ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 22, 2020 at 9:29 PM
    #91
    Tundrafan23
    Tundrafan23 New Member
    I don't see anybody getting "angry", I see people discussing their differing opinions. Isn't that kind of the whole point of a forum?
  2. Sep 22, 2020 at 9:43 PM
    #92
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    yes, fluid goes through the puck first, it is the primary heater/cooler. If fluid is over 180 degrees after exiting the puck, the thermostat on the transmission diverts the fluid up front to the secondary cooler.
    The thermostat and secondary cooler is what Toyota removed in 2019 from the towing package. Now all trucks have the old non-towing package setup of only the primary heater/cooler.
    Bammer likes this.
  3. Sep 23, 2020 at 5:11 AM
    #93
    timsp8
    NY
    Chill out man. No need to get upset. This thread is about his atf fluid. Not the misperception that his warranty is void because he added a cooler.
  4. Sep 23, 2020 at 6:23 AM
    #94
    betotundra
    betotundra Toyota for Life
    Wow, that's beyond amazing.
    I'd say having a SC definitely affects the transmission in some way, even a considerable tire size change does, but hey, I'm not Toyota, nor an engineer, so good for you man.
    Like you said, either other people (many) has had crappy dealer experiences, or at least looks like you have a pretty nice dealer that takes care of their customers, cheers!
  5. Sep 23, 2020 at 6:51 AM
    #95
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Looking forward to the fluid analysis, thanks for the forthcoming information.
    I have been going back and forth on getting a cooler, I keep vehicles until the end of life. I found a local transmission shop willing to install for 250 bucks ( I don't trust myself), so I think it is a yes to add.:threadjacked:
    jetfishn likes this.
  6. Sep 23, 2020 at 8:24 AM
    #96
    Blue Thunder
    Washington
    Let's hope Blackstone has a good sample size for this fluid. Since this is the OEM fill, it will likely have a higher metal content from the break-in cycle. Not saying "higher" as in bad, just more than maybe what you see with a 2nd fill. If Blackstone has a good history for this fluid, they'll be able to determine if any higher wear metals are from fluid breakdown or "normal" for a factory fill.
    If the fluid shows it has broken down, I'm going to raise hell at my dealer and then likely install a cooler. I'm curious to see if any "add a cooler" opinions change if the report comes back looking good...
    tttrdpro, Doxiedad and Cpl_Punishment like this.
  7. Sep 23, 2020 at 8:40 AM
    #97
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    As someone who really doesn't have a horse in the race at this point (I currently do not tow a ton) I am pretty in the middle. Good results = leave things as they are. Bad results = probably get the cooler before I have the need to start pulling stuff. Will be interesting!
  8. Sep 23, 2020 at 8:42 AM
    #98
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    They have at least 6 samples of WS that I have sent in. They also have countless others from the FJ/4rnr/taco and even the rav4 forums from what I have seen.
    Both my FJ and Taco showed high wear metals on first drain due to breakin, but diminished over drain/refills as you expect. Copper will be sky high after the cooler install, but just put that in your notes to them and they will confirm it.
    Blue Thunder[QUOTED] and Hartsy8 like this.
  9. Sep 23, 2020 at 4:18 PM
    #99
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    This is what my fluid looked like as it came out at 18,000 miles with some towing.3700E6F4-ACCC-4FD1-A830-91511B8D0972.jpg A52D3E6A-E85B-43B4-9473-CDF8BDC4EACB.jpg Only driven home from the dealer today. Red is the pan blue is torque converter. Way better than 235 pan and 250 torque going up the same hill. 67 and misty out.
    This was driving on level ground.
    JRock likes this.
  10. Sep 23, 2020 at 5:48 PM
    #100
    TriniMan
    TriniMan New Member
    SEAN
    South Carolina
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    Hi everyone, I've been following this discussion. I bough a 2019 Tundra the beginning of July. It is a 4.6 RWD and had 17600 miles. Since following the threads, I hooked up my scan tool to monitor the ATF temps. Normal driving around town the ATF temps were running between 200f to 215F and I saw it hit 220F also. My transmission has the warmer on the side of it. I installed a trans cooler on Monday and flushed the transmission first before hooking up the lines. I used about 3 gal. of fluid. I using a full sync. ATF replacement for the WS fluid. My average ATF temp. is now 150F. If I down shift while going up a hill, the TC temp gets to about 180F while the pan oil is 150F. As soon as the TC locks, the temp. drops back to 150F. I have not towed anything as yet, but I do have an enclose trailer that I trailer my motorcycle in. The truck had 23000 miles when I did the flush and install the cooler. Here is the color of the fluid that came out.20200923_120243.jpg 20200923_120243.jpg 20200923_120243.jpg 20200923_120233.jpg
    Bammer likes this.
  11. Sep 23, 2020 at 7:44 PM
    #101
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Need to hold it up to a light, Trans fluid looks dark in a 2L bottle.
    3 pics of the fluid with less than 2k milesIMG_0159.jpg IMG_0162.jpg IMG_0160.jpg
  12. Sep 23, 2020 at 7:49 PM
    #102
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That last pic is the same fluid? Wow, what a difference the light makes.
  13. Sep 23, 2020 at 7:50 PM
    #103
    Coffee*8)
    Pennsylvania
    + Trans cooler
    yes, 3 pics of the same bottle.
    Blue Thunder likes this.
  14. Sep 23, 2020 at 9:44 PM
    #104
    Blue Thunder
    Washington
    Unless you've been destroying your truck, the color "loss" is just the pigment fading out. No way you've zorched your fluid that quickly. This might turn out the same as modern engine oil...the color of the oil has nothing to do with the state of the oil.
    Thanks for posting that pic...
    Jtundra81 likes this.
  15. Sep 23, 2020 at 10:10 PM
    #105
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Yea, the fluid is fine. Just cant tell the color unless the fluid is thin or back lit by a light. I did not pour any brand new fluid into a 2 liter bottle but think the color would look the same.
    But this bottle is what was in the pan after replacing the rubber all purpose hose initially installed with the cooler with transmission hose. Most of the volume is the 1 quart added to the fill hole that was returned thru the check hole a few mins later. Truck has 1600 miles on it, 300 of the more recent miles were towing a 5k pound trailer (pre cooler install).
  16. Sep 24, 2020 at 6:27 AM
    #106
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    In for the blackstone report.
    Saltyhero13 likes this.
  17. Sep 24, 2020 at 9:47 AM
    #107
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Lol my 01 tundra tranny sits at 140 degrees and peaks at 185 at the peak of summer
  18. Sep 24, 2020 at 12:49 PM
    #108
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    It was delivered to Blackstone Labs today so no sure how long the process takes but I will post results promptly.
  19. Sep 24, 2020 at 12:57 PM
    #109
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My UOA came back in about 3 days, transmission fluid may take longer though.
  20. Sep 24, 2020 at 5:44 PM
    #110
    Kanobi13
    Kanobi13 New Member
    No they don't!!
    rebmo and Txexplorer23 like this.
  21. Sep 24, 2020 at 6:36 PM
    #111
    SouthWestGA
    SouthWestGA New Member
    Anybody have a link to the cooler kit they’re talking about?
  22. Sep 24, 2020 at 6:44 PM
    #112
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    There’s a thread about it on the first page.
    Cpl_Punishment likes this.
  23. Sep 24, 2020 at 6:47 PM
    #113
    SouthWestGA
  24. Sep 25, 2020 at 7:39 AM
    #114
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    I would say the “smell” on ATF tells more than “color”. I had a 01’ Honda odyssey awhile back and the transmission has no filter nor cooler. The first time I flushed ATF on Odyssey at around 45k miles, it looked dark and smelled like rotten egg.
    The odyssey’s original transmission went at around 110k miles and the transmission shop put in a remanufactured one for $1200 with one-year/12000 miles warranty. The replacement didn’t even last for 6 month, the shop put another remanufactured one in and threw in the atf cooler for free. I guess they don’t want to see me again!
  25. Sep 25, 2020 at 7:45 AM
    #115
    AZBoatHauler
    So.Arizona
    You see the screenshot of the owner’s manual in post #65?
  26. Sep 25, 2020 at 7:54 AM
    #116
    Bammer
    Monroe, CT
  27. Sep 25, 2020 at 8:18 AM
    #117
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    “To maintain engine braking efficiency and charging system performance when using engine braking, do not use the transmission in D”
    When using engine braking use s4 it doesn’t specify any other situation
    rebmo and McCrapper like this.
  28. Sep 25, 2020 at 8:24 AM
    #118
    AZBoatHauler
    So.Arizona
    That interpretation ignores use of the comma after “braking”. You think Toyota expects everyone towing with a Tundra to know when the truck is engine braking? I’d bet the majority of drivers don’t know what engine braking is...
    Clemsonman14 and 14burrito like this.
  29. Sep 25, 2020 at 8:43 AM
    #119
    Kanobi13
    Kanobi13 New Member
  30. Sep 25, 2020 at 8:47 AM
    #120
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Here we go. It is Friday after all.
    GODZILLA and EDDO like this.
Thread Status:
