Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jan 15, 2016 at 1:03 PM
    #241
    Emily
    Emily New Member
    Emily
    Mississippi
    2015 Toyota Tundra Crewmax 4x4
    Weathertech mats, Line-x bed liner, 5% tint
    @LOTSOFTOYS Thank you for answering all of our questions!!! So I'm looking into getting the 4 1/2 in BDS lift on my 15 CM. Is that something Toyota can install or would i need to take it to another shop? Thanks again!!!
  2. Jan 15, 2016 at 6:33 PM
    #242
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    The 4.5 is a drop bracket right? I've never done one, not a big fan... I'd say a different shop, but u could ask for a quote?
    Sefferston likes this.
  3. Jan 16, 2016 at 10:14 AM
    #243
    Emily
    Emily New Member
    Emily
    Mississippi
    @LOTSOFTOYS well i got my answer today. Drove to the nearest toyota dealership for an oil change and tire rotation. I asked if they installed any lifts and they said no, they also said that if you come in with after market rims they won't rotate them either due to the fact that if they mess up the rim they don't want to have to replace it, or in the case the rims aren't made anymore having to pay for 4 new rims.
    Also I've decided to go with the Toytec Boss lift. Thanks for the info!
    csuviper and T-Rex266[OP] like this.
  4. Jan 16, 2016 at 10:47 AM
    #244
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Wow, clearly that dealer has had some issues with aftermarket parts... hell, I did two lifts his week lol
    And great choice on lift!
    T-Rex266[OP] likes this.
  5. Jan 16, 2016 at 6:14 PM
    #245
    Emily
    Emily New Member
    Emily
    Mississippi
    haha thanks!
  6. Jan 16, 2016 at 6:27 PM
    #246
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    How's the reliability and do you know of any issues with the new highlander?
  7. Jan 16, 2016 at 7:43 PM
    #247
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Not a whole lot yet... same power train as previous years for the most part. Should be a solid vehicle. I personally hate the look, but that's my opinion.... too much like a Ford explorer.
  8. Jan 16, 2016 at 7:52 PM
    #248
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    My wife has the 2016 Highlander. She wouldn't have one if there were issues.
  9. Jan 20, 2016 at 1:11 AM
    #249
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    @LOTSOFTOYS
    Here is a video of what I'm talking about.
    http://youtu.be/eaPlzhnuOuU
    I don't know if this is normal but after shutting off my engine tonight heard a buzzing type sound coming from underneath my truck(turned off a few seconds later). So I started/shut off the engine again I went under the truck to pin point the sound. It's coming from the transmission oil pan. I put my ear on the pan and can hear it inside. After a few seconds or more I hear a click then it turns off.
    It's not the normal fan like noise and it's not coming from the back of the truck.
    Any ideas?
  10. Jan 20, 2016 at 12:27 PM
    #250
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    I just went to the dealership and the mechanic was looking for the air pump and when he found it he said its normal.
    LOTSOFTOYS likes this.
  11. Jan 22, 2016 at 12:04 PM
    #251
    2416
    2416 New Member
    Have you heard of the AIP system doing that sound on older gen tundras? With that odd sound after turning off the truck?
  12. Jan 22, 2016 at 12:14 PM
    #252
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Ur talking after you turn the truck off? The air pumps clear the lines for a second or two?
  13. Jan 24, 2016 at 1:18 AM
    #253
    2416
    2416 New Member
    Is that what it is? I've just read that it's a normal noise clearing out moisture or something?
  14. Jan 24, 2016 at 8:19 AM
    #254
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    No not the air pump. It happens during the air pump but when the air pump stops there is the sound which i posted in the video. You can crawl under the drivers side, put your ear on the trans. oil pan and hear the sound inside. I even put a stethoscope to it.
    It's not the pump because I put the stethoscope on the pump and it wasn't making noise.
  15. Jan 24, 2016 at 8:21 AM
    #255
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Pretty sure my window motors are going out...takes 4 or 5 taps to get the drivers side window to go fully down with the auto down. Any input? Passenger side goes down retarded slow.
  16. Jan 24, 2016 at 12:17 PM
    #256
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yeah I don't think that is normal. I hear the air pump, but that buzz is something else.
  17. Jan 24, 2016 at 12:20 PM
    #257
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    It did it on a brand new truck at the dealer also. I'm sure yours does it if you drive it around the block then turn off the engine. Put your head under the truck near the trans oil pan and listen once the pump stops. "buzz/Hummmm"
  18. Jan 24, 2016 at 12:52 PM
    #258
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Hey LOTSOFTOYS, I have a '13 TRD, 5.7L. It has a slight pull to the right going down the road. I brought this up to the service guy on one of my 5K scheduled service trips and he said this was normal for the TRD's. It doesn't feel or sound normal. Is this normal??
  19. Jan 24, 2016 at 1:47 PM
    #259
    DB444
    DB444 New Member
    2015 Tundra Pro Inferno
    I have two questions. My 2016 Pro radio and GPS won't work until the cabin warms up if it's cold outside. Do you think this needs looked at?
    What's the best locker for the Tundra rear?
  20. Jan 24, 2016 at 2:49 PM
    #260
    TruckyTruck
    Gary
    Sorry man, mine does not do that. There is only the air pump sound.
    Unless mine is so quiet I don't hear it. I've been outside of my truck plenty of times after oil changes. No sound like that.
  21. Jan 24, 2016 at 4:40 PM
    #261
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds like the person you talked to doesn't like his job, he's a liar. Ask locally to find a quality alignment shop to have it looked at. Check the tire inflation as well. My truck will pull on some very specific sections of road, but I know it's the road, make sure that's not what you're experiencing.
    Looking at it won't help, you should be watching the road. LOL. Vehicles are an unfriendly place for electronics, but unless it's brutally cold, in the neighborhood of -20F, they should work pretty normally after five or ten minutes after being powered up.
    My favorite locker would be an ARB Air Locker, they're not cheap though.
    DB444[QUOTED] likes this.
  22. Jan 24, 2016 at 4:59 PM
    #262
    jfrd30
    2013 TRD Tundra
    Thanks buddy, I really appreciate your help!!!!
    I know it's not the tire pressure or section of road, so I guess I'll be looking around for an alignment shop. Sadly the 4 Toyota dealerships around here all suck ass and can't be trusted. I know their not all that way, but around here they are for some reason.
  23. Jan 24, 2016 at 8:06 PM
    #263
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Can't say I've ever heard that noise before man... odd
  24. Jan 24, 2016 at 8:09 PM
    #264
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No, like stated above^ trd non trd doesn't make a vehicle pull.
    What do u mean the radio won't work? Literally it won't come on? Black screen?
    And I'm not familiar with lockers for tundras, but the ones I've worked on woth lockers all have been arb
  25. Jan 24, 2016 at 9:15 PM
    #265
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    Sorry i didn't notice you had a 2005. Might be diff on the newer ones.
  26. Jan 24, 2016 at 9:28 PM
    #266
    ? He's a Toyota mechanic....
    And FWIW, mine hasn't done that no matter how cold we are at the time.
  27. Jan 24, 2016 at 9:42 PM
    #267
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    It's not related to how cold it is(warm engine shut off). I tested a new one at the dealer and it did the same thing... Maybe it's a 2015/2016 thing or just a 2016 thing. I will go to a different Toyota and try another truck tomorrow.
    I'm not trying to offend him in anyway. I am just reporting back what I have discovered. I'm not a Toyota mechanic but I know my way around cars. I was trying to see what it was or if anybody else actually heard it or even paid attention to it.
    @Boozer posted his makes the same noise also.
    :bananadance: <<<< Could even be this guy inside messing with me lol
  28. Jan 25, 2016 at 8:22 AM
    #268
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    Just another thing to consider, Had a level kit and 4 Cooper mud tires put on my 2013 Crewmax. Noticed it too had a slight pull even though they aligned it at the dealer. Took it back and they swapped sides with the two front tires and it went away. Maybe that will help you.
    jfrd30[QUOTED] likes this.
  29. Jan 25, 2016 at 10:11 AM
    #269
    jfrd30
    2013 TRD Tundra
    Thanks, I'll give that a whirl and let you know what happens!
  30. Jan 25, 2016 at 3:59 PM
    #270
    DB444
    DB444 New Member
    The radio or GPS won't come on at all until the cab warms up.
