Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 2, 2023 at 4:19 PM
    #2761
    gunshipz
    gunshipz New Member
    Kevin
  2. Apr 2, 2023 at 4:33 PM
    #2762
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wynnded likes this.
  3. Apr 2, 2023 at 6:33 PM
    #2763
    gunshipz
    gunshipz New Member
    Kevin
    Will do. Do you know if the 5.7 geometry is such that the piston could hit a valve if the timing was off?
  4. Apr 2, 2023 at 7:32 PM
    #2764
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes, valve and piston contact can happen.
    Wynnded likes this.
  5. Apr 3, 2023 at 10:44 AM
    #2765
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Front driver side brake is slow to release. When i back out of parking spot, i can feel it still holding for a second after i release pedal to go forward. No other drivability issue. Not dragging. Seems to grip evenly under hard braking. Truck has 125,000 miles.
    I cleaned and greased slide pins a few months ago just because it was easy during tire rotation but that didn't make a difference.
    Would you expect it to get worse over time if i do nothing?
    My next thought is to remove pads to clean in caliper around pistons. Then put fresh grease on pistons and back of pads. (The purple ceramic grease)
    Is there something else i should be checking?
  6. Apr 3, 2023 at 11:36 AM
    #2766
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Completley remove the caliper pad retaining pins and remove the pads. Remove the caliper retaining bolts and remove the 8mm bolt that holds the flex hose in place then set the caliper on a box so it's not hanging on the flex hose. Wire brush the area where pads sit and apply a thin coating of silicone grease. Clean the pins and coat them the same way. Push the caliper pistons back. Becareful to push back all four pistons at the same time or you may have a Piston pop out. Reinstall everything g and makes sure the pads move freely. Do the same on the other side.
    Don't leave it because it will only get worse.
  7. Apr 4, 2023 at 7:21 PM
    #2767
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    The dealership says there is no problem with the truck.
    Tech says it’s normal to experience slow engagement if the truck sits for longer than a week.
    The tech refused to place the truck in gear immediately after starting. He said it’s necessary to allow the truck to run for about 15 seconds before placing it in gear.
    The truck is now back at home and will sit for a few weeks. I’ll try allowing it to run for about 15 seconds before placing it in gear.
  8. Apr 4, 2023 at 9:31 PM
    #2768
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How many owners wait 15 seconds after starting before placing the transmission in gear? Very few would and there are very few complaints on a new truck with slow trans engagement.
    Sometimes when you go to the dealership with a problem that would take time to diag they tend rather wait and see. Toyota corporate pays nothing to the dealer for diag and they are reluctant to charge the customer. It really is a loosing situation for the dealership dollar wise.
  9. Apr 6, 2023 at 8:06 AM
    #2769
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Good points.
    Thank you for the insightful information. Must be tough for dealerships.
    I’m sure I’ll be happy with the slow engagement. Easy to live with.
    Ruggybuggy[QUOTED] likes this.
  10. Apr 11, 2023 at 3:02 PM
    #2770
    Bobfun81
    Bobfun81 New Member
    I have a 2011 Tundra 5.7 FF that's not getting fuel. It started and ran just fine when I left work the other morning and when I went to leave again that afternoon, nothing. Didn't even try to fire. It would start with a blast of fluid in the throttle body but only enough to burn it off. Fuses good, swapped relay...I'm guessing that control module on the frame rail just based off internet searching and the fact that I had one go to crap on a Ford I had once....but like I said I'm only guessing. Can anyone steer me in the right direction on troubleshooting, it makes me sick to think about paying to tow this thing 40 miles and paying shop rate while they poke around for several hours if it's something I can isolate.
    Thanks
  11. Apr 12, 2023 at 4:23 PM
    #2771
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Reach up and unplug the connector at the fuel pump. Check for power and ground at the connector. If you have no power, older Tundras had a problem with the wiring harness from the pump to the control module. It's unlikely that the fuel pump or module are the issue. You don't have to drop the tank to diag or change our the harness.
    French Avocado and Wynnded like this.
  12. Apr 12, 2023 at 5:11 PM
    #2772
    Bobfun81
    Bobfun81 New Member
    Can I check this with the key turned on or do I have to have someone turn it while I'm under there?
  13. Apr 12, 2023 at 6:52 PM
    #2773
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Test for power when the key is first turned on or when the engine is cranking. If you can get access to Techstream there is a utility that activates the pump.
    Wynnded and Mike59 like this.
  14. Apr 12, 2023 at 8:20 PM
    #2774
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Icon stage 7, Dobisons rear springs and track bar, Icon Rebound Pro wheels, MT Baja Legend 40s, JB4, Pedal Commander, AFE intakes and hot pipes
  15. Apr 13, 2023 at 4:10 AM
    #2775
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    T-MAC[QUOTED] likes this.
  16. Apr 13, 2023 at 4:50 AM
    #2776
    Retired...finally
    I would scour the owner's manual for any mention of having to wait after starting before putting the transmission in gear. But it's not in there.
    Mike59 likes this.
  17. Apr 18, 2023 at 1:53 PM
    #2777
    bdoland
    bdoland New Member
    Brady
    2016 Tundra Pro
    Stock
    Hi Everyone,
    Excited to be part of this forum and just bought my dream truck a 2016 Tundra Pro.
    Unfortunately off to a bad start as the original owner had it detailed before I bought and now its throwing a B1788 code and B1650 (airbags) code. Dealership wanting to charge me $1800 to get it fixed.
    This is what they said:
    Confirmed light on and seat belt light flashing, scanned for codes found codes B1788, B1650
    tried performing sensitivity test and failed. tried also performing zero point calibration and failed which leads to recommend replacing passenger side bottom seat frame and occupant classification ecu. sent parts request for pricing.
    Parts are :
    Passenger front side bottom seat frame assembly…..517.80
    Occupant classification ecu ……489.01
    Labor = 624.00
    Subtotal
    Diag = 124.80
    Labor 624.00
    Parts 1006.81
    1772.81 plus taxes.
    I tried looking for loose wires under seat and none. Any help would be greatly appreciated!
  18. Apr 23, 2023 at 9:53 AM
    #2778
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Update: Incase it helps anybody else.
    After the truck sat for more than 15 days, I let it run for about 15 seconds before placing it in gear.
    It engaged immediately.
  19. Apr 25, 2023 at 7:08 AM
    #2779
    Robtmj
    Robtmj New Member
    Robert
    2010 tundra 4X4
    Can anyone tell me the location of the bak up light relay on a 2010 tundra?
  20. Apr 25, 2023 at 8:29 AM
    #2780
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    In the fuse block in the engine compartment on the driver side. There should be a layout diagram on the inside of the cover. I thought that I saw that relay on the upper right hand corner of the diagram.
    Edit: I had to go out to the truck, so I looked. I didn't recognize a relay specifically for backup lights. Now that I think about it, aren't the just fused?
  21. Apr 25, 2023 at 4:54 PM
    #2781
    Robtmj
    Robtmj New Member
    Robert
    2010 tundra 4X4
    I concur no relay in the E/bay fuse box, but as long as I was there I checked them all for continuity. All good. The wiring diagram show a relay but no info on the location. The fuse for the B/U lights is only 7.5Amp. and the wiring diagram shows that it is only for the relay exciter circuit. I found an on line diagram that shows the relay under the dash above the throttle. But here is nothing there (of any kind). I guess I'll have to check with the dealer next time I go to town. BTW all fuses good. Thanks for the help.
    Slim Gym likes this.
  22. Apr 27, 2023 at 4:20 AM
    #2782
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have a 19 tundra with 53k and the rack and pinion went out...Toyota claims common on lifted trucks. I have toytec coilovers so I'm probably sitting at 3inches. I would think oversize tires a bigger deal. I have 295/70/18 on stock rims. Now that I'm going thru this...fortunately they are covering the repair. My question is other than going completely back to stock which I won't do is there anything else I can do to help avoid a repeat? Like a coachbuilder steering kit?
  23. Apr 27, 2023 at 11:46 AM
    #2783
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
    Did Toyota change something about the wiring in 2021 (and possibly earlier) models. Just want keyless entry on my 2021 SR and cannot get low priced keyless entry system to work. Can get wiring working to lock/unlock manually but once I hook up keyless entry using both wiring choices neither works.
    More specifically bought this system
    https://www.amazon.com/gp/product/B088D7R8LG/
  24. Apr 27, 2023 at 4:00 PM
    #2784
    Robtmj
    Robtmj New Member
    Robert
    2010 tundra 4X4
    Toyota Mech:
    I'm trying to locate the B/u light relay on my 2010 4X4. It's apparently not in the engine bay fuse box. Can you help?
    Thanks to Wynnded for the lead
  25. Apr 27, 2023 at 5:16 PM
    #2785
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've seen it in the EWD, but I'll be darned if I can find anything to tell us where it's positioned on the vehicle....:notsure:
  26. Apr 28, 2023 at 4:59 PM
    #2786
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    Found an oil leak and started a thread.
    https://www.tundras.com/threads/oil-leak.123689/#post-3173900
    Are any mechanics on here familiar with this particular leak? If not I’ll start taking the accessories off of the front of the engine to make sure I know where it is. But I’d rather not if I don’t have to.
    thanks in advance for any and all help.
  27. Apr 30, 2023 at 4:01 PM
    #2787
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    Well, I am moving I tread I started at the 2nd Generation Tundras to this page, so here it goes:
    Nice to meet you forum members. My older son passed away a little over a month ago, and left behind a truck that he treasured, so I plan to take care of it and drive it very little. Anyway, this truck is a 2013 Tundra double cab with an 8-cylinder 5.7L engine that has 2 pending trouble codes number P0012, and P0022. The BlueDriver scan tool shows them as follows:
    P0012 "A" Camshaft Position-Timing Over-Retarded Bank 1 (this has been a permanent code)
    P0022 "A" Camshaft Position-Timing Over-Retarded Bank 2
    P0012 Code: The fixes from other owners reporting the codes have been replacing the engine variable valve (WT) timing solenoid. P0022 Code: The fixes have been replacing the engine variable valve timing (WT) solenoid.
    The scan tool also directs to the parts replaced by other owners, found at Amazon as: 15330-0SO10. I could replaced the two solenoids, which I believe are located by the front edge of the engine cover, but still have to figure the exact locations Edit: already know the locations.
    Any ideas why these codes would show? The oil and filters were replaced about a week of two (Mobil 1 0W-20, 8-quarts,Toyota oil cartridge), the engine does not burn oil, nor the oil level low. However, I have noticed that the oil pressure gage's pointer on a cold start takes a few minutes to rise to the middle or normal. And it happens gradually as the engine temperature gage's pointer rises from cold to the middle or normal mark.
    I just feel that the oil pressure should rise rapidly instead of being so slow. But once the engine is at normal operating temperature, I can turn it off and restart before it is completely cold, and the oil pressure rises as it should.
    sider64 likes this.
  28. May 1, 2023 at 5:58 AM
    #2788
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
  29. May 2, 2023 at 9:47 PM
    #2789
    Gatofeo22
    Gatofeo22 New Member
    Tee
    2007 tundra SR5
    Stock
    My 2007 tundra 4.7 over heated. Blew off reservoir cap no other visible hose burst anywhere. I replaced water pump,thermostat,fan clutch, radiator cap and lower radiator hose At idle engine runs at normal temperature no problem but as soon as engine RPM increases lower radiator hose collapses ..I've replaced all I can think of.. any advice
  30. May 3, 2023 at 2:28 PM
    #2790
    Rwolf5500
    Rwolf5500 New Member
    Raymonf
    2003sr5tundra
    Stock
    You have an air pocket in the system
    Bprose likes this.
