Assembled Bilstein 6112s - great all around buy for the leveler in us all?
Discussion in 'Suspension' started by MistrRoboto, Nov 17, 2017.
  1. Sep 23, 2020 at 4:42 AM
    #331
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I’m coming up on 3 years, about 45k miles. They haven’t been around so long you will see mega miles. My Icons got about 80k miles before the seals started to leak and I had to send them back for 800 bucks in work. I’d expect well over 100k of life if not off-roading heavily.
  2. Sep 23, 2020 at 4:44 AM
    #332
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Awesome to hear. I bought a set used from a member on here with 24k and just wanted to know what to expect. It sounds like I will get my monies worth :)
  3. Sep 23, 2020 at 4:45 AM
    #333
    Hartsy8
    Max
    2020 MGM 1794
    I will be doing the same sir
  4. Sep 23, 2020 at 4:54 AM
    #334
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    They actually are rebuildable, the bilstein po way, CA location does them. 6112 and 5160’s. Probably takes quite a while though. I kept my stock shocks around just in case, figured I’d throw a spacer lift on for alignment purposes if I ever do have to send them in for a rebuild. Mine are on highest setting w stock uca’s and no issues aligning.
    CaptainGrumpus likes this.
  5. Sep 23, 2020 at 4:58 AM
    #335
    MistrRoboto
    Virginia Beach, VA
    Nice! Didn't know that.
  6. Sep 23, 2020 at 11:47 AM
    #336
    infamousavi
    infamousavi New Member
    Awesome info.
    Was thinking to do the same 5100 with Eibach that i had on my 2nd Gen, no complaints on comfort drivability, but seem these assembled 6112 are worth more research
  7. Sep 25, 2020 at 6:45 PM
    #337
    BLK1794
    BLK1794 New Member
    Ontario, Canada
    ‘17 Toyota Tundra 1794
    Procomp 7” Stage 1 37x12.5 on 20” Fuel AMP retract runners Anzo front and rear lights Dual Magnaflo exhaust and some other stuff.
    My ‘21 TRD Sport is done 6112F/5160R set at 1.9” front & stock rear.
  8. Sep 25, 2020 at 7:05 PM
    #338
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    My 6112's wore out around 30k. Nice ride, just expected them to last longer.
  9. Sep 25, 2020 at 7:08 PM
    #339
    Hartsy8
    Max
    2020 MGM 1794
    Wow really? I am hearing people getting closer to 90-100k.. do you wheel a lot?
  10. Sep 25, 2020 at 7:40 PM
    #340
    Hartsy8
    Max
    2020 MGM 1794
    Someone talk me off the ledge here!! I just bought a set with 24k on them thinking they had a year or two of life left in them?! 30k can’t be the norm..
  11. Sep 25, 2020 at 10:07 PM
    #341
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    Maybe 10 miles a year on forest roads to go fishing. For whatever reason, they just didn't hold up.
  12. Sep 26, 2020 at 6:41 AM
    #342
    Hartsy8
    Max
    2020 MGM 1794
    Interesting.. I’m interested to have others chime in
  13. Sep 26, 2020 at 6:54 AM
    #343
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    That is not normal at all. I would buy with confidence if the price is right. The “norm” would be more in the 80-100+ range. I’m not even sure what wore out means? We’re they leaking or did this guy just think they didn’t ride as well?
    Either way, they are an excellent shock that should last years.
    Krewcial likes this.
  14. Sep 26, 2020 at 6:56 AM
    #344
    Hartsy8
    Max
    2020 MGM 1794
    I didn’t think so! Was also thinking shoot... looks like I got a terrible deal :bananadead:
  15. Sep 26, 2020 at 6:57 AM
    #345
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    What does “wore out” mean? They were leaking?
    Medinasmoke likes this.
  16. Sep 26, 2020 at 6:58 AM
    #346
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    What did you pay?
    Hartsy8[QUOTED] likes this.
  17. Sep 26, 2020 at 7:43 AM
    #347
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    That doesn't sound right at all. Did performance degrade and/or leaking some fluid? According to Bilstein, oil seepage is 'normal', at least in the case of the 5100s I had on the rear of my truck.
  18. Sep 26, 2020 at 9:17 AM
    #348
    MistrRoboto
    Virginia Beach, VA
    Dude you are fine.
  19. Sep 26, 2020 at 9:50 AM
    #349
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    I bought them when they first came out. Ran them for a little less than 30K before one of them blew a seal. No warranty at that point.
    Was really happy with their road performance and the increased stability. Like any product, stuff happens. I had an Icon seal blow out at 12k and they covered it. As with many products, your YMMV.
    BTBAKER[QUOTED] likes this.
  20. Sep 26, 2020 at 10:57 AM
    #350
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks for explanation. They didn’t wear out then, one had a failure which can happen with any shock. It’s unfortunate there was no warranty there for you though.
  21. Oct 19, 2020 at 5:52 AM
    #351
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    5160s are not adjustable. You will need to install something else to lift rear- shackle, AAL, Leaf kit, block...
    Shuffler likes this.
  22. Oct 21, 2020 at 4:24 AM
    #352
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    :yes:
    Bama Tundra likes this.
  23. Oct 21, 2020 at 5:09 AM
    #353
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    Thought I would post up info for those of us that have the 6112/5160 set up. I have my 6112's at top setting in front. About 1/4" higher in front than rear but not a real visual issue. I just purchased Cooper AT3 xlt all terrains, 295 70R 18. Love the tire and size. Had to remove the front mud flaps, and the install shop is trimming my factory skid plate as the tires hit it on the inside during full turn backup. Just info for those of us who are on the fence or just looking for more info like I was.
    cforman61, equin and pearlpower like this.
  24. Oct 21, 2020 at 5:44 AM
    #354
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Appreciate you posting your info...getting almost the exact same set up installed tomorrow...just wondering what offset you are running on your wheels ?
  25. Oct 21, 2020 at 6:44 AM
    #355
    CavBluTundra
    Howard
    No offset, factory rims TRD Off Road Limited.
  26. Oct 21, 2020 at 7:39 AM
    #356
    tundrasportinMA
    Western Mass
    10-4 , thanks !
  27. Oct 21, 2020 at 10:48 AM
    #357
    CavBluTundra
    Howard
    Here she is with her new shoes! 6112's top setting front; 5160's rear, nothing else. Murica!!
    equin, iyaman, drobb and 4 others like this.
  28. Oct 21, 2020 at 3:36 PM
    #358
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Looks great ... can't even tell it's a tad higher in front. The bigger tires fill up the wells nicely - great choice.
  29. Oct 23, 2020 at 3:32 AM
    #359
    iyaman
    iyaman New Member
    2016 platinum
    I'm trying to buy the 6112/5160 kit. Any reputable seller of site you guys recommend? Thank you. You guys tundras looks awesome!
  30. Oct 23, 2020 at 3:34 AM
    #360
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    Darren at Boss-offroad
