At what mileage should you do a Transmission Flush?
Discussion in 'General Tundra Discussion' started by 2015Crewmax, Jan 8, 2019.
  1. Apr 30, 2021 at 6:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No on the flush, do however do a drain and fill every 50-60k
    BlueRibbon4x4 and Jeff_1974 like this.
  2. May 1, 2021 at 8:35 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    damn, then I need to schedule mine! I’m at almost 90k and all highways and dirt roads for work
  3. May 1, 2021 at 9:45 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    I think the word "flush" is being used very loosely in this thread. Toyota dealers will do a fluid exchange but not a power flush. They hook up lines to the trans cooler and let the trans pump cycle out the old and suck in the new. You can exchange all 15 or so quarts of trans fluid at once this way. This will not hurt your trans by blocking passageways with debris this way. It's a $300 charge at the dealer which is mostly the cost of the OEM trans fluid. I would be more worried about doing short interval drain and fills due to this transmission being very picky about the fluid level. I don't trust most Toyota techs to get the level dialed in.
    Booney likes this.
  4. May 1, 2021 at 9:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I do a drain and fill on all my Toyota’s every 30k.. keeps the fluid nice and red..
    at 100k your typically fine
    camillethetoy likes this.
  5. May 1, 2021 at 9:55 PM
    This is my trans fluid after 130k miles. It was supposed to be serviced 50k miles ago. C781FE83-F8CB-485F-AC3F-BCF345E1EB9D.jpg
    camillethetoy and Kgfit85 like this.
  6. May 1, 2021 at 10:05 PM
    empty_lord
    05 rollover special
    That’s about how it’ll look after 50k... the WS turns black pretty quick. Does it mean it’s bad? No.
  7. May 2, 2021 at 5:46 AM
    Besides the fact that that I paid for the service that didn’t get done (I marked the bolts), the manufacture calls for service every 60k miles.
    I’m taking care of the WS turning black issue. AMSOIL went in.
    empty_lord[QUOTED] likes this.
  8. May 2, 2021 at 6:08 AM
    blanchard7684
    blanchard7684 New Member
    This what I do as well.
    get a case of fluid. Drain and refill. Run trans through gears. Repeat until you’ve gone through a case. Then on last round drop pan and replace filter.
  9. May 2, 2021 at 7:41 AM
    Dag3
    Dag3 New Member
    David
    Vail, Colorado
    2012 crew max limited
    I did mine at 100k but only drain and fill. I was always told not to flush it.
