Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 7, 2022 at 8:21 PM
    #2581
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you have the service records of what fluids have been changed? If not then I would suggest a coolant change which should be done every 5 years. Do and inspection of the diff fluids and transfer case fluid. Also check the date code on the tires which is the last four digits of the DOT number. First two number is the week of manufacture and the last two is the year. Anything over 5 years you should consider replacement. Check the brake fluid for water. You can buy test strips from any parts store. Check the power steering fluid, it should be a gold color if it's the original fluid. If it's dark consider a flush.
    AstroDude and Blue Thunder like this.
  2. Apr 8, 2022 at 3:55 AM
    #2582
    Thomas4x4
    Thomas4x4 New Member
    Thomas
    2008 Toyota Tundra SR5
    Yes it was the full exchange done at the dealer and it has just over 188k miles. However, the fluid exchange has been done a few times before. They used some machine that hooks up to cooler lines and replaced all the old fluid with new fluid and they added conditioner. Is this different from power flushing? I had a technician at the dealer check the fluid level and at first he was thinking it could just be a quart low. He just drained the fluid to see how much came out and put some back in.
  3. Apr 8, 2022 at 5:11 AM
    #2583
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would want to verify that the level is correct using the method Toyota specifies which requires using Techstream. I would also do a health check using Techstream to make sure there are no issues. The delay that your experiencing can happen on higher mileage transmissions. As parts wear it takes a little longer for fluid pressure to build resulting a slightly longer engagement. If your worried about it you could have someone take the pan down and inspect for debris in the pan and make sure the filter screen is clean. Personally I would just leave it if you know the level is correct and the health check showed no problems.
  4. Apr 8, 2022 at 5:18 AM
    #2584
    Thomas4x4
    Thomas
    Definitely makes sense on a higher mileage transmission. Would this mean that I may need to replace or get the transmission rebuild at some point if the parts are wearing?
  5. Apr 8, 2022 at 5:26 AM
    #2585
    Il0kin
    Il0kin New Member
    2012 Tundra
    I sure do, definitely should have looked last night before posting but I was comfortable in bed!
    Standard oil changes every 5k
    July 2013 - fresh fluid in front and rear differentials and transfer case
    New tires in 2014, but they have no signs of dry rot or anything
    Thank you, this is great!
    Ruggybuggy[QUOTED] likes this.
  6. Apr 8, 2022 at 5:31 AM
    #2586
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    I'm a mechanic, well it has been a few moons but I can handle all of your F-15E needs :oldglory::plane:
  7. Apr 8, 2022 at 5:37 AM
    #2587
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Everything has a service life and can only last so long. It's tough to know when something is going to fail. It comes down to how it was serviced and how the transmission was used. Someone that tows frequently will have a shorter trans service life than someone that doesn't.
    Thomas4x4[QUOTED] likes this.
  8. Apr 8, 2022 at 5:43 AM
    #2588
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How often should I service my trunnion bearing on the demultiplexer?
    :monocle:
    AstroDude likes this.
  9. Apr 8, 2022 at 5:50 AM
    #2589
    icodeintx
    Scott
    Palacios, Texas
    Every 1.65220010101 Months :hattip:
  10. Apr 8, 2022 at 7:28 AM
    #2590
    AlumBody
    AlumBody New Member
    Hello to all on Tundras.com,
    We are an aluminum truck bed manufacturer and recently picked up a low mileage 2011 CMSB Grade 5.7 4x4 for research and development (read: to play with). Long story short, the previous owner/their mechanic did some less than stellar repairs. After fixing their uh-oh's, it was time for the fun stuff i.e. Optitron gauges, drive monitor switch, ultimately leading to a front end conversion. Upon installing the drive monitor switch, it was discovered that 2 wires from JL1 to J28 were needed and subsequently installed using the correct pins for the harness connector. Finished the job, go to start truck and.............nothing. Not even a click. Literally followed every single starting procedure/wire checking continuity and signal all the way from the ignition to the ECU, all good. Starting relay, good. Battery, new and good. Assuming that I crossed or damaged something while pinning the harness for the drive monitor switch, I located a Tundra at a junkyard and went and picked the entire J28 down to the JL1 with the drive monitor switch wires already present! Also pulled the starting relay as a test/backup. Spliced the entire new J28 and JL1 connectors into our truck, plug everything back in and.............nothing. No start, same condition. Now to the fun part, while installing the 2 wires the first time, we un-installed an aftermarket trailer brake controller installed by the previous owner. Figuring we had nothing else to lose or try, we plugged the trailer brake harness (not the controller, just the harness!) back into the truck and BAM, fires right up. Unplug it, same no start condition. Called the manufacturer of the brake controller and talked to three separate tech support persons and none had any idea why this would be the case!
    Therefore, here we are, any Tundra experts out there know why the truck would not start without an after market trailer brake controller harness plugged into the factory connector?
    Thank you in advance for your best guesses!
    AlumBody Team
  11. Apr 8, 2022 at 7:40 AM
    #2591
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So after successfully replacing my rack and pinion, ps pump (one of them failed a while back not sure which one) axles and knuckles I noticed this today. The left side seems to be good while the right side seems to not be in all the way.
    Not sure how it happened, I only drove the truck 3 miles since the replacement. No oil is coming out.
    My question: Am I good to bang that axle back in by using a pry bar on the metal lip of the axle? Or do I have to disconnect everything again (caliper, rotor, take the axle out of the knuckle) to do it?
    I would assume there's enough movement in the axle to allow me to get that axle dust boot cover flush with the surface.
  12. Apr 8, 2022 at 8:54 AM
    #2592
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you have Techstream? Plug in the brake controller and run a health check with Techstream.
  13. Apr 8, 2022 at 9:04 AM
    #2593
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Use your hand and see if you can move the axle in and out. My concern is that the C clip may not be on the axle shaft. Did you smear the CV axle shaft and C clip with some grease to help center the clip before you reinstalled? If you sure the clip is in position then a good strike on the metal lip with a pry bar and hammer should set it in place without removing everything. Check it after a few miles.
    AstroDude[QUOTED] likes this.
  14. Apr 8, 2022 at 9:24 AM
    #2594
    AlumBody
    AlumBody New Member
    Thank you Ruggybuggy for the suggestion. We don't currently have Techstream. If we can't figure it out without going that route we will definitely look into it!
    AlumBody Team
  15. Apr 8, 2022 at 9:42 AM
    #2595
    AstroDude
    Eddie
    The axle doesn't move when I try and I put some grease on one but no the other. Can't remember which side. I'll give the pry bar a shot to see how it goes. Thank you for all your help.
  16. Apr 8, 2022 at 2:06 PM
    #2596
    justcuz
    justcuz 2.5 Gen Member
    2018 Tundra Off Road how can I make the "beep" louder when I use the remote to lock or unlock the truck?
  17. Apr 8, 2022 at 2:41 PM
    #2597
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm sure you can do it but I don't recall. Have a look in the owner's manual or maybe someone else can chime in.
  18. Apr 8, 2022 at 4:38 PM
    #2598
    justcuz
    Vehicle must be running and in gear
    Setup
    Scroll down to Vehicle
    Vehicle Customization
    Door Lock Settings
    Scroll down to Lock/Unlock Feedback Tone
    Press down arrow and it displays a minus & plus bar
    I changed mine from factory 5 to 7 (highest)
    Volume should now be at its highest volume.
  19. Apr 8, 2022 at 6:34 PM
    #2599
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I took my 2012 in for an oil change and was told that Toyota didn't recommend greasing the fittings at this time. I started looking online to find the fittings and the only reference I can find is to the driveshaft. Are there fittings on the suspension parts?
  20. Apr 8, 2022 at 6:38 PM
    #2600
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There are not.
  21. Apr 8, 2022 at 7:10 PM
    #2601
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You need to get more involved in answering a few of these. :D
    Wynnded[QUOTED] and JMB like this.
  22. Apr 9, 2022 at 8:53 AM
    #2602
    NickG
    NickG New Member
    Nick
    2009 Toyota Tundra Limited DC 5.7L
    Now that I have my AIP issue fixed, do I ever have to worry about this happening again? Pumps for bank 1 and 2 replaced, new valves, new hose, snorkel cover, clamp, pipe gaskets. Problem was water intrusion.
  23. Apr 9, 2022 at 9:02 AM
    #2603
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Imagine that would depend upon how long you keep the vehicle.
    Nothing lasts forever.
    Ruggybuggy likes this.
  24. Apr 9, 2022 at 9:10 AM
    #2604
    Thomas4x4
    Thomas
    Why yes, the system can fail again. Why do you think some people just get the bypass kit and move on?
  25. Apr 9, 2022 at 3:45 PM
    #2605
    AstroDude
    Eddie
    Here's the movement. It doesn't move any more than that. I took a pry bar with a soft mallet and gave it a couple taps but it still moves. No oil leaks while moving it. I'll just keep an eye out.
    Hopefully dust didn't accumulate with the front diff while off reading.
    https://youtu.be/ykpll9kkkzQ
  26. Apr 9, 2022 at 5:00 PM
    #2606
    COTundie
    Trey
    Pretty things
    Not a Toyota, but a pretty fun journey into the mystery of the disappearing brake pad!
    Think I can just hit those pistons with some emery cloth and be back in action. There is also a couple thousandths left on the backside of that rotor, so maybe we can just turn them.
  27. Apr 9, 2022 at 9:14 PM
    #2607
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Once the clip is in the mating groove there shouldn't be any movement like you're showing. An easy way to check it would be to jack the truck and support it on the frame and let the control arm hang. Undo the two large bolt that go into the knuckle. Pull the strut assemble out a bit and see if you can pull the axle out of the diff by hand. If it slides out the clip is missing.
  28. Apr 9, 2022 at 9:19 PM
    #2608
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is no way your going to be able to reuse the rotor. Rotors are cheap. Caliper should be replaced but I'll leave that up to you.
    I'm guessing a GM product? Tahoe?
  29. Apr 10, 2022 at 7:27 AM
    #2609
    COTundie
    Trey
    Pretty things
    It's ALL getting replaced. I don't take any chances with bakes.
    You know your GM products sir! It's a 2002 Tahoe.... And my friend is still alive and with us, thankfully.
    He was very close to losing those pistons, along with braking function/pressure.
    I have another buddy (a couple decades ago) who wore completely thru his rotors to the vanes/vents. But this is the first I've seen a brake pad just entirely gone. There were a couple shredded steel bits which May have been the remainder of the backing plate.
  30. Apr 10, 2022 at 7:51 AM
    #2610
    COTundie
    Trey
    Pretty things
    Yep.
    Looks like there's possibly a circlip sitting at the bottom of your differential housing.
    I would probably see about sourcing one just to be prepared for reassembly.
    I got lucky after accidentally tearing out my front axle. Was able to compress the circlip with my fingers, rotate the axle back and forth till the splines seemed aligned, then inserted the axle as far as I could by hand. I hear the "opening" of the circlip should be facing downward for ease of installation, but I did not know about this and it seems to have worked out just fine.
    Drive it home with your pictured prybar and 3lb lump of hammer.
