ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 29, 2020 at 5:28 PM
    #181
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Was that on torque or pan ? Were you towing with S4 and tow haul ?
  2. Sep 29, 2020 at 7:35 PM
    #182
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    To get to 300 degrees need to be in first gear. The torque converter will lock in second and third gear around 260 degrees.
    Jtundra81 likes this.
  3. Sep 29, 2020 at 7:41 PM
    #183
    Jtundra81
    Joe
    Good info , I always tow on 4th regardless highway or not which seems to keep temp under control
  4. Sep 29, 2020 at 9:31 PM
    #184
    Vizsla
    Vizsla 2 = 2.5
    I’ve hit 302+(warning light thing) but not in first gear. :notsure:
  5. Sep 29, 2020 at 9:46 PM
    #185
    Coffee*8)
    Pennsylvania
    + Trans cooler
    What were the driving conditions when the warning light came on? the torque converter can lock in gears 2-6, but just because it can does not mean it will. In any given gear can give it enough gas to unlock the torque converter but not enough to downshift where it would lock.
    The 2nd and 3rd gear lock come into play when climbing a mountain at constant speed.
  6. Sep 29, 2020 at 9:54 PM
    #186
    Vizsla
    Vizsla 2 = 2.5
    Lol. I can see everything the trans does, truck is tuned by me.
  7. Sep 30, 2020 at 3:45 AM
    #187
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Your 2018 has a transmission cooler?
  8. Sep 30, 2020 at 4:14 AM
    #188
    Jtundra81
    Joe
    If he has the 18 , he should
  9. Sep 30, 2020 at 5:24 AM
    #189
    timsp8
    NY
    Yes 18s have a trans cooler, but it’s not overly efficient. It’ll get the job done but the 19/20 owners that have installed one are reporting lower numbers than what I see with my factory cooler.
    Hitting 302 on an 18 is concerning.
    Saltyhero13 and Jtundra81 like this.
  10. Sep 30, 2020 at 8:25 AM
    #190
  11. Sep 30, 2020 at 8:51 AM
    #191
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    The purely fictional description of forum user Greg Marmalard being brain washed in a basement by henchmen-like Toyota personnel in no way reflects my assumptions about the removal of the transmission cooler, nor does any part of the brief satirical narrative attempt to explain, quantify, or qualify any argument for or against the installation of the transmission cooler on 2019 and later years. It was written only for the purpose of adding humor and levity to the thread. It was not even intended to be constructive, but did fit into the conversation as we all wait for the lab analysis of Mr. Marmalard’s ATF sample, much like the Mr. Bean GIFs that followed.
    If I had chosen to communicate my assumptions or feelings about the removal of the transmission cooler, I would have made my points in a structured way, without including fictional characters or situations. But really, it wouldn’t be terribly relevant for me to do so, since I have a 2018 which came equipped with the cooler.
  12. Sep 30, 2020 at 9:00 AM
    #192
    Blue Thunder
    Washington
    I’m tempted to send in a sample from my truck so we have more than one data set. Is it easy to extract a small amount from the fill plug?
  13. Sep 30, 2020 at 9:25 AM
    #193
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I find it comforting. I have a 2019 without an additional cooler and have not hit 302 or had an alarm.
    Apparently the cooler on 2018 and older was not doing anything for the transmission ATF cooling and we're not hearing of massive transmission failures.
  14. Sep 30, 2020 at 9:47 AM
    #194
    Coffee*8)
    Pennsylvania
    + Trans cooler
    can extract some from the check plug. Truck should be level and cold. Start the engine and crawl under and remove the ‘check’ plug(has the word check on it). Hold a pan under and catch the drips. May have to wait until Trans temperature approaches 100 degrees. If it gets hotter then 110 degrees and nothing comes out your level is low.
  15. Sep 30, 2020 at 9:48 AM
    #195
    timsp8
    NY
    It does something, I just think the btu isn’t that great. My hoses are hot around 195 and that seems to be where it wants to settle. It will go up when towing or accelerating fast, but goes back down to around 195. My engine coolant is usually the same or a little higher.
    jtwags likes this.
  16. Sep 30, 2020 at 9:58 AM
    #196
    AZBoatHauler
    So.Arizona
    Same for me. I experimented over the past month with keeping the thermostat pinned open. When it’s pinned opened, my temps fluctuate between 150-175 driving around town. I’ll likely pin the thermostat May-September and leave unpinned Oct-April moving forward.
    jtwags likes this.
  17. Sep 30, 2020 at 10:52 AM
    #197
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    If a well-cooled transmission has a lifespan of 15-20 years or 250-300k miles...and a poorly cooled, overheated transmission has a lifespan of half that or less... do you really expect to see issues on a 2-3 year old unit ?
    I think the jury is still out on this subject... and will likely still be out for a few more years... but by then the damage is already done.
    I didnt wait.
    I put a cooler on mine and will never have the overheating concern in the back of my mind every time I hook a trailer up.
    JRock, betotundra, jetfishn and 3 others like this.
  18. Sep 30, 2020 at 3:58 PM
    #198
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I measure both, trans and torque with a Scan Guage II and the temps are within 5* difference. If i am hammering on the right peddle going up a steep grade with the TT the temps usually equal out by the time i get to the top of the incline (265*F+). Even when i am not towing anything, the temps are usually equal across the pan and the torque converter. Unlike my tacoma with the transcooler, those temps were usually a 20*F difference, maybe more at times.
  19. Sep 30, 2020 at 5:35 PM
    #199
    Vizsla
    Vizsla 2 = 2.5
    It was. But mostly self inflicted, should of been in low range, 37’s with stock gears, LT heavy pig truck, 105F + temps.. My temps look the same as 19 and 20, but all the self inflicted stuff makes my info useless for comparison.
    timsp8[QUOTED] and GODZILLA like this.
  20. Oct 1, 2020 at 6:16 AM
    #200
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
  21. Oct 1, 2020 at 6:18 AM
    #201
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In my experience with Blackstone, it can take 2-3 weeks.
  22. Oct 1, 2020 at 10:24 AM
    #202
  23. Oct 1, 2020 at 11:50 AM
    #203
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  24. Oct 1, 2020 at 11:54 AM
    #204
    Jtundra81
    Joe
    Pretty sure he sold the truck and moved on while we are sitting here and waiting , can't even work , Damm it
  25. Oct 1, 2020 at 12:16 PM
    #205
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    What X gauge are you using for the torque converter temp?
  26. Oct 1, 2020 at 12:17 PM
    #206
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    HURRY UP WILL YA?
  27. Oct 1, 2020 at 12:34 PM
    #207
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    Didn't read all 7 pages, but based on the memes the analysis results haven't posted yet.
    In for the results. Trying to determine if the next truck should be a newer Tundra, go HD, or keep my 2016 for awhile.
  28. Oct 1, 2020 at 1:59 PM
    #208
    Blue Thunder
    Washington
    My UOAs took two weeks to the day from when I mailed them. Think it was about 1 week for USPS to deliver and another week to get the results...
  29. Oct 1, 2020 at 2:14 PM
    #209
    timsp8
    NY
    OP was last seen Sunday, 4 days ago. He is probably out camping again. Or his transmission burned up taking his phone with it.
    Sundog, Sumo91 and Cpl_Punishment like this.
  30. Oct 1, 2020 at 2:45 PM
    #210
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
Thread Status:
