Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Oct 28, 2021 at 11:41 AM
    #2311
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Just trying to find all the options, but thank you again for all the info!! Might be time to sell the truck unfortunately :notsure:
  2. Oct 28, 2021 at 11:53 AM
    #2312
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    had discount tires check out the sensors all good they were reading for about a day and then the malfunction occurred and this has happened twice.. am i needing to rewrite the new id with techstream if they use a hand held device that they use for those tpms sensors
  3. Oct 28, 2021 at 12:43 PM
    #2313
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Are the sensors Toyota? Did they give you the ID numbers? You can use Techstream to program the ID numbers and it will show you the information of each sensor. We did have a new hand held scanner at the dealership that was pretty cool. You would scan all the tpms sensors then plug it into the OBD2 and it would automatically update the info to the module. Unlikely Discount Tire would have such a thing.
  4. Nov 2, 2021 at 6:40 AM
    #2314
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    LCA squeaky at cam adjustment area.
    Last alignment 5000 miles ago.
    One cam tab getting worn, of course.
    Alignment fellow tightened super tight to lessen possible movement.
    134,000 miles.
    Should I hit with at-205 and then silicone or lithium grease or replace bushing?
  5. Nov 2, 2021 at 6:58 AM
    #2315
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Replacing the rubber bushing in the control arm is something that is rarely needed. If the bushing rubber is good I don’t recommend you change them. They are very difficult to do. Depending where you live Tundras and Tacomas have issues with the cam bolts seizing up. Some alignment techs tend to just crank the cam trying to get the numbers and bend the tab. Cam tabs don’t wear out because there is no movement there. If the cams are seized the control arms should be removed and new cams installed.
    Are you sure the noise is from the lower control arms bushings? Squeak noises are usually from dry ball joints.
    Hightide[QUOTED] likes this.
  6. Nov 2, 2021 at 7:10 AM
    #2316
    Hightide
    Abalama
    Magic School Bus
    Im in Alabama.
    Last month I did some off roading in the mud.
    I did pressure wash everything but pretty sure I didn’t hit that area too hard.
    The tab is slightly bent from a previous alignment.
    I plan on doing TC gussets and/or Bison Offroad cam kit.
    My first thought was ball joints as well.
    I did grease everything and inspect the most common areas.
    Camburg UCAs
    But I didn’t notice the noise from that area in general.
    I climbed underneath yesterday evening and had the truck shaken back and forth to determine the area of noise.
    It was fairly distinctive when I was underneath.
    I guess hitting it with some spray lube would be my next step to see if that at least stops the noise.
  7. Nov 2, 2021 at 7:17 AM
    #2317
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check and see if you don’t have any small stones caught between the control arm and mount. If the cam tabs are bent it’s likely the cams are seize. The cams should move freely. Hitting the bushing with lube would help determine if the noise in that area. I would just use some WD40. Some lubes can deteriorate rubber bushing. Rubber bushings are designed to operate dry.
  8. Nov 2, 2021 at 7:46 AM
    #2318
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just another thought. Remove your front skid plate and see if the noise goes away. Sometimes dirt and small stones get trapped between the skid plate and frame and makes noise. It’s very common with the TRD skid plate.
  9. Nov 2, 2021 at 8:13 AM
    #2319
    Hightide
    Abalama
    Magic School Bus
    Thank you!
    I’ll check those things.
    My skid is RCI
    would a silicone or lithium grease be better?
    I always thought WD-40 would shorten the life of rubber.
    But I guess WD-40 will wash off.
  10. Nov 2, 2021 at 8:19 AM
    #2320
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes the WD40 would just wash off. You would just use it to diag. Silicone spray if you plan on doing it religiously.
  11. Nov 2, 2021 at 8:29 AM
    #2321
    Hightide
    Abalama
    Magic School Bus
    Thanks again!
    I’ll get on it and see what I get.
    Ruggybuggy[QUOTED] likes this.
  12. Nov 2, 2021 at 6:24 PM
    #2322
  13. Nov 2, 2021 at 7:30 PM
    #2323
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    To find the location of the pins in the connector we us Toyota Inforstream at the dealership. I believe you can sign up and use it but there is a fee. Another way is to find another Tundra and check the harness. Maybe someone on the forum could take a picture to help you out.
    Hightide likes this.
  14. Nov 2, 2021 at 7:32 PM
    #2324
    Hightide
    Abalama
    Magic School Bus
    @RainMan_PNW
  15. Nov 2, 2021 at 7:41 PM
    #2325
    @rayjr84z
    rayjr84z and Hightide[QUOTED] like this.
  16. Nov 2, 2021 at 7:43 PM
    #2326
    Not my post, just putting it in the right place.
  17. Nov 2, 2021 at 7:59 PM
    #2327
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    On it...posted response in the original post that Jim linked.
  18. Nov 2, 2021 at 8:08 PM
    #2328
    Red Sonja
    Red Sonja Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    Can you recommend any aftermarket transmissions for an ‘07 5.7 4x4 w/tow package? The local dealership wants to charge $5500+ to put one in. There has to be a cheaper option. I’d rather give my local small shop the business with a quality reman and never deal with it again. The truck only has 145k on it. Thank you and you rule for doing this!!!
  19. Nov 2, 2021 at 8:33 PM
    #2329
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    When I start my Tundra up in the morning, how long should I wait before driving? There is a start up procedure that the engine seems to go through but I can never figure out how long to wait before I ease into driving.
    FYI - I love in Canada, where the weather isn't really warm most of the time.
  20. Nov 3, 2021 at 6:49 AM
    #2330
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    When I first crank mine, the engine revs higher for about 20-30 seconds or so. When it revs down I assume it's good to go. I crank it before doing anything else, so while I am waiting, I put my seatbelt on and get everything else situated. I'm curious about the "official" answer as well though.
  21. Nov 3, 2021 at 12:30 PM
    #2331
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Depending on temp. When it’s -40C I will let it run for about 10 min. On warmer winter days around -10C about 2-5min. A little trick on very cold days is to not turn your steering wheel at all. The PS fluid is like plastic and I think contributes to PS leaking and failures.
    coldcanuk likes this.
  22. Nov 3, 2021 at 12:43 PM
    #2332
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    Is there no synthetic power steering fluid that fixes this issue?
  23. Nov 3, 2021 at 12:59 PM
    #2333
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Doesn't Toyota call for ATF, the same thing that's in their automatic transmissions?
  24. Nov 3, 2021 at 1:52 PM
    #2334
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Are factory overload leafs flat, or can they only be installed one way or flipped?
    Same for the main spring, does it have to be installed with one particular side to the front?
  25. Nov 3, 2021 at 2:12 PM
    #2335
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That what we used at the dealership but it's only a semi synthetic(WS fluid). It would still get thick when cold and anytime we has PS issues was during the coldest months. The gen 1 was really bad for PS leaks.
    Wynnded[QUOTED] likes this.
  26. Nov 3, 2021 at 2:36 PM
    #2336
    Ghillie93
    Ghillie93 New Member
    James
    09' 4x4
    Intake, Headers, Exhaust.
    Hey everyone, is there any chance you guys have a link or source for the 12v motor that's in our 2nd gens 4x4 actuators or something else similar? I've found the original motors info page on the manufactures website ( mabuchi rs-455-3050 ). But can't find any online. I'm close to ordering the entire unit (600$), but if there's a way to replace the motor it could save me big bucks which would be totally sweet. Thank You all!
    joseph_womack likes this.
  27. Nov 3, 2021 at 5:11 PM
    #2337
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Is the motor gone of are the terminals corroded?
  28. Nov 3, 2021 at 6:42 PM
    #2338
    Ghillie93
    James
    09' 4x4
    The motor is shot
  29. Nov 3, 2021 at 6:44 PM
    #2339
    Ghillie93
    James
    09' 4x4
    I cleaned and greased everything else and can solder the terminals back on. Thankfully the rust wasn’t penetrating the metal too bad
  30. Nov 3, 2021 at 7:27 PM
    #2340
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Can you find a used one? Probably the cheapest way to go.
