Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 15, 2021 at 10:51 AM
    #2191
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    A friend of mine who is also a Toyota master tech also has a first gen Tundra. I remember he disabled the tpms by grounding a wire off the tpms module. Do a google search. Most of the older Tundras with blinking tpms lights are usually a dead sensor battery. Personally I would connect to techstream and figure out what the issue is. Might not be as expensive as your thinking.
  2. Aug 16, 2021 at 7:50 PM
    #2192
    Toyoman2
    Toyoman2 New Member
    As far as error codes...can they be pinpointed to the exact mile they activated though the computer?
    This is important in a warranty discussion with a true Toyota dealership.
  3. Aug 16, 2021 at 7:51 PM
    #2193
    ElCapitanpdx
    ElCapitanpdx New Member
    Dwight
    2013 Tundra Dbl Cab
    Hey @Ruggybuggy,
    2013 Tundra Dbl Cab and the power door locks occasionally don't work. Started mostly with the front passenger but now seems to be something that can affect any of the. Other posts have pointed clearly to bad actuators but those all indicated complete failure, which is not what I have. Is this still likely actuators or more likely electrical given the irregularity? (it's not the fob) Thanks in advance.
  4. Aug 17, 2021 at 3:51 AM
    #2194
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My reader doesn't give a mileage figure like what the odometer read at the time of activation, but it shows how many mile were driven with the MIL/CEL illuminated.
  5. Aug 17, 2021 at 5:49 AM
    #2195
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes I believe so through Techstream but not sure why your worried. If your under warranty and your CEL is on why wait to bring it in? You could always take a picture of the instrument cluster showing the light on and mileage.
    Wynnded and NewImprovedRon like this.
  6. Aug 17, 2021 at 5:50 AM
    #2196
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So all the door locks work perfect from the fob and you only have an issue at the door switches?
  7. Aug 17, 2021 at 6:01 AM
    #2197
    ElCapitanpdx
    Dwight
    2013 Tundra Dbl Cab
    No, same issue can occur when using fob or the interior locking button.
  8. Aug 17, 2021 at 6:21 AM
    #2198
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Which doors do not work? Do they not work on both the unlock and lock? How frequently do they act up?
  9. Aug 17, 2021 at 6:28 AM
    #2199
    ElCapitanpdx
    Dwight
    2013 Tundra Dbl Cab
    Failure happens both ways (lock and unlock). I would say front passenger is the most common and it was initially the only door that had the issue. But within the last couple of weeks I think I have experienced it at one point or another with all 4 doors. My data is going to be slightly skewed though since I use the back doors much left often than the front. I would say that it happens at least 1 out of every 7 or 8 trips.
  10. Aug 17, 2021 at 7:01 AM
    #2200
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you have Techstream? The door lock circuit is controlled by the main body ECU. Because you said that the problem occurs with the fob and from the door switches I would think it unlikely an input issue. Using Techstream could verify this. Do you have a door lock wiring diagram?
    If you dont have Techstream or a wiring diagram I would start by removing the door panels and verifying that there is power to each of the door lock actuators. There are just two wires to each actuator and the polarity switches when locking and unlocking. Use a test light and connect directly to those wires.
    NewImprovedRon likes this.
  11. Aug 17, 2021 at 7:31 AM
    #2201
    ElCapitanpdx
    Dwight
    2013 Tundra Dbl Cab
    I don't have a techstream but I can open up the panel. Are you thinking the wiring may have come slightly loose in some way which is what's causing the problem to be inconsistent?
  12. Aug 17, 2021 at 7:58 AM
    #2202
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Putting a test light on the each connector eliminates the door locks as a possible problem and will allow you to check the wiring in the door. Also with the test light connected you can hold down the switch and with the test light illuminated you can do a wiring harness wiggle test. Grab the wiring harness where it exists the door and goes into the body of the truck and wiggle it while watching the test light. Ice the doors are used often over time the wires can break form the constant bending. The problem is more common on the driver's door.
    To be honest Techstream and a wiring harness would be the best way to diag the problem. It will allow you to work all the door switches and verify the the body module is recieving the inputs. You can also work the actuators and test the circuit from the module to the actuators.
  13. Aug 17, 2021 at 8:35 AM
    #2203
    ElCapitanpdx
    Dwight
    2013 Tundra Dbl Cab
    Alright, thank you for the guidance. Really appreciate it.
    Ruggybuggy[QUOTED] likes this.
  14. Aug 17, 2021 at 9:18 AM
    #2204
    Toyoman2
    Toyoman2 New Member
    Roger to both you and Wynn.
    Thanks for the response!
  15. Sep 10, 2021 at 1:08 AM
    #2205
    vanhack
    vanhack New Member
    Siddharth
    2020 Cavalry Blue Crewmax TRD Offroad
    Hi, I have 2020 Tundra with 10,000miles and a week ago after the car sitting at work for 8 hours, it had a hard start issue, which I managed to start after clearing codes, multiple misifire was one of the codes. Now I have often p0019 and when at moderate to full throttle in gear only, not in park/neutral I get a p0302, which I have to clear the pendind codes and restart the engine.
    I have swapped with existing parts the following, VVT solenoid on exhaust bank 2, VVT sensor with intake on bank 2, coils with cylincer 2 and 4, spark plugs too, and camshaft sensor with one of the VVT sensors as they are the same part. This morning I changed the injector for cyclinder 2 "(where the p0302) points too with cylinder 1 on opposite bank ofcourse. Still I get a p0302 on moderate to hard acceleration out of 4 of these throttle conditions. I also have disconnected battery for 10 minutes, idle 10 minutes AC off, idle 10 minutes AC on, slow driving 10 minutes, and the moderate to full throttle, moderate I mean 4000rpm to 5000rom, full throttle beyond 5000rpm foot to the floor, this is when the p0302 code activates, car runs rough as there is a misfire, but CEL is just flashing and p0302 is recorded, engine runs slightly rough and lacks full power, until I clear the code, restart to reset the VCS/pre-collision faults, which I believe is that ECU turning these off due to the p0302 code as safety measure to the driver.
    Thanks for your help.
  16. Sep 10, 2021 at 5:20 AM
    #2206
    vanhack
    vanhack New Member
    Siddharth
    I don't have warranty, as this is a grey import from Canada, I live in Dubai. Tundras are sold by non dealer importers here.
  17. Sep 10, 2021 at 5:41 AM
    #2207
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That sucks. What are you using to pull codes?
  18. Sep 10, 2021 at 5:43 AM
    #2208
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Tundra tick/rattle
    Well, I tried everything suggested to no avail.
    Then I had one final thing to try before breaking down to diagnose.
    Did an oil change using this.
    So, a short term update.
    After 1500 miles since new oil, no more noise.
    It stopped immediately after switching to the Signature Series and has not made this noise since.
    Maybe, some of the others with this noise could try and see if they can duplicate results.
    Does it make for an expensive oil change?
    Yes.
    Is it worth losing the noise and the peace of mind?
    Absolutely!
    Oey12 and Ruggybuggy like this.
  19. Sep 10, 2021 at 6:00 AM
    #2209
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Many people knock Amsoil for being a boutique snake oil. Clearly they never used it because I have had the same results as you in a few 3.4’s, a Tacoma 4.0, several RAV4’s, and a 4Runner 4.0. It really does get rid of the tick. Amsoil=not having your Toyota sounds like a Mack R series at idle.
    Hightide[QUOTED] likes this.
  20. Sep 10, 2021 at 6:46 AM
    #2210
    vanhack
    vanhack New Member
    Siddharth
    Scangauge 2, and at times a Bluetooth dingle to a android app. I am about to get my cable for techstream but it will be another 10 days
  21. Sep 10, 2021 at 11:11 AM
    #2211
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes you will need to use Techstream to diag it properly. What cable are you buying? They are not all equal.
  22. Sep 10, 2021 at 11:18 AM
    #2212
    Fishhead
    Fishhead New Member
    My experience was exactly the same. This oil change I went to M1 and the tick/rattle came back. Going back to Amsoil next oil change.
  23. Sep 10, 2021 at 6:42 PM
    #2213
    vanhack
    vanhack New Member
    Siddharth
  24. Sep 12, 2021 at 6:58 AM
    #2214
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  25. Sep 12, 2021 at 7:45 AM
    #2215
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
  26. Sep 13, 2021 at 1:59 AM
    #2216
    vanhack
    vanhack New Member
    Siddharth
    What are the limitations with the one i have out of curiosity?
  27. Sep 13, 2021 at 8:55 AM
    #2217
    vanhack
    vanhack New Member
    Siddharth
    Hey I got the cable today, and after installing version 10, which did not work due to the drivers I had, then installed version 16 and used the drivers supplied and it works. When it fires up it does say that all the functions are not available, and I can work in offline mode. But I was able to get to the active tests, clear codes....but p0019 keeps coming back!!!!!
    Anyhow this software is a monster, and loads to learn. But I am curious as to what will not work though with the cable i have. I incedently used firmwire version 1.4.8 for the driver.
  28. Sep 13, 2021 at 12:35 PM
    #2218
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    sone of the engine data doesn’t show up. Some testing is not available.
  29. Sep 13, 2021 at 1:38 PM
    #2219
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    2021, Tundra Limited:
    The Brake Warning Light comes on for no apparent reason when traveling down the road. I sometimes notice a new small piece of pavement that might be the cause, but not always. Is there a calibration or adjustment the dealer or I can perform?
  30. Sep 13, 2021 at 6:21 PM
    #2220
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Techstream would have to be used to do a healthcheck and check for any codes. The dealer isn’t capable of doing any kind of calibration. There may be a software update that might address the problem and it will be displayed when the healthcheck is done. Be prepared to be able to duplicate the problem when you bring it in.
