Assembled Bilstein 6112s - great all around buy for the leveler in us all?
Discussion in 'Suspension' started by MistrRoboto, Nov 17, 2017.
  1. Sep 12, 2020 at 7:18 AM
    #301
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Haha yeah lots of options. This seems to be the most affordable and actually provides some improvement as well. You didn’t have enough of a delta angle to need a diff drop?
  2. Sep 12, 2020 at 7:58 AM
    #302
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    TRD pro comes with 2” of lift and has nothing to change the axle angles. At 1.9, you’re technically lower than an oem provided lift. I’m at 1.9 and my angles barely changed.
    BTBAKER and Hartsy8[QUOTED] like this.
  3. Sep 12, 2020 at 8:03 AM
    #303
    Hartsy8
    Max
    2020 MGM 1794
    That’s what I like to hear! Thanks!
  4. Sep 12, 2020 at 8:40 AM
    #304
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    I went ahead and did the diff drop back when the 5100s went on - was cheap & easy enough to do. Might make more of a difference when the 6112s go on at the #4 setting ... guess I'll find out and report back when the install is done.
  5. Sep 12, 2020 at 8:43 AM
    #305
    Hartsy8
    Max
    2020 MGM 1794
    I mean no harm in doing it right?
  6. Sep 12, 2020 at 8:46 AM
    #306
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Nope ... mechanic said it wasn't really necessary, but having it there wasn't going to hurt anything. Plus it's done for later when it might be needed. This was like 60k miles ago ... zero issues.
    Hartsy8[QUOTED] likes this.
  7. Sep 12, 2020 at 8:49 AM
    #307
    Hartsy8
    Max
    2020 MGM 1794
    Sounds like I’ll be doing both then
  8. Sep 13, 2020 at 3:50 PM
    #308
    clarkritchie
    clarkritchie New Member
    Would 6112s be stout enough to support the weight of a steel front bumper and winch and still maintain a mostly level stance (on a '21 Limited CrewMax)?
    And would 6112s pair OK with the factory TRD Offroad rear suspension -- maybe for the short term. Long term maybe adding 5100s or 5160s, an AAL or shackles in the rear for a bit more support when towing/hauling.
  9. Sep 13, 2020 at 6:14 PM
    #309
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I did the drop, but it was probably unnecessary. I went through three sets of CV axels on my FJ with a 3in lift and that left a bad taste in my mouth.
  10. Sep 13, 2020 at 6:16 PM
    #310
    MistrRoboto
    Virginia Beach, VA
    Definitely yes to the second question - it rides excellent with the stock rear. Maybe someone more expierenced can answer the first. I’m certain you would drop down lower than whatever someone without the heavy number would have. If I had a question like that I’d call Boss 4x4 (Darren) and ask.
    clarkritchie[QUOTED] likes this.
  11. Sep 18, 2020 at 5:23 AM
    #311
    Saab95v6
    Saab95v6 New Member
    Can anyone point me in a direction, what shop would install the 6112 on my 2020 platinum, PA NJ area , also where to purchase the 6112?
  12. Sep 18, 2020 at 5:33 AM
    #312
    Hartsy8
    Max
    2020 MGM 1794
    Would it be bad to put the diff drop on now with a level in anticipation of a future lift in the rear that might change the angles more? Any I’ll effects of a possibly unnecessary drop?
  13. Sep 18, 2020 at 6:17 AM
    #313
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Had that discussion with my mechanic when I put the 5100s on at the top setting; he said not necessary, but I went ahead and did it anyway. That was almost 10yrs ago, no issues since. It's also very easy to do, so you don't necessarily have to do it until the time comes; it was about a 15min job.
  14. Sep 18, 2020 at 6:33 AM
    #314
    Hartsy8
    Max
    2020 MGM 1794
    Awesome man thanks for the reply. Thats what I am thinking I will do. I just dont want to induce additional wear by trying to be extra cautious haha
  15. Sep 18, 2020 at 6:35 AM
    #315
    ccress83
    ccress83 Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    I see alot of posts about 1.9 setting with shim +2 Driver +1 Passenger, and leaving rear alone. How much lift is that for the front. I have a 3/1 LRO level and will be upgrading to the 6112/5160 setup but I want to bring my truck back down alittle bit. So has anyone ran 6112 +1 Driver and nothing on passenger? And I will be getting rid of 1" block on rear and putting 1" shackle probably unless that will be too much rear lift with the 1.9 setting. Thanks have a good day.
  16. Sep 18, 2020 at 6:44 AM
    #316
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Any pics out there of the 6112’s set at 1.3 with the OEM TRD Off-road wheels?
  17. Sep 18, 2020 at 9:56 AM
    #317
    Hartsy8
    Max
    2020 MGM 1794
    Bringing this back.. AGAIN! Ha. Grabbing this combo set at the third clip. If I want to maintain factory rake and not touch the rear should I look at moving to the 2nd clip?
    BTBAKER likes this.
  18. Sep 18, 2020 at 10:53 AM
    #318
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    I'm running the 6112's @ 1.9 with a single shim on the driver side. Kept the stock 4600's from the TRD OR package in the back. It was about dead level with that setup when measuring, but it looked just a bit sagged to me. So I added a +1 CB shackle (which is .625" actual lift) in the rear and I'm happy with it.
    ccress83[QUOTED] likes this.
  19. Sep 18, 2020 at 10:56 AM
    #319
    Hartsy8
    Max
    2020 MGM 1794
    This is why I’m thinking I might set them at 1.3
    CaptainGrumpus likes this.
  20. Sep 18, 2020 at 7:32 PM
    #320
    MistrRoboto
    Virginia Beach, VA
    You can’t raise the front any height, leave the rear alone, and have “factory rake”. 1.3 setting would leave you with some rake but less than factory. 1.9 has my front and rear within millimeters of each other (level). I’d have to raise the rear an inch to get rake again. When I have something heavy in the bed it is slightly sagged, but not offensive.
  21. Sep 18, 2020 at 7:38 PM
    #321
    Hartsy8
    Max
    2020 MGM 1794
    Thanks for the reply! Yeah I mis spoke about “factory” rake. I would just like to maintain some rake period. Good to know! And forgive me I’m sure it’s been mentioned. Did you do a diff drop?
  22. Sep 18, 2020 at 7:41 PM
    #322
    MistrRoboto
    Virginia Beach, VA
    I did do it. Seemed like cheap cv axle insurance to me, but I also recognize that the TRD Pro comes with a 2in lift up front and no diff drops. I had a 3in lift on my FJ cruiser and replaced the cv axles multiple times due to boot failure.
  23. Sep 18, 2020 at 7:44 PM
    #323
    Hartsy8
    Max
    2020 MGM 1794
    Yikes! Yeah pretty strange the pro doesn’t do it from the factory. I’ll probably still do it at 1.3
  24. Sep 18, 2020 at 9:45 PM
    #324
    BLK1794
    BLK1794 New Member
    Ontario, Canada
    ‘17 Toyota Tundra 1794
    Procomp 7” Stage 1 37x12.5 on 20” Fuel AMP retract runners Anzo front and rear lights Dual Magnaflo exhaust and some other stuff.
    Great thread!
    My ‘21 TRD Sport Premium Just arrived and I am waiting for a set of 6112&5160 to come in next week. I will be setting the front to 1.9”, but I am not sure about the rear. I will be putting a ARE cap on so it might sit a little lower. I am thinking of adding +1” to the rear. Would anyone have a pic of that setup with a cap? Thanks in advance. My 1794 sits pretty level, but that has a 7” Procomp on it.
    pro2amendment, jr1016 and Hartsy8 like this.
  25. Sep 19, 2020 at 10:28 PM
    #325
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I used Liquid Iron Industries and they were great. Good pricing and did a stellar job. Based out of West Berlin, NJ
    Mcoop and biebs96 like this.
  26. Sep 20, 2020 at 4:21 AM
    #326
    biebs96
    PA
    im also curious what shops you guys are using
  27. Sep 20, 2020 at 8:32 AM
    #327
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Most paved interstates/highways are built with a crown for water drainage. The slight drivers-side lean of some vehicles was designed to compensate for that, so that it is actually level on crowned surfaces.
    I'd asked this question loooong ago, and that was the explanation I got. Not sure if that's the case with Tundras, but it kinda makes sense.
  28. Sep 22, 2020 at 5:09 PM
    #328
    Hartsy8
    Max
    2020 MGM 1794
    How many miles is everyone getting out of this set up?
  29. Sep 23, 2020 at 4:22 AM
    #329
    CaptainGrumpus
    Maine
    6112’s at 1.3 are what I’m settling in on now after a lot of pondering. Are aftermarket UCA’s needed to get my alignment in check?
  30. Sep 23, 2020 at 4:39 AM
    #330
    MistrRoboto
    Virginia Beach, VA
    Not needed. Best I can tell they are something to consider as you get past 2.5-3 inches of lift. Mine aligned just fine at 2.
