Attempting 1st Camper Shell Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Roadtripper, Mar 11, 2020.
  1. Mar 11, 2020 at 4:45 PM
    Roadtripper
    Roadtripper [OP] New Member
    Kurt
    2018 Tundra SR5 Dbl 4x4
    ARE Shell, Line-X Spray-in Bed Liner, Toyota Running Boards, Vision Turbine Matte Black Wheels
    I recently purchased a 2018 Tundra SR5 Dbl Cab 4x4... I will be adding an ARE Shell as well as a bed liner before attempting a camper style build out... I do not have a bed rail system, so I am contemplating using the bolt holes intended for the bed rail system (see photo) to anchor 2x4 railings for the cabinet sides... the rails will not need to support the bed in the middle, just the storage areas on the sides... so, being a newbie, is this a good idea, bad idea? Does any one have any thoughts or advice that might be helpful? Anyone know what size bolts to use? Anyone else done this with success... or failure? Thanks in advance for your time & thoughts!!
    SprinterAE86 likes this.
  2. Mar 11, 2020 at 6:28 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Those holes are 6mm and I would and do use UniStrut for this and not wood.
    Strut comes in 2 profiles and I think the smaller or 3/4" profile is easily enough for your needs.
    The great thing about Strut is that there are fittings and hardware that attach your stuff by bolting to track mounted fasteners.
    They stock and sell the basics at the big box hardware stores.
    For most uses they are all alike just with different names by manufacturer but anyone in Hardware will know what you are talking about.
    Learn it
    Love it
    Use it
    https://www.google.com/search?q=usi.....69i57j0l5.3599j0j7&sourceid=chrome&ie=UTF-8
    Roadtripper[OP] and AZTundra like this.
  3. Mar 12, 2020 at 8:10 AM
    Stig
    Stig New Member
    8020 is another option
  4. Mar 12, 2020 at 1:50 PM
    Roadtripper
    Kurt
    Thanks EzDog & Stig, I appreciate the suggestions and the info on the size!
