ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 21, 2020 at 9:28 PM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    I used to be strict S4 and tow haul. NEVER tow in OD.
    Toyota doesn't demand that with these Tundras and last trip I left in D with TH the vast majority of the time. Only time I downshifted was on a long down hill I could see before the Tundra could feel and downshift. Even then I got more confident TH could work it out better than I could.
    I experimented and found TH pretty much keeps it in S4 for a long while and doesn't shift to OD unless no load flats. You'd think it'd be rushing to get in 6 but it really doesn't.
    Put it in D and TH and roll. That's what Toyota and the "pros" say.
  2. Sep 21, 2020 at 9:47 PM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    I also tow a 25’ airstream with 19’ crewmax here in SoCal. I always use tow mode and s4. Up shift to s5 on flat freeway. Very interested in the trans fluid lab result and also wondering what Toyota’s approach will be “IF” there’s a transmission claim down the road? Should I get the trans fluid cooler kit or buy the extended warranty instead?
  3. Sep 22, 2020 at 4:11 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    If I never tow, I should be good right?
  4. Sep 22, 2020 at 4:49 AM
    Tundrafan23
    Tundrafan23 New Member
    They wouldn't, just not worth doing that every time I brought my truck in for service, IMHO.
    Cpl_Punishment likes this.
  5. Sep 22, 2020 at 4:59 AM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Sure, but then why buy a truck?
  6. Sep 22, 2020 at 5:03 AM
    timsp8
    NY
    If you take your truck to get the oil changed and tires rotated, they aren’t going to mark down that you have a trans cooler and all warranty is voided. They are going to do the job as fast as they can and move onto the next vehicle. I doubt they’d even notice it was there or care if they did notice it.
  7. Sep 22, 2020 at 5:19 AM
    Cthulhu
    :monocle:
    Plenty of other reasons to buy a truck than just towing...off-roading, hauling stuff in the bed, it’s a Tundra...
  8. Sep 22, 2020 at 5:24 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    According to the owners manual, Tundras are primarily designed as a passenger and load carrying vehicle. I don’t tow much, but I do haul stuff quite a bit.
    https://www.tundras.com/threads/tow...ler-on-2020-trd-pro.69167/page-2#post-1792734
    If I had any serious need to tow, I’d probably get a 3/4 or 1 ton crew cab and full 8’ bed (maybe even a diesel...)
  9. Sep 22, 2020 at 6:17 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Especially since a lot of dealerships have a separate quick lube lane or special bays just for oil changes. Those "techs" have a hard time just doing an oil change properly let alone notice something like an ATF cooler...
  10. Sep 22, 2020 at 6:36 AM
    Greg Marmalard
    I was getting 230° on 75° days going 65mph on flat to rolling hills.... NOT towing!
    The kit will get you down to the "normal" 180° range where MOST 1/2 ton trucks run
    jetfishn and jordoncloutier like this.
  11. Sep 22, 2020 at 6:52 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    You’ll be fine. The 4.6 engine ran this setup for years without any major issues. They had a couple of them make it to 1 million miles
    Jtundra81 and Cpl_Punishment like this.
  12. Sep 22, 2020 at 7:16 AM
    blanchard7684
    blanchard7684 New Member
    Group iii oils are good to 300F.
  13. Sep 22, 2020 at 7:34 AM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    This was always my understanding as well.
  14. Sep 22, 2020 at 7:44 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Did something change in 2019? If so I wonder why
  15. Sep 22, 2020 at 7:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Front mounted ATF cooler removed. It now uses the engine coolant circuit via the puck for heating/cooling.
  16. Sep 22, 2020 at 8:11 AM
    GreatBigAbyss
    I know at least one of those million mile trucks went through a few transmissions/rebuilds. I remember in the interview, the owner said had he gotten the transmission serviced more often, it likely would have performed better.
  17. Sep 22, 2020 at 8:22 AM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Weird so many are willing to modify there trans cooling system on a truck built by the worlds biggest auto maker known for their reliability based on a few high temp issues where we don’t even know for sure the cause.
    Jtundra81, Pucks18, Kn4x2 and 4 others like this.
  18. Sep 22, 2020 at 8:25 AM
    Redcon41318
    Redcon41318 New Member
    2018 was last year with a real tranny cooler?
  19. Sep 22, 2020 at 8:25 AM
    #49
    AZBoatHauler
    So.Arizona
    This is the well known cause...
    Bakershack and GODZILLA like this.
  20. Sep 22, 2020 at 8:53 AM
    #50
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Agree- the cause of concern is now well-documented.
    It’s the long term effects that are unknown.
    I’m eager to see the results of the BS analysis.
  21. Sep 22, 2020 at 8:58 AM
    #51
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    It would cost a dealership more to "prove" a cooler caused potentially damage than to do the work the warranty calls for. Service mananger at my dealer stated the cooler would not void warranty and preferred I had one for my applications (towing 3-5 times a week at about 4k lbs on average).
  22. Sep 22, 2020 at 9:01 AM
    #52
    Tundrafan23
    It costs Toyota ZERO dollars to negate a warranty claim, the onus is on you to prove otherwise. If your Service Manager said so, he is in the extreme minority! Sure you can sue citing the MM act, but Toyota has a number of law firms on retainer for this very reason, trust me, Toyota has a lot more money than you do!
  23. Sep 22, 2020 at 9:03 AM
    #53
    14burrito
    2014 SR5 CM 4x4 5.7
    Unfortunately the dealerships aren't always the final word for warranty work. They typically put the claim in with Toyota Corporate who has the final say - otherwise they dont get paid.
    At least this is the order of operations all my warranty work followed.
    AZBoatHauler and Cpl_Punishment like this.
  24. Sep 22, 2020 at 9:04 AM
    #54
    Ckatz53
    Ckatz53 Newish
    MD
    Except the burden of proof is on Toyota to prove the cooler caused an issue according to MV Act. So where do you think it costs them 0 dollars?
    JimboSlice413 and GODZILLA like this.
  25. Sep 22, 2020 at 9:07 AM
    #55
    Ckatz53
    Ckatz53 Newish
    MD
    I had similar dealings with Volkswagen and a 337 edition GTI long ago with brake issues after a redesign in the early 2000s. Long story short, it was more cost effective for VW to bite the bullet and eat the warranty work versus going to fight it. They are indeed just that, businesses. Large pocket books or not, its a cost benefit analysis for them. Pay the money to determine the cause of the issues, potentially run into bad news for them, have to warranty thousands of trucks, or shell out a couple grand on the rare truck that does have issues.
    GODZILLA likes this.
  26. Sep 22, 2020 at 9:07 AM
    #56
    Tundrafan23
    They ABSOLUTELY will make a note of any additional modifications to the truck, trust me, it's happened to me! NOBODY is saying "all warranty" is voided, only part of the warranty that will be voided is anything that is modified, in this case the transmission.
    Clemsonman14 and Cpl_Punishment like this.
  27. Sep 22, 2020 at 9:08 AM
    #57
    18" TRD Off Road Wheels
    Read before you post. Lol.
    You don't sue them. You go to your State AG, BBB, etc. It costs you nothing to cause them enough of a headache to at least listen.
  28. Sep 22, 2020 at 9:10 AM
    #58
    Tundrafan23
    I did the latter and bought an extended warranty for the same money a cooler costs, I am covered up to 100,000 miles bumper to bumper.
    Clemsonman14, glowblue and 14burrito like this.
  29. Sep 22, 2020 at 9:11 AM
    #59
    Ckatz53
    Ckatz53 Newish
    MD
    I think its hilarious the amount of people that just blindly defend Toyota in this particular scenario. Like do you have money in Toyota stock or something? Lol.
    I bought a cooler from Nick. Im sticking it on MY truck. It's a safety assurance for me from long term trans failure that no one knows IF or WHEN the puck is really a bad thing. Id rather pay $900 now than POTENTIALLY $15k in two years. Im not one blindly defending Nick's trans cooler kit either. It may not be necessary. But if something is designed well, works as intended, and keeps something cooler, Im gonna go with that option.
    Sub'd to see the results of the BS analysis.
    JRock and GODZILLA like this.
  30. Sep 22, 2020 at 9:22 AM
    #60
    Blue Thunder
    Washington
    It depends upon how you define this problem. If you don’t like tranny temps in the 250ish range then you are “not good”. A few of us, including me, have seen this temp during normal driving.
    Ckatz53 likes this.
Thread Status:
