. Feb 9, 2022 at 5:48 PM
    #482
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Thanks man!!! Definitely worth the wait!!!!!!!!
    GODZILLA[QUOTED] likes this.
  3. Feb 9, 2022 at 6:01 PM
    #483
    AZBoatHauler
    So.Arizona
    Awesome! Hopefully you can make it longer than I did before tearing your new machine apart. :anonymous:
    drobb[QUOTED] and snivilous like this.
  4. Feb 9, 2022 at 6:11 PM
    #484
    :eek::eek2: What did you do!?
  5. Feb 9, 2022 at 6:14 PM
    #485
    AZBoatHauler
    So.Arizona
    You won’t believe me - but this is following Honda’s instructions to add their horn. I think I’m now a qualified tech.
    drobb and GODZILLA[QUOTED] like this.
  6. Feb 9, 2022 at 6:17 PM
    #486
    Oh, I believe you. That's part of why I bought mine with the street legal kit installed. I would be the guy that has an extra bolt or two after reassembly.
  7. Feb 9, 2022 at 6:21 PM
    #487
    AZBoatHauler
    So.Arizona
    I only had to drill and tap for one bumper bolt that wouldn’t go back in.
    https://youtube.com/shorts/r3zQuzFUTYs?feature=share
  8. Feb 10, 2022 at 11:29 AM
    #488
    drobb
    A8717B48-EBB9-403C-8E95-A4219E38C8AE.jpg D80E314D-49FD-47D9-80CD-3C6C800C310B.jpg ….annnnnnnd she’s home!!!!!
  9. Feb 10, 2022 at 11:46 AM
    #489
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    About damn time! Looks awesome, those are some meaty tires too. Drop the tire pressure, setup the fox tune, and go yeet that skeet.
  10. Feb 10, 2022 at 12:30 PM
    #490
    drobb
    Yep…. Took 4 months to get here. Stock tires are 32s. :) Now I’m just trying to not drain the wallet with mods.
    snivilous[QUOTED] and GODZILLA like this.
  11. Feb 10, 2022 at 12:45 PM
    #491
    Get out and drive it first. It'll help you focus on mods and know what you need.
  12. Feb 10, 2022 at 1:11 PM
    #492
    drobb
    Exactly!
  13. Feb 10, 2022 at 2:04 PM
    #493
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    OMG, that is pretty much what I am looking at too! Can't wait to hear your experience..
    snivilous likes this.
  14. Feb 10, 2022 at 2:46 PM
    #494
    drobb
    Keep you posted :)
  15. Feb 10, 2022 at 5:43 PM
    #495
    snivilous
    SW UT
    I bottomed out prerunning at KOH in some trophy truck ruts, fucked up the gearbox again despite having a 1/4" aluminum skid, so now I get to try and seal it again :D this time I have it nose up to try and keep all the gear oil away from the cracks so I can weld and rtv it, then will put some 1/4" spacers between the skids and frame and then get some 1/2" UHMW skids, hopefully that will finally stop the rear end leaking.
    mgm16trdpro and boostedtrdpro like this.
  16. Feb 10, 2022 at 5:49 PM
    #496
    Yikes! Have you looked into beefing up the suspension to prevent the bottoming out? Also, what is UHMW?
    That pic scared me. I thought I was seeing it after it had teetered off the lift. Took a second for my eyes to catch the straps holding it.
    snivilous[QUOTED] likes this.
  17. Feb 10, 2022 at 8:30 PM
    #497
    snivilous
    SW UT
    I have the pairs of lift arms locked parallel to each other, the straps was mainly to make sure it wouldn't roll over backwards :D but the tires are sitting in the cradle of the pair of arms, so it's about as safe as normally lifting something.
    UHMW is just the dense plastic the stock skids and body panels are made from. I can run the suspension stiffer, I have it at the softest setting, but where I had issue was the ruts on the race course were so deep I was literally dragging the bottom since the ruts formed a W shape, so combine that with a little bump and regardless how your suspension is setup you're bottoming out, which is what happened to me--plus I think there was a rock in the silt where I hit since the front of the skid got ripped backwards and turned into a shovel :D
  18. Feb 10, 2022 at 8:39 PM
    #498
    Damn. That's quite the adventure. Maybe you need a steel skid that has a but of upward lip/curve and the front so there isn't an edge down low to get caught? Or bigger lift and tires.
  19. Feb 10, 2022 at 9:21 PM
    #499
    snivilous
    SW UT
    That's how the aftermarket skids are set up, 3/8-1/2" plastic and a bent up edge to cup the body and try to avoid it being ripped off. Hopefully between that and the 1/4" aluminum skid I have beneath the gearbox already, I won't crack the case again :rofl: you're right lifting it and bigger tires would help, but that is its own host of trade offs I don't want to deal with
  20. Feb 10, 2022 at 10:00 PM
    #500
    Oh, I know. I was just playing devil's advocate. :devil:
  21. Feb 12, 2022 at 8:21 PM
    #501
    drobb
    CE41E968-2514-4898-BED1-13539BABE81B.jpg Posted in another channel, but thought I would update here also.
    Found a unicorn!!!!! 14ft trailer with an 83 inch deck. #5200 axle and brakes. It’s going to work perfect with the new Can AmX3!!!
    snivilous, boostedtrdpro and GODZILLA like this.
  22. Feb 12, 2022 at 8:36 PM
    #502
    Nice! Any reason you went for a single axle vs a tandem?
  23. Feb 12, 2022 at 10:00 PM
    #503
    drobb
    I did a ton of reading on forums….people seemed to like both and both had good comments about towing….. just have to see. Since this has a 5200 lb axle, I should be fine as far as weight carrying capacity goes. At 14ft the X3 should sit really close to over the axle…… or I can back it in. Going to do some load testing tomorrow…… any insight would be great if you have experience.
  24. Feb 12, 2022 at 10:18 PM
    #504
    For me the only relevant difference shows up when you have a bad day and lose a tire. If you are cruising down the road at 40-50 MPH and a tire shreds, on a single axle trailer you might be out a wheel, whereas on a tandem you still have another tire on that side to keep things from getting too gnarly. Purely personal preference.
    As for backing it on the trailer, I wouldn't. The engine is in the rear of your SxS, and that is where the most weight will be. I'd try to put the rear wheel just behind the fender of the trailer. About where I scribbled it below. That should keep a good amount of weight on the trailer axle, but not make you too light in the tongue. If it wobbles on your test run, I'd just keep moving it forward until you are where you wanna be. I'd put the front tires against the front rail of the trailer before I backed it on. Especially if you ever plan to put a windshield on. Lots specifically say not to tow the vehicle backwards with a windshield, so it's better to just build the habit of pulling straight on the trailer than risk damaging an accessory you buy in the future.
  25. Feb 12, 2022 at 10:33 PM
    #505
    drobb
    Great info!!!!! Thank you!!!
  26. Feb 13, 2022 at 11:19 AM
    #506
    drobb
    578F8F7E-323F-46CE-AC05-BBEB7DC9D435.jpg A5A049C8-18E6-4868-A304-88D28F4D69D4.jpg We’ll she seems to fit pretty well on the trailer. The issue is the distance is so short from a front D Ring to a tie down point on the X3, that I can’t get a strap to tighten. Are you guys using tire bonnets or another method to tie down?
    GODZILLA likes this.
  27. Feb 13, 2022 at 11:48 AM
    #507
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    U can criss cross from front of trailer to rear axle, then front a arm to a rear point on trailer. That'll keep it from moving forward or back, side to side.
  28. Feb 13, 2022 at 3:42 PM
    #508
    drobb
    This worked perfect! Took the trailer and X3 for a freeway test run…. Solid and no sway. Thanks for the info!!!!
    mgm16trdpro[QUOTED] likes this.
  29. Feb 13, 2022 at 5:09 PM
    #509
    mgm16trdpro
    Northern NJ
    That's great to hear, glad I was able to help. BTW congrats on the X3. Great choice. I almost went that way too but decided I could get a little more work out the Commander.
    drobb[QUOTED] likes this.
  30. Feb 13, 2022 at 6:16 PM
    #510
    As you've found a good way to tie down with @mgm16trdpro's help I won't worry about the question, but had to say: Good grief! That thing is huge! The tires look like they are almost interchangeable with your truck. When I recommended the rear wheel placement I thought you've have at least a foot up front, but there really wasn't any other way to put it on there than right up to the front rail. :rofl: That monster is gonna be loads of fun for you.
    Quick question, when you say freeway test run, how fast did you test it? Only asking because most stock trailer tires aren't rated for speeds much beyond 60-65 MPH. A short test up to 75-80 is unlikely to do any harm, but if you head out on a trip and run those speeds on a lower rated tire.... well, you might find out first hand why I prefer tandem axles to singles. Can't tell you how many trailers I pass on the interstate with a blown tire, and I would bet that a majority of them were running full tilt on tires that aren't rated for it, heated the tires, and :boom:! You'll also get better MPG at 60-65 vs 75-80, if that matters to you.
    Safe travels, and keep us posted on how you like it through the break in period, and then when you can really cut it loose!
