ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 28, 2020 at 9:23 AM
    #151
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The only thing I know for sure that tow/haul does is make the accelerator more sensitive/ responsive.
    I wish our owner's manuals actually had some information in them. You know, explaining how tow/haul or auto LSD works, instead of just telling you in broken English where the button for it is.
  2. Sep 28, 2020 at 9:26 AM
    #152
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    It also holds gears longer.
  3. Sep 28, 2020 at 10:04 AM
    #153
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FWIW
    I saw no difference in timing advance between...
    87 vs 91
    Or
    Normal vs tow/haul
    Patiently waiting for Blackstone results.
    tttrdpro and Cpl_Punishment like this.
  4. Sep 28, 2020 at 10:47 AM
    #154
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The very same. His first name is Cooter.
    GODZILLA and SomeGuy4 like this.
  5. Sep 28, 2020 at 11:48 AM
    #155
    blanchard7684
    blanchard7684 New Member
    Yes . Mine barely moves. Still under 300 vs a max of what 50,000?
  6. Sep 28, 2020 at 12:01 PM
    #156
    Vizsla
    Vizsla 2 = 2.5
    Think it goes 65,500 ish, 50,000 means atf thermal breakdown iirc. Mines at 850.
  7. Sep 28, 2020 at 5:45 PM
    #157
    blanchard7684
    fwiw I don’t have a cooler either.
  8. Sep 29, 2020 at 6:48 AM
    #158
    Any updates?
  9. Sep 29, 2020 at 6:51 AM
    #159
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    So, does the stock temperature gauge not show accurately? If it does, where should it be when it is a safe temperature. I have been watching mine and at operating temperature it always sits a bit under the halfway mark. Being that there are no numbers, what temperature is at at that point?
  10. Sep 29, 2020 at 6:58 AM
    #160
    Kanobi13
    Kanobi13 New Member
  11. Sep 29, 2020 at 7:06 AM
    #161
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Patiently awaiting results.....
    Cpl_Punishment likes this.
  12. Sep 29, 2020 at 7:06 AM
    #162
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You're talking about either the coolant temperature gauge or the oil temperature gauge? No transmission temperature gauge on the 3rd gen (though I believe the second gen may have had one).
    Ronin73[QUOTED] and GODZILLA like this.
  13. Sep 29, 2020 at 7:14 AM
    #163
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    In for the results as well!
  14. Sep 29, 2020 at 7:21 AM
    #164
    Ronin73
    Ronin73 New Member
    Oh, okay. I know which is the oil temp, so I must be mistaking the coolant temperature gauge for a transmission one. Thanks for the clarification.
  15. Sep 29, 2020 at 7:23 AM
    #165
    rrp0968
    rrp0968 New Member
    This is exactly what I did....covered for 10 years or 125K
    jtwags likes this.
  16. Sep 29, 2020 at 7:51 AM
    #166
    timsp8
    NY
    Your 19 has an oil pressure gauge and coolant temp gauge. The 07-13s had an atf temp gauge, but it was meaningless. It was in the middle between about 170-240. It accomplished the same thing a light could. Best atf temp gauge is a digital one, but I think most mfg don’t put one in because most users don’t need it and don’t know what the numbers mean.
  17. Sep 29, 2020 at 8:27 AM
    #167
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Men in dark suits have Marmalard in a basement. They are having him repeat over and over again that his atf fluid is fine and the engineers at Toyota are bright young folks who whistle while they work.
  18. Sep 29, 2020 at 8:32 AM
    #168
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
  19. Sep 29, 2020 at 8:37 AM
    #169
    Just a warning, no more minivan BS.
    Jbehredt, GODZILLA, SomeGuy4 and 11 others like this.
  20. Sep 29, 2020 at 9:53 AM
    #170
    Blue Thunder
    Washington
  21. Sep 29, 2020 at 9:56 AM
    #171
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    So your assumption is they took off the atf cooler to save a couple 100 per truck and if reliability goes out the window it doesn’t matter to them?
  22. Sep 29, 2020 at 10:32 AM
    #172
    timsp8
    NY
    Or he could be assuming the analysis will come back good and Toyota was right all along. And unlike his username, no need to panic, man.
  23. Sep 29, 2020 at 10:49 AM
    #173
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  24. Sep 29, 2020 at 11:30 AM
    #174
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    I am definitely paying attention to this thread....and yet I have one of those lucky dealers where they guarantee powertrain for life. Would I like to see Toyota fix this? Yes....but wait...IF..IF this thing comes back good and there proves to be no issue, then what is there to fix? So round and round we go where I conclude I am happy I bought where I did and have powertrain for life...they didn't even try to sell me a warranty...as in, didn't even bring it up.
    Still watching.
    Clemsonman14 and tttrdpro like this.
  25. Sep 29, 2020 at 11:39 AM
    #175
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I too am eagerly awaiting the results of the Blackstone analysis. I expect the results to show that the old ATF was still good as I have maintained all along that the Toyota engineers know what they are doing. If the results show that the oil is indeed cooked I will admit I was wrong. Will I put a cooler on my truck? Absolutely not. I’ll trade it in on something else, probably a GMC 2500 AT4. I just don’t trust FCA and I refuse to buy a Ford.
  26. Sep 29, 2020 at 12:27 PM
    #176
    Ronin73
    Ronin73 New Member
    How many miles on your truck?
  27. Sep 29, 2020 at 2:51 PM
    #177
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    The wait for the Blackstone results begins...
  28. Sep 29, 2020 at 5:18 PM
    #178
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    I tow a TT 4000lb and never go above 218 on pan , I see 235 or lower when In traffic or when stopping and accelerating on torque and goes down after.
    I towed in Vermont and NH and in MA flat , didn't see that difference .
    I am not sure under what driving conditions they were getting 300 .
    tttrdpro and Txexplorer23 like this.
  29. Sep 29, 2020 at 5:22 PM
    #179
    Jtundra81
    Joe
    Attached data collection from my last round trip while towing, one hour of towing each way
  30. Sep 29, 2020 at 5:27 PM
    #180
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I have towed my TT #6000, in Maine and NH in July this year. I seen trans temps reach 265*F when going uphill. The temp did drop quickly when on flat pavement to about 210*F. I'm not going to worry too much about it. The ambient temp up here in New England does not get high enough to warrant the install of a trans cooler. I will keep an eye on my trans temps when i tow for sure. If i see the trans temps getting worse, then i will contemplate a trans cooler install.
    I am still interested in the results. I am a mechanic, and understand fluid temps, but i'm still on the fence
Thread Status:
