Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Oct 7, 2021 at 6:17 PM
    #2251
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    I hope not to need it but is there anywhere that can test an ecm other than a dealer and how could i clear historical codes or do they even matter?
  2. Oct 7, 2021 at 7:38 PM
    #2252
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No need to worry about history codes because they are “history”. Why do you want to test the ecm/tcm? What issues are you having?
  3. Oct 8, 2021 at 2:40 AM
    #2253
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    Ok that was my line of thinking. Im not sure yet, im fairly sure its ok but i had read that faulty or missing sensors could damage it. Im missing the back o2s and one or two others i replaced. Im getting all but the o2s corrected and now im thinking the truck has been in limp mode this whole time. Will it come out when i get them cleared up or do you hav to trip it out of limp. I picked up the truck blown and just replaced the motor with a reman and im getting it going now. My plan is to keep it long term. I think i have all the codes figured out but im having to wait on trans filter and vss to come it before i can do much more right now. Over all the trucks in great shape, no corrosion or wire molesting and the interior is in great shape
  4. Oct 8, 2021 at 2:53 AM
    #2254
    CMikeB
    CMikeB New Member
    Hi Dave, I'm stumped about my 2010 DC 4X4, 86,000 miles and a garage queen. I have the same IPT Valve Body with shift kit for several years and a BA Exhaust. I thought my TRD CAI was robbing me of the 'snap' I used to get, so I went back to stock all except the air accelerator that goes in the fender. After fully warmed up, I can't break the tires from a stop like I used to. What would you advise me to look at to get this power back? Thanks for any help , Mike.
  5. Oct 8, 2021 at 5:17 AM
    #2255
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sensors or actuators that are missing will not harm the ecu. Toyota ecu are very reliable. Your going to have to make sure all the sensors are present and working if you want the truck to run properly and without a check engine light.
  6. Oct 8, 2021 at 5:25 AM
    #2256
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I don’t think the TTD CAI is responsible for your power loss. Are you still running the BA exhaust?
    I’m assuming all maintenance items have been looked at (spark plugs, air filter, etc) and you have traction control off? Also make sure the parking brake pivot is not seized.
  7. Oct 8, 2021 at 5:51 AM
    #2257
    CMikeB
    CMikeB New Member
    I just traded my 10" for a 14" BA Exhaust just last week. I had my Park Brake adjusted tighter a while back, maybe I should ask about that, it almost holds the weight of the truck now though. Spark plugs are original but truck idles/runs fine, air filter is good, as was the TRD filter. All nannies are turned off as I buckle up.
  8. Oct 8, 2021 at 6:47 AM
    #2258
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So your running the BA exhaust? Do you have the stock exhaust? Some performance exhaust systems will increase HP but will sacrifice torque to do it. Torque is what gets you off the line.
    Blue Thunder likes this.
  9. Oct 8, 2021 at 7:21 AM
    #2259
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    Thank you much, i didnt want to chase my tail but i was curiuos
  10. Oct 8, 2021 at 7:43 AM
    #2260
    CMikeB
    CMikeB New Member
    You're right about most 'off the shelf' exhausts that use 3 inch pipe. Keith uses the stock tailpipe and stays with stock sized pipe everywhere else. This change happened while the 10" BA system was on for several years. I've unhooked the negative battery terminal to see if it'll help. Might have the spark plugs changed out soon too.
    Ruggybuggy[QUOTED] likes this.
  11. Oct 8, 2021 at 11:01 AM
    #2261
    CMikeB
    CMikeB New Member
    Ordered a new air filter, just changed it and took it for another spin. It might've needed more time for the ECT to re-learn + maybe the air filter was dirtier than it appeared. Seems to be back to normal now! I appreciate your time Dave, thanks much!:thumbsup:
    Ruggybuggy likes this.
  12. Oct 8, 2021 at 11:37 AM
    #2262
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nice, that was easy!
  13. Oct 10, 2021 at 9:48 PM
    #2263
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) what is Tech Stream?
    2.) Do I really need it?
    3.) if I did need it were do I get it?
  14. Oct 10, 2021 at 10:19 PM
    #2264
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    1) On this forum, do a search , there is a thread on it.
    2) Techstream is use to customize certain setting and diag issues you may have with your truck. Only you will know if you need it.
    3) Same answer as 1)
  15. Oct 10, 2021 at 10:22 PM
    #2265
    NueveTundra
    Planet Earth
    I did do a search its what brought me here to this thread :rofl:
    were is this thread , I find 2 pages that come on "What is Tech Stream" an filtering through them they do not offer a answer to my questions. :(
  16. Oct 13, 2021 at 12:01 PM
    #2266
    blackdemon_tt
    blackdemon_tt Battery Slayer
    By any chance do you know if the LX570 calipers are compatible with the Tundra?? they have different part numbers, assuming they're the same, they're 100 bucks cheaper for the pair than Toyotas and are not on back order, nor require the core exchanges..
  17. Oct 13, 2021 at 12:40 PM
    #2267
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry I’m not sure. It’s unlikely they are the same. The casing on the outside may look the same but the piston cup is likely a different diameter. Look up an aftermarket source for both vehicles and see if the part numbers are the same. You can’t do that with Lexus/Toyota parts.
    Wynnded likes this.
  18. Oct 13, 2021 at 2:32 PM
    #2268
    fmscott2
    fmscott2 New Member
    I have a 2014 with the 4.0L V6. Fairly uncommon truck from what I can tell. Toyota didn’t make a ton of V6 equipped 2014s. I’m always a little worried my dealer will not realize it’s the V6 and service it like one of the V8s that normally come in. Is this a needless worry or should I continue to remind the service advisors that my truck has the uncommon V6 engine? Will the average Toyota mechanic notice right away once they pop the hood?
  19. Oct 13, 2021 at 2:34 PM
    #2269
    NueveTundra
    Planet Earth
    all the gen 3's are V6 Turbo :rofl:
  20. Oct 13, 2021 at 2:40 PM
    #2270
    fmscott2
    fmscott2 New Member
    Sorry, meant to say 2.5 Gen. Edited post above. It’s a 2014 (which I always thought was considered Gen 3 o_O).
    NewImprovedRon likes this.
  21. Oct 13, 2021 at 4:44 PM
    #2271
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No need to worry and no need to tell them. The parts for the truck are sourced by the VIN. Every work order has the VIN printed on it and when the parts are supplied by the parts department they go off the VIN.
    NewImprovedRon and Wynnded like this.
  22. Oct 16, 2021 at 7:19 PM
    #2272
    vanhack
    vanhack New Member
    Siddharth
    2020 Cavalry Blue Crewmax TRD Offroad
    Hi I am finally getting my techstream to work. I have the openport 2.0 drivers installed, and checked that they are working. But for some reason techstream version 16 has reduced capability. I installed version 13 and it works fine. I wanted to check the utility section of the techstream by entering a DTC code. P0019 as you know my camshaft and rocker issue from another post, that seems to have been resolved for the last 2 days.
    I have upgraded my laptop to Windows 10 as well now, 64bit, but still version 16 techstream has reduced capability. I assume this is a driver and cable issue, rather than a windows issue.
    what version techstream are you using, version 13 only has tundras upto 2018, I need 2020, I also want to programme a new key for my tundra as a spare, as I like to carry a spare when offroading.
  23. Oct 19, 2021 at 7:40 PM
    #2273
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    a new tpms sensor was installed due to a shop that was installing wheels and tires damaged it any way using techstream to scan or locate that new id without removing tire and wheel???
  24. Oct 19, 2021 at 8:11 PM
    #2274
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did they install a Toyota sensor? You need the ID of the sensor that is printed on the sensor itself. Techstream can’t read a sensor until it know the ID number. The dealer has a hand held reader that is placed next to the valve stem and can read the ID number. Once you have that number Techstream can be used to program the new sensor. Some tire shops can also read the sensor ID.
  25. Oct 19, 2021 at 8:23 PM
    #2275
    FitsofRage88
    Hill Country, Texas
    thanks for the info….
  26. Oct 19, 2021 at 8:28 PM
    #2276
    FitsofRage88
    Hill Country, Texas
    they replaced the part with one from a Toyota dealership but im uncertain as to what part number actually is and not to mention they didn't try to reprogram and they certainly did not give me the information needed to register the new one from what that shop purchased. This offroad shop i will never go back again….
  27. Oct 19, 2021 at 9:00 PM
    #2277
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would ask them if they have a way to scan the sensor and get the ID number. You won’t have to pay if you can get them to scan it. The ID number is different than the part number.
  28. Oct 20, 2021 at 1:15 PM
    #2278
    FitsofRage88
    Hill Country, Texas
    Im curious How long does it take when you see the truck trying to recalibrate… wait till complete…
  29. Oct 20, 2021 at 1:22 PM
    #2279
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Can take up to 20 minutes. You can try letting air out of the tires to wake up the sensors or go for a drive.
  30. Oct 20, 2021 at 3:02 PM
    #2280
    FitsofRage88
    Hill Country, Texas
    It does need to be started up and let ii idle correct?
