ATF Check With ATF Cooler. How?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TravisH, Jul 31, 2023.
  1. Aug 16, 2023 at 2:39 PM
    pursuit2550
    pursuit2550 New Member
    Ok so if you're going by the manuf recommendations on the level check then go with the manuf recommendation on the fluid change 60k if towing and 90k if not. I personally wouldn't do either and have changed it at 30k. And lets stick to 10k oil changes. Like I said not rocket science.
  2. Aug 16, 2023 at 2:50 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I hear you
    but if you get me under the truck, I’m gonna use the check process every time
    my 4Runner and tundra both had variances after a couple changes
    maybe, like whiskey aging in a barrel, the angles take a share.
  3. Aug 16, 2023 at 2:54 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I run Blackstone lab analysis for determining fluid life. The fluid level check is not a recommendation, it is a procedure for determining the correct fluid level. Big difference.
  4. Aug 16, 2023 at 2:56 PM
    pursuit2550
    And that's fine. I never said it was wrong or stupid to do it. To me it's like when you do an oil change and I am guilty of this. Drain the oil, change the filter and re-fill. I still pull the dip stick to check the level. Why? I put in exactly what Toyota say the engine takes. I know the oil is in the engine, as long as you didn't forget to re-install the plug. So its the same with the trans fluid. I know it's at the correct level and I have no leaks, so 4 quarts comes out, 4 quarts go back.
    Wouldn't know anything about whiskey aging, only know that I dont like it. :cheers:
  5. Aug 16, 2023 at 3:00 PM
    pursuit2550
    You are correct, it's a procedure. Still not rocket science.
  6. Aug 16, 2023 at 4:00 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The pan does hold about 4 quarts, the entire system is about 12. Doing the drain and fill without the check process will work but is not the correct way. Personally I use Toyota ATF WS its not super expensive if you shop around.
    https://autoparts.fredandersontoyot...standard-automatic-transmission-fl-00289atfws
    Pig Rig likes this.
  7. Aug 16, 2023 at 4:25 PM
    pursuit2550
    Price has gone up a lot. I paid around $3-4 a while back. I was thinking of switching to the Valvoline since it’s a full synthetic. But I have while to go before that happens so.
  8. Oct 20, 2024 at 3:56 PM
    TravisH
    TravisH [OP] New Member
    Travis
    2019 Tundra TRD Off Road Double Cab
    None
    Confusing thread.....
    So to recap:
    Pin the thermostat
    Drain the pan
    Fill with same volume that drained OR ~4.5 qts
    Get to proper temperature
    Open overfill and drain to trickle.
    BUT LEAVE IT PINNED OR PIN THERMOSTAT WHEN DRAINING TO TRICKLE?
    Thanks!
    Mr Badwrench likes this.
  9. Oct 20, 2024 at 4:12 PM
    Joe333x
    Joe333x Member
    Boston
    Not confusing. Look at post 5 of this thread.
  10. Oct 20, 2024 at 4:29 PM
    TravisH
    Travis
    None
    It's confusing because there's 30+ replies for a simple question and many replies just go back and forth. I'm just lookign for an accurate step by step way instead of wading through videos.
    Thanks!
  11. Oct 20, 2024 at 4:35 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you are checking the fluid when you first install the cooler, leave it pinned. After you have correctly checked the fluid level, the next time you drain and fill u don't need to pin it and you can put it what came out because you know it was at correct level.
  12. Oct 20, 2024 at 4:45 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    TravisH[QUOTED][OP] likes this.
  13. Oct 20, 2024 at 4:55 PM
    TravisH
    Travis
    None
    Well the PDF post right after yours says PIN the thermostat as far as I can read......
  14. Oct 20, 2024 at 5:19 PM
    MadMaxCanon
    If you want to do the whole procedure absolutely correctly every time, that's great and the best choice. If you know for a fact the fluid level is correct, how can putting I'm whatever came out steer you wrong?
  15. Oct 20, 2024 at 5:42 PM
    TravisH
    Travis
    None
    Gotcha!
    I'm confident the level is correct and I see no leaks but IF I wanted to make 100% sure I have the correct level which approach should I take?
  16. Oct 20, 2024 at 7:00 PM
    Joe333x
    Joe333x Member
    Boston
    You're just lazy and want spoon fed information? Post #5 over a year ago i not only posted the answer to your question but also posted a video and had it start exactly where the check processes starts in the video. Sounds like you might as well just have someone else do the work as well since you can't even be bothered to read the replies to your own post for over a year.
    BillyB likes this.
  17. Oct 20, 2024 at 7:32 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  18. Oct 20, 2024 at 10:03 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    @TravisH did you take a nap for 15 months? Welcome back!
  19. Oct 21, 2024 at 6:19 AM
    #49
    Mr Badwrench
    Mr Badwrench New Member
    It is way too confusing for a simple transmission fluid swap, I agree 100%.
    WTF Toyota.
  20. Oct 21, 2024 at 8:01 AM
    #50
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Gettin ready to do my first trans drain n fill on my '18 that I bought used last year(Nov). It's got about 34K miles on her now but since it's 6years old, i'm guessin it's probably a good idea to jump on that soon.
    Between reading this 1 year old reawakened thread and watching a few videos the steps are all pretty straight forward n simple. I'm gonna buy 5qts of ATF WS just in case I drain anything over 4qts. Looks like adding about .5qts more then what drains is the best practice(better over then under). Gonna jump on the Fred Anderson sale right now for that along with other stuff.
    I wonder if OP still has not completed his trans maintenance :monocle:
