Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jul 28, 2021 at 10:08 AM
    #2161
    Tundy19
    Tundy19 New Member
    Devin
    Kailua-Kona
    2019 Black Platinum
    I would think something like that as well... I find it odd the dealership went straight to replacement rather than diagnose further...
  2. Jul 31, 2021 at 1:24 PM
    #2162
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    The question I have is I have noticed the rear sway bar in many photos at different heights along the differential. Some under, some just along lower edge and some seem half way up.
    What is the correct position on the Tundra?
  3. Jul 31, 2021 at 1:34 PM
    #2163
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ideally you want a right angle between the links and the bar. People that have a suspension lift will change the orientation of the bar on the differential in an effort to maintain that relationship.
    Some sway bars have adjustable links to make this happen so that the original intended mounting orientation of the sway bar is maintained.
  4. Aug 1, 2021 at 1:36 PM
    #2164
    T-bone Tundra 63
    T-bone Tundra 63 New Member
    2019 Tundra limited
    Backflip tri-fold bed cover Go rhino running boards
    So I just installed OEM remote tailgate lock. Disconnected the negative cable before I started . Finished installing kit and replaced negative cable. Went to start and it started fine but shut off a few seconds later. I restarted multiple times immediately and it never stalled again. So I guess my question is that a normal response after disconnecting battery? Was thinking it could be a computer reset .
  5. Aug 1, 2021 at 2:13 PM
    #2165
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  6. Aug 1, 2021 at 2:14 PM
    #2166
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's exactly what it was.
    NewImprovedRon likes this.
  7. Aug 1, 2021 at 2:17 PM
    #2167
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Yep, mine does that every time I disconnect the battery..
  8. Aug 1, 2021 at 2:28 PM
    #2168
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    What’s the mechanics thought on that banks pedal monster discussed in another thread?
  9. Aug 1, 2021 at 4:52 PM
    #2169
    T-bone Tundra 63
    2019 Tundra limited
    Ok. Thanks. Never had any other vehicle do that . Appreciate the quick response.
  10. Aug 14, 2021 at 8:59 AM
    #2170
    French Avocado
    Utah / Wyo
    @Ruggybuggy - My 2008 blower motor is not producing much air. Sounds like it is on at full speed yet there is little air coming out of the vents. (and with the heat it is bad news). Any ideas?
  11. Aug 14, 2021 at 12:37 PM
    #2171
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Pull the cabin air filter out and see if it improves. Some aftermarket filters can restrict flow. Any unusual smells? Evaporator can grow mold which can block the airflow. Make sure the drain isn't plugged. If you think it may be plugged there are cleaning sprays you can buy specifically to clean the evaporator. I would also pull the blower motor out and check for obstructions and motor condition. It very easy to do. Just three screws and a connector and it falls right out.
  12. Aug 14, 2021 at 1:05 PM
    #2172
    French Avocado
    Utah / Wyo
    Thanks I will will try all of the above and let you know if it works. You are the best! I hereby grant you a lifetime subscription to this forum!
    NewImprovedRon and JMB like this.
  13. Aug 14, 2021 at 2:29 PM
    #2173
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sweet!
  14. Aug 14, 2021 at 2:47 PM
    #2174
    French Avocado
    Utah / Wyo
    The cabin air filter that I was told was checked 8,000 miles ago and 2,000 miles ago is black and full of leaves. Problem solved! Thank you for your expertise. Just ordered a new cabin air filter.
    For knowledge and experience, I went ahead and dropped the blower fan. It appears the last tech to have worked on it did not properly screw one of the three screws into the hole on the other side - thus, only two screws holding it up. It was otherwise fine.
  15. Aug 14, 2021 at 6:22 PM
    #2175
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nice to see it solved. It was a good thing to check the blower regardless. Sometimes when checking the cabin air leaves and other debris can fall down onto the blower and it's a good opportunity to clean the fan.
  16. Aug 14, 2021 at 6:56 PM
    #2176
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Ruggy, did you get your truck back yet after that last setback?
  17. Aug 14, 2021 at 7:17 PM
    #2177
    peterska1
    peterska1 New Member
    Kyle
    2016 tundra platinum
    Hi I’m a relatively new tundra owner what mods would you recommend for someone who’s new to all this. I’m not scared to get into anything too involved and I’m here to learn so I’d appreciate any advice. I have a 2016 tundra platinum and I’m looking
    To get the most I can out of it.
  18. Aug 14, 2021 at 7:23 PM
    #2178
    French Avocado
    Utah / Wyo
    Not the right thread for mod suggestions. Follow this link to the mod list https://www.tundras.com/threads/tundra-possible-mods-diy-updates-add-ons.757/#post-12663 or click on the Mods & Tutorials tab at the top of the page. Mods are highly dependent on how you use your truck, the look you prefer and how many thousands of dollars you can spend.
    GODZILLA likes this.
  19. Aug 14, 2021 at 8:05 PM
    #2179
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I did. They put in a new transfer case but the noise was still there. I took it back to them and said I wouldn't pick it up until the noise was gone. They have been swapping out between my truck and the service managers to find the offending part. So far they have done both driveshafts, both CV axles and front diff. Next they said they are putting in new front wheel bearings.
  20. Aug 14, 2021 at 8:17 PM
    #2180
    TILLY
    Massachusetts
    Wow, that's crazy. Hope they figure it out soon and get you back into your truck.
  21. Aug 14, 2021 at 9:12 PM
    #2181
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's definitely getting old. It's been two weeks without the truck. I will need it the day after labour day. RV holiday for two weeks.
    JMB and TILLY[QUOTED] like this.
  22. Aug 15, 2021 at 5:42 AM
    #2182
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    The Hellwig bar is adjustable. I'm not sure about the pretty little red TRD bar though.
    Wynnded[QUOTED] likes this.
  23. Aug 15, 2021 at 6:08 AM
    #2183
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Correct on the Hellwig from what I've read here from those that have it. The TRD does not have adjustable links.
  24. Aug 15, 2021 at 6:32 AM
    #2184
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The service manager said they should have it back to me before then. It would have been nice to have a loaner but nope, nothing was offered. I did complain to Toyota corporate about not having the truck and just got "we are so sorry this is happening" but nothing else. I asked if they would extend the power train warranty if the problem can't be found but couldn't get a answer. Customer service just kept repeating they were sorry and the dealer should get it solved. WTF.
  25. Aug 15, 2021 at 7:09 AM
    #2185
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    given everything is installed correctly....
    how much positive displacement boost can a 5.7L hold semi-reliably?
    I'm guessing 8.5lbs...or ~600 hp .. not driven like a juvenile.
    What is the opinion of the Toyota Mechanic...or other semi-qualified soothsayers?
    what are the weak spots?
    Wynnded likes this.
  26. Aug 15, 2021 at 7:41 AM
    #2186
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    As a Toyota technician that isn't something that is experienced and the dealership level but I'm sure someone else can answer the question.
  27. Aug 15, 2021 at 7:43 AM
    #2187
    18" TRD Off Road Wheels
    I'd be asking Keith @dirtydeeds as he has lots of knowledge on modding these trucks, and he's humble enough to tell you if he doesn't know.
  28. Aug 15, 2021 at 7:43 AM
    #2188
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This may be better directed toward @ViktorG and/or peruse his YouTube channel and threads that he has here on the board.
    2mchfun likes this.
  29. Aug 15, 2021 at 8:52 AM
    #2189
    Cybertek
    Cybertek 67 Tons of Romping, Stomping mean!
    William
    Pensacola, FL
    2006 Tundra Double Cab 2WD SR5
    None
    So, I have read numerous versions and fixes for the "Blinking TPS' issue. Short of paying lots of money for unneeded IMO TPS sensors do you have any legit recommendations to hide this blinking light forever?
  30. Aug 15, 2021 at 8:57 AM
    #2190
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    On the first gen there’s a wire you can cut and disable the TPMS light for good
    Don’t know it off hand, but it’s documented
    Wynnded likes this.
