Attaching stuff to bed rails (Shovel, Axe, etc.)
Discussion in 'General Tundra Discussion' started by SD Surfer, Apr 16, 2025.
  1. Apr 16, 2025 at 10:58 PM
    SD Surfer
    SD Surfer [OP] Globe Trotting Bon Vivant
    Bruce
    So Cal
    Are quick fists the best option or is there something better?
    Let's see your setups!
    No I don't want to put molle panels over the full Bedrug, probably just a shovel and axe. (Actually large hatchet)
  2. Apr 17, 2025 at 3:18 PM
    SD Surfer
    Bruce
    So Cal
  3. Apr 17, 2025 at 3:43 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Quick Fists and angle iron.
    SD Surfer[OP] likes this.
  4. Apr 17, 2025 at 3:55 PM
    SD Surfer
    Bruce
    So Cal
    Oh that's pretty smart! Is the Angle just attched to the rail or did you attach the bottom too?
  5. Apr 17, 2025 at 4:05 PM
    JLS in WA
    Attached to the rail and then resting on the wheel well. I did Plasti Dip on the bottom where it makes contact. I got the idea on Tacoma World.
  6. Apr 17, 2025 at 4:39 PM
    2mchfun
    Have you considered the hi-lift interchangeable tools kit?
  7. Apr 18, 2025 at 8:09 AM
    SD Surfer
    Bruce
    So Cal
    I like it!! Thanks
    Saves on rail space having them stacked vertically and below the rail.
    If I had a shovel and hatchet directly on the rail it eats up all that real estate and could interfere with having my tie-downs where I want them.
    I had not considered that, mostly 'cuz I didn't know it was a thing!
    You talking about this? Pretty cool. (Not sure it's $216 cool for my limited needs, but cool nonetheless)
    https://hi-lift.com/products/handle-all/
  8. Apr 18, 2025 at 9:17 AM
    JLS in WA
  9. Apr 18, 2025 at 10:42 AM
    SD Surfer
    Bruce
    So Cal
    JLS in WA[QUOTED] likes this.
  10. Apr 18, 2025 at 12:29 PM
    JLS in WA
    Not my write up, but yes it’s very good. I found it right after I bought my Tundra. I’ve been really happy with the setup.
