At the tire shop and they can't use my lug nuts
Discussion in 'Wheels & Tires' started by texasrho83, Nov 20, 2020.
  1. Nov 20, 2020 at 11:53 AM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm slapping on some Fuel Shoks and they can't use the ET lugs I used on my KMC wheels. Anyone know what sort of lug nuts I need?
  2. Nov 20, 2020 at 12:50 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm no expert, but...... Sounds like someone fucked up somewhere.... I've replaced shocks and struts and have never come across not being able to reinstall lugs on studs that were there before... unless they broke when I took them off, which is rare.....
  3. Nov 20, 2020 at 12:53 PM
    Kanobi13
    Kanobi13 New Member
    Can they use another brand?
  4. Nov 20, 2020 at 12:58 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I believe Fuel Shoks are a brand of rim.
    Sounds like the OP didn't purchase the necessary lug nuts to use with the new rims. Ex. Can't use OEM lug nuts on SCS Ray10 rims
  5. Nov 20, 2020 at 1:02 PM
    Kanobi13
    Kanobi13 New Member
    He had kmc wheels so not oem
  6. Nov 20, 2020 at 1:04 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    That's what he is saying in post you quoted. He was giving an example
    Tundyfundy likes this.
  7. Nov 20, 2020 at 1:07 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Bingo
    Tundyfundy and Black Wolf like this.
  8. Nov 20, 2020 at 1:21 PM
    Kanobi13
    Kanobi13 New Member
    So he has oem wheels?
  9. Nov 20, 2020 at 1:23 PM
    MEWaters
    MEWaters New Member
    Maine
    man read the post lol
    eta - comes across in a way i don't mean
  10. Nov 20, 2020 at 1:24 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    No, he has Fuel Shok rims (new) that take a specific type of lug nut. His old KMC rims use a lug nut that can't be used on the Fuel Shok rims.
    My post was an example (thus the Ex.) of rims that had one style of lug nut (OEM) that could not be used on a different brand of rims (SCS).
    So in essence, if that is correct, the OP didn't research enough thus not purchasing the correct lug nuts for his/her new Fuel Shok rims.
  11. Nov 20, 2020 at 1:27 PM
    Kanobi13
    Kanobi13 New Member
    Kmc should use conical nuts same as fuel correct?
  12. Nov 20, 2020 at 1:31 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Fuel Shok:
    What are the correct lug nuts for my vehicle?
    Your authorized Fuel retailer/installer should offer the correct lugs for your particular vehicle. Stud size and length and center cap clearance all play a factor in determining the correct lug nuts for your application. Your authorized Fuel retailer/installer is best able to inspect your vehicle, analyze your needs and recommend the correct lug nuts.
    I'm done...
    Tundyfundy and Backslider like this.
  13. Nov 20, 2020 at 1:32 PM
    Kanobi13
    Kanobi13 New Member
    Good job with google
  14. Nov 20, 2020 at 1:33 PM
    MEWaters
    MEWaters New Member
    Maine
  15. Nov 20, 2020 at 1:34 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    OMG...you are just precious, aren't you.
    Tundyfundy, joonbug and MEWaters like this.
  16. Nov 20, 2020 at 1:35 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    If your tire shop doesn't know what size lugs to put on.....find a different tire shop
    Tundyfundy, JLS in WA and Black Wolf like this.
  17. Nov 20, 2020 at 1:39 PM
    Kanobi13
    Kanobi13 New Member
    Guess you were not done
    Zero One Actual likes this.
  18. Nov 20, 2020 at 2:23 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    OP, what's happening? Why can they not use the ET lugs? Is the lug bore too small? Is the lug pad too shallow?
    Black Wolf likes this.
  19. Nov 20, 2020 at 3:04 PM
    This^^^
  20. Nov 20, 2020 at 3:06 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I don't think this has anything to do with the size of the lugs - it's going to have more to do with the lug bore, whether or not the existing lug nuts are conical, how much material is at the bottom of the lug bore.. etc?
    I'm highly doubtful his tire shop "doesn't know what size lugnuts to use"
  21. Nov 20, 2020 at 3:09 PM
    Backslider
    Tooele, UT
    My first comment was before reading the entire thread, but this ^^^ hits the nail on the head. Lots more to lug nuts than size, pitch, and seat..
  22. Nov 20, 2020 at 5:19 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Didn't expect the bloodshed to ensue from a simple question lol but yes I went to another tire shop (one I usually go to but didn't this time. Lesson learned).
    Anyway the manager was able to quickly find the right lug nut that accommodated the new wheels I had. I needed M14x1.50 without the extended thread. Conical.
    Thanks for the useful comments guys :cheers:
  23. Nov 20, 2020 at 5:38 PM
    Kanobi13
    Kanobi13 New Member
    Glad the world did not end!
