ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 25, 2020 at 8:55 AM
    #121
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Is this when the engine stops working? Asking for a friend. :crapstorm:
  2. Sep 25, 2020 at 9:01 AM
    #122
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    If someone doesn't know what engine braking is, they probably shouldn't be towing more than a hot dog cart.
  3. Sep 25, 2020 at 9:31 AM
    #123
    Kanobi13
    Kanobi13 New Member
    Ok.so can you enlighten the community?
  4. Sep 25, 2020 at 9:35 AM
    #124
    AZBoatHauler
    So.Arizona
    You’re proving my point. The whole internet available to you... here is a decent explanation-
    The Ins And Outs Of Engine Braking
    Here's a quick low-down on how engine braking occurs in petrol and diesels engines, along with where it can be utilised!
    The art of engine braking can either be a help or a hindrance when driving, exploiting the suck, bang and blow of internal combustion in an inverse form. Experienced when acceleration has stopped and at 0% throttle, engine braking can be used to slow a car down as much as possible in tandem with the brakes. Engine braking can make coasting while off the throttle slightly frustrating as it saps your road speed at a rate that needs further throttle input down the road. But it does have its uses, so let’s take a look at how engine braking occurs and how it works in petrol and diesel engines.
    In its simplest form, engine braking occurs in a petrol engine when the throttle is released. When the throttle pedal is actuated, a butterfly valves opens at the engine’s intake, allowing air to enter the intake manifold to be mixed with fuel for combustion. So when the throttle is released, this butterfly valve shuts, allowing only a very small amount of air through to the engine.
    This sudden closing of the airway forms a vacuum within the intake manifold which produces an opposing force to the pistons reciprocating within the engine. Imagine placing your finger over the end of a football pump and then trying to move the plunger upwards - a large opposing force formed by a vacuum within the cylinder will mean that the pumping piston won’t shift much at all.
    The effort that the pistons have to exert to oppose the manifold vacuum saps energy from their reciprocation, forcing them to slow down and thus rotating the crankshaft slower, reducing road speed. This braking is therefore emphasised when engine speed is high as the large amount of air previously entering the cylinders is suddenly shut off, creating the vacuum that opposes a higher rotational force from the cylinders.
    On top of the vacuum element, a minimal amount of engine braking is also achieved by friction between the moving parts of the engine. Although the oil system provides a more than suitable amount of lubrication to make sure the moving components don’t end up welding themselves together due to heat, there is natural friction between every moving piece of the engine as they interact with each other. This friction has a negative influence on the positive energy of the moving engine, thus stripping rotational energy from the crankshaft and ‘braking’ the engine.
    (article by Michael Fernie @ carthrottle.com)
    AZ_Tundra1, Sundown5oh and Bammer like this.
  5. Sep 25, 2020 at 9:45 AM
    #125
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What is petrol? Is it an additive to keep ATF cool?
  6. Sep 25, 2020 at 9:51 AM
    #126
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I think it's a Canadian blend of gasoline.
  7. Sep 25, 2020 at 9:57 AM
    #127
    Kanobi13
    Kanobi13 New Member
    Lol your funny so how does s4 help with breaking in normal driving and not hills? I just think its funny how you take a bullet point and its set in stone for s4.
  8. Sep 25, 2020 at 10:00 AM
    #128
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Us Canadians use a special blend of Unicorn piss and Eskimo sweat in our petrol , We keep it cool in our igloos so it lasts longer :thumbsup::rofl::rofl:
    JRock, AZ_Tundra1, SomeGuy4 and 7 others like this.
  9. Sep 25, 2020 at 10:09 AM
    #129
    Kanobi13
    Kanobi13 New Member
    I inderstand this im just saying the manual does not say you must tow in s4 its a bullet point for downhill grade control to have engine slow you down instead of torching breaks and ending up in a ditch
  10. Sep 25, 2020 at 10:10 AM
    #130
    AZBoatHauler
    So.Arizona
    It’s not in stone - it’s in a written manual authored by Toyota. Take the advice or don’t - I don’t care. FWIW I use D while towing on flat ground but that doesn’t mean that is what Toyota recommends. What does the bullet point have to do with anything? Do bullet points mean they don’t really mean what they wrote? This section of the owners manual is a list of tips for driving while towing. You can take the tip or not but doesn’t change the fact it’s there and says what it says.
    Cpl_Punishment likes this.
  11. Sep 25, 2020 at 10:14 AM
    #131
    AZBoatHauler
    So.Arizona
  12. Sep 25, 2020 at 10:28 AM
    #132
    Kanobi13
    Kanobi13 New Member
    I love the passion!! I will be waiting for the results so we can put this aux cooler nonsense to rest
  13. Sep 25, 2020 at 10:29 AM
    #133
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    This sounds like the driver doesn't have any control over whether the truck engine brakes or not. Therefore, I would always tow in S4 to be safe.
    Jtundra81 likes this.
  14. Sep 25, 2020 at 10:36 AM
    #134
    Bammer
    Monroe, CT
    I hope so, but doubt it.
    Blue Thunder likes this.
  15. Sep 25, 2020 at 10:42 AM
    #135
    blanchard7684
    blanchard7684 New Member
    What is the benefit of towing in S4 besides engine braking?
  16. Sep 25, 2020 at 10:44 AM
    #136
    AZBoatHauler
    So.Arizona
    Keeping the transmission temp down. Shifting into and out of overdrive builds heat fast.
    Jtundra81, Cpl_Punishment and Bammer like this.
  17. Sep 25, 2020 at 10:45 AM
    #137
    Bammer
    Monroe, CT
    Post # 129
    AZBoatHauler likes this.
  18. Sep 25, 2020 at 10:47 AM
    #138
    blanchard7684
    Thanks...but I thought lock up was better for reducing heat load?
  19. Sep 25, 2020 at 10:58 AM
    #139
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    It is. It was either a mistake or they were just wrong.
    Blue Thunder and AZBoatHauler like this.
  20. Sep 25, 2020 at 11:08 AM
    #140
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It is. More likely to stay locked in 4th than 5th or 6th.
  21. Sep 25, 2020 at 11:09 AM
    #141
    AZBoatHauler
    So.Arizona
    Correct, slippage while unlocked is the source of heat.
    Blue Thunder and Cpl_Punishment like this.
  22. Sep 25, 2020 at 11:11 AM
    #142
    blanchard7684
    Alrighty...squared away now. thanks!
  23. Sep 25, 2020 at 11:12 AM
    #143
    Bammer
    Monroe, CT
    My apologies for the false info, I stand corrected and humbled.:hattip::hattip::hattip:
  24. Sep 28, 2020 at 6:53 AM
    #144
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I haul things, I need 4x4,...I mean towing is not the only reason for having a truck...
  25. Sep 28, 2020 at 6:59 AM
    #145
    Kanobi13
    Kanobi13 New Member
    You can haul things in a mini van and have more payload though....
  26. Sep 28, 2020 at 7:11 AM
    #146
    Vizsla
    Vizsla 2 = 2.5
    Anyone with a 19+ check the atf thermal degradation estimate?
  27. Sep 28, 2020 at 7:12 AM
    #147
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Who wants to haul a load of gravel/dirt/mulch in a mini van lol.
  28. Sep 28, 2020 at 8:42 AM
    #148
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    It sounds like you used to have lunch with my brother!!
  29. Sep 28, 2020 at 8:50 AM
    #149
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Tracks? There are no tracks where we're going!
    ...I did use S4 this weekend to tow the boat on a highway with 75mph speed limits. Now deciding between running 1,000 RPM higher or frequent ATF changes are the better option.
  30. Sep 28, 2020 at 8:54 AM
    #150
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    What’s the purpose of tow mode if one is using S4? Thought the whole purpose of tow mode was for the truck to pick the correct gear/rpm while towing.
    Leo's first and hagrid like this.
Thread Status:
