ATF Drain and Fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by matrdguy, Sep 4, 2021.
  1. Sep 4, 2021 at 6:41 AM
    matrdguy
    matrdguy [OP] New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    Just looking for some input on my situation from the knowledge base here...I did search but not finding anything regarding my situation.
    2016 Tundra with 123000 on it... due to a variety of circumstances I failed on the ATF maintenance cycle...so what I'm asking is if I do just a drain and fill on the ATF would I be ok?
    I put lots of hwy miles on the truck and local Toyota dealers want $ 500+ to do Transmission service. I don't have that $$ right now... so I was just gonna do a simple drain and fill ( about 4 qts or whatever comes out) then in about 2000 more miles do another D/F.
    I was also worried that dealer would do a flush on the Trans service ( with the machine) and not drop the pan which I know might possibly cause issues too due to the old fluid being in there and maybe dislodging something that would mess up my transmission.
    What say you ?
    Any advice is appreciated...
    Wallygator likes this.
  2. Sep 4, 2021 at 7:12 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Your plan of multiple drain and fills is good.
    rodm1, equin, avssuc and 1 other person like this.
  3. Sep 4, 2021 at 7:18 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    drain and fill , dont do a flush with higher miles.
    rodm1, equin and avssuc like this.
  4. Sep 4, 2021 at 7:21 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Interested if you're going to watch the AT temp for the level correction I guess you'd call it?
    I've seen about 4 ways to do this but think when the time comes for me I'll suck it up and buy a Scan Guage, seems like the cheapest while still being accurate? The jumping the ODB II pin method seems pretty detailed to me. I think I'd like to slow things down, watch the temp on a Scan Guage. Happy for thoughts from the experts, I know it's been hashed out a lot.
    rodm1 and 10 Bears like this.
  5. Sep 4, 2021 at 7:28 AM
    matrdguy
    Pete
    Yeah.. unfortunately buying a scan tool or any of that is not in my budget .... I was just gonna let it sit overnight to get totally cool and just drain and replace exact amount of fluid ...
    I watched a bunch of vids but I'm thinking some clean fluid is better than NO clean fluid...hope that is the right mindset to be in
    Hoping that works... until i can get a job... $$ is very tight... and I still am traveling as I can for interviews etc...so I need the truck to be running.
  6. Sep 4, 2021 at 7:42 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    TorquePro on your phone for $5 is cheaper, or use an IR thermometer. I've done those and the jumper, the jumper is a pain in the ass to do correctly imo :D
    OP I see nothing wrong with drain and fill same amount. Any new fluid is better than none imo.
  7. Sep 4, 2021 at 7:56 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I measured how much drained out. Then re added exactly that much. Not scientific but no issues
    WILLINH, equin, matictundra and 7 others like this.
  8. Sep 4, 2021 at 8:09 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I’ll be doing the same drain and fill at 30,000 miles. How many quarts drained, need to go buy some WS this week.
    YardBird likes this.
  9. Sep 4, 2021 at 8:12 AM
    CTundraForMe
    CTundraForMe New Member
    Ask the dealers how/what they do.
    There IS a safe way to do it, and there definitely is a wrong way to do it.
    The right way is for them to cycle out the old fluid with the natural flow from the transmission pump while refilling it with new stuff. Some dealers know how to do this and do it right.
    The wrong way is to force it out with an external pump. That's what damages transmissions.
    The lame way for a dealer is to drain and refill. That doesn't do much of anything and isn't very efficient.
    When I had it done on my 2015 they charged me about $325 give or take. Most of that is the cost of the fluid.
    deptrai and CallsignKodiak like this.
  10. Sep 4, 2021 at 8:17 AM
    coldcanuk
    Nice, I think when the time comes, I might just do that. I'll also look at the TorquPro mentioned here, great tip/help!
    Big fan of the KISS method
  11. Sep 5, 2021 at 2:58 PM
    matrdguy
    Pete
    Thanks to all for your input and advice..
  12. Sep 5, 2021 at 4:33 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  13. Sep 5, 2021 at 8:13 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Super informative video. I had no idea that was the way these transmissions needed to be filled and checked. With the amsoil ATF that had to have costed 110-150 just in fluid.
  14. Sep 5, 2021 at 9:48 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I did a simple a drain and fill. Let it sit over night, drained it the next day day, basically exactly 4 quarts came out. I measured using empty milk gallons and a scale but next time wont bother and will just always do 4 quarts, there no need to do the temp check with the overflow drain with this method since your just putting in what you took out. Now if you were completely draining the system and refilling I understand the need to check.
  15. Sep 6, 2021 at 3:33 AM
    matrdguy
    Pete
    Joe,... Thanks.. that's what I'm doing today... I let it sit overnight to get fluid completely cold and am going to just replace what I remove. I have the Toyota WS on hand.
  16. Sep 6, 2021 at 5:51 AM
    georgiey22
    Thank you Joe. Will do the same in the coming days. How many miles were on your truck when you did this, how did the oil look? The tranny fill bolt head looks like the same size as the differential, did you replace the washer as well?
  17. Sep 6, 2021 at 9:18 AM
    Joe333x
    Joe333x Member
    Boston
    15,000 miles. Didn't replace any washers. Old fluid on the left.
    equin, avssuc, Wallygator and 6 others like this.
  18. Sep 6, 2021 at 11:12 AM
    matrdguy
    Pete
    Exactly what mine looked like
  19. Sep 6, 2021 at 6:13 PM
    pursuit2550
    pursuit2550 New Member
    Wrong way and temp to check. Per Toyota it’s 115* to 133*. And never use a temp gun. The tranny oil and pan temp are different. It’s been proven that there is a difference in temps between the pan and tranny oil. Why Amsoil would do this is ridiculous and wrong. Use a scanner or look up the procedure to jump out the obd2 connector for the right temp.
    Trust86 and deptrai like this.
  20. Sep 8, 2021 at 3:52 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Did you drain hot and then measure in morning? would think draining hot may get some extra crap out
  21. Sep 8, 2021 at 5:13 PM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    What A difference between old and new. Nice job...
  22. Sep 9, 2021 at 3:33 AM
    plrod
    plrod New Member
    18 DC LTD 4WD
    if you're just draining a refilling, no reason not to drain it when hot which would get out more solids in suspension IMO
  23. Sep 9, 2021 at 4:07 AM
    convex
    convex New Member
    Robert
    Columbia SC
    ARE Topper Yakima rack Dual Dash Cams
  24. Sep 9, 2021 at 8:39 AM
    Joe333x
    Joe333x Member
    Boston
    I just assumed that letting it sit over night would allow as much fluid to come back down into the pan as possible.
    avssuc likes this.
  25. Sep 9, 2021 at 2:05 PM
    parkerbows
    Jack
    thats sounds reasonable also
  26. Sep 9, 2021 at 3:59 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    It only goes up a couple degrees a minute and steel conducts heat very quickly. The last time I did a drain/fill I used both the OBD2 readout and double-checked the infrared gun for curiosity's sake. It was never more than 2 degrees off at any given time. I can understand if it's a cheap and poorly calibrated gun though.
    Mr_Ed likes this.
  27. Sep 15, 2021 at 1:14 PM
    plrod
    plrod New Member
    18 DC LTD 4WD
    Is the transmission filter in the 3rd gen a screen or paper element?
  28. Sep 15, 2021 at 1:20 PM
    AZBoatHauler
    So.Arizona
  29. Sep 16, 2021 at 6:21 AM
    parkerbows
    Jack
    Just curious did u use a long funnel or what u used to refill?
    Thanks
  30. Sep 16, 2021 at 3:10 PM
    Joe333x
    Joe333x Member
    Boston
    I used a pump from Amazon, I believe it was called slippery pete
    equin, avssuc and parkerbows[QUOTED] like this.
