Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 25, 2021 at 8:24 AM
    #2131
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I replaced the big antenna with a stubby. But it does have the satellite radio antenna on the roof.
  2. Apr 25, 2021 at 5:05 PM
    #2132
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    Ok, to phrase it better... the play in the center bearing is like "throwing a hotdog down a hallway" loose.
    Cg13055 likes this.
  3. Apr 25, 2021 at 5:39 PM
    #2133
    T-bone Tundra 63
    T-bone Tundra 63 New Member
    2019 Tundra limited
    Backflip tri-fold bed cover Go rhino running boards
    This might be a stupid question but just got my second oil change done on my tundra and I happened to notice that when accelerating the oil pressure gauge goes from 1/2 to 3/4. Is that normal? I haven’t noticed it before. When cruising at a normal speed it stays steady at 1/2. Just wanna make sure the des,er didn’t over fill or do something stupid.
  4. Apr 25, 2021 at 7:49 PM
    #2134
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    An increase in oil pressure when the engine is under load is normal, as long as it stays in the safe range and returns to its standard position once the load is decreased.
  5. Apr 25, 2021 at 9:04 PM
    #2135
    B33
    B33 New Member
    Ok so my problem is driving me crazy. I have a 2007 4x4 Limited. I had the falling break pedal the truck would stop but the peadel once stoped it would sink to the floor. checked for leaks and found none so I was thinking the MC was bad and since the truck is a 2007 with 125k I changed it out for a New Toyota MC. The pedal feels 100% better but still feels like its soft, so I bleed the system a second time and it was good for a few days then went back to the soft spongy pedal so I did a bleed and there was Air in the lines for the 3rd time what am I missing I know Im bleeding them correct whats my next step thanks for any help
  6. Apr 26, 2021 at 9:37 PM
    #2136
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    I’ve got a 2013 with less than 10k miles. Appears garaged and everything runs well (exactly as it should for the nearly new condition).
    My question is all of Tundras services except brake fluid are based on mileage intervals; given the age of the truck are there services that I should perform based on time rather than mileage? I don’t think any service has ever been performed other than an oil change.
    Thanks so much in advance.
    NewImprovedRon likes this.
  7. Apr 27, 2021 at 4:15 AM
    #2137
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Wow! Did you buy it as a collector?!?
    Cg13055 and GayFish like this.
  8. Apr 27, 2021 at 8:25 AM
    #2138
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    No I bought it 6 months ago. An elderly couple used it once a week to make dump runs.
  9. Apr 27, 2021 at 1:39 PM
    #2139
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Great find!!!!
    Tundra2010&60 likes this.
  10. Apr 29, 2021 at 5:55 PM
    #2140
    TNCountrygal
    TNCountrygal New Member
    Lenoir City, TN
    2014 MGM 4X4 1794 Tundra
    Good evening. I had my wheels & tires replaced yesterday at Discount Tire. They had to put new TPMS in since the old ones wouldn't fit correctly. The light was on when I left, but they said to call or come back if it didn't go off & they would fix it. It was flashing when turning the truck on and then staying on after driving about 30 miles, so I went back today and had them try to do a relearn. The guy told me the computer wouldn't communicate with my OBD2 port. All the dash lights were flashing when he plugged it in, but he said it wouldn't communicate. I can't imagine that my ECU is fried... Is there something else you suggest trying before I have to go to the dealership for a re-flash? The thought of a fried ECU makes me sick! :( 2014 1794 Tundra 4x4. Thanks.
  11. Apr 29, 2021 at 9:17 PM
    #2141
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Thanks man!!
  12. May 1, 2021 at 10:35 PM
    #2142
    dylanschmarr
    dylanschmarr New Member
    dylan
    2013 White creamax
    6 inch procomp lift fox suspension 35x12.5 toyo open country a/t
    I have a question about my Tundra. So for starters i recently installed a bully dog platinum tuner on my truck and sense then i have been having some issues.
    First and main issue is when i am accelerating in the lower gears once the RPMS pass 4500 the engine stops producing power but still continues to rev up.
    Second problem is I would like to learn how to download aftermarket tunes to my bullydog to increase hp and economy.
    Any help would be greatly appreciated
  13. May 3, 2021 at 1:35 PM
    #2143
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    To follow up on this, I did replace the center bearing. It really needed it bad. However, the actual problem was broken teeth on the rear diff ring gear.
    Wynnded likes this.
  14. May 3, 2021 at 5:59 PM
    #2144
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Cause? From the adjoining two teeth it appears something got in the gear.
    Cg13055 likes this.
  15. May 3, 2021 at 6:03 PM
    #2145
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ouch!
    YardBird likes this.
  16. May 25, 2021 at 8:02 AM
    #2146
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Did this ever get resolved or figured out?
  17. May 26, 2021 at 4:02 AM
    #2147
    War Machine
    War Machine SSEM # 5 3MW
    Yeah, he got it figured out somehow. Don’t remember what they came up with.
    GIN•OKUMA[QUOTED] likes this.
  18. May 26, 2021 at 4:35 AM
    #2148
    GIN•OKUMA
    Fish
    26.57°
    I was wondering if it was the Skid Control ECU. Or if something else resolved it. Having the same issues here.
  19. May 26, 2021 at 4:45 AM
    #2149
    War Machine
    I can ask, but I think he ended up finding someone who had the right machine to bleed them. I don’t remember anything about the ECU. I do know he never managed to get the warning lights to go off.
  20. May 26, 2021 at 4:57 AM
    #2150
    GIN•OKUMA
    Fish
    26.57°
    Sound about right :D
    no worries I was just wondering. I got the lights to go off but not sure if the’ll stay off. :notsure:
    :fingerscrossed: They do
    War Machine[QUOTED] likes this.
  21. Jun 4, 2021 at 8:00 PM
    #2151
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    I guess I could slide under mine to find out, but does anyone know if the 2021s have zerks you can grease? Thanks
  22. Jun 4, 2021 at 8:04 PM
    #2152
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I'm pretty sure that all the newer models are zerk-free. I think I have seen that posted here somewhere. Some have even posted that they replaced OEM parts with after-market parts with zerks.
  23. Jun 4, 2021 at 8:34 PM
    #2153
    Giskk
    Giskk New Member
    Mississippi
    Appreciate it!
  24. Jun 5, 2021 at 8:59 PM
    #2154
    Tcueva42
    Tcueva42 New Member
    Tristyn
    2008 green tundra trd 5.7
    Just a quick question looking for an answer I have a 2008 Toyota Tundra 5.7 and the tranny started slipping a couple weeks ago plugged in the scanner and solenoid A and D came up today I replaced them the truck ran fine when I test drove parked it for 2 hours and went to reverse and reverse was acting as neutral and neutral was another drive what could be the issue?
  25. Jun 12, 2021 at 3:33 PM
    #2155
    PinnacleX
    PinnacleX New Member
    Bart
    2020 TRD Off Road
    Have you gotten any complaints on the ac clunk when you turn it on after its been sitting?
    2mchfun likes this.
  26. Jun 19, 2021 at 2:11 PM
    #2156
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Asking for guidance as I will be starting some long trips.. my water pump started leaking or has been leaking.... how long could I have before it goes? My original blue chunks 210k miles ago.. I need to make a business run tonight should I risk it, or take my back up? The streak just behind the crank pilley
  27. Jun 20, 2021 at 7:40 PM
    #2157
    dhbrown
    dhbrown New Member
    2019 TRD Pro, black
    To preface I've never owned a V8 before. Always small trucks: '81 22R standard, '90 3.0L Ex Cab, '98 3.4L Tacoma... And now a 2019 Tundra TRD Pro 5.7L. I like to think I know a good noise from a bad one -- I've blown head gaskets, CV joints, etc.
    Anyway, since I've owned my TRD Pro it's made this noise (see video)... A sort of clack clack w/ the revolution of the motor. It only does it at around 1400 rpm when the truck is more or less coasting up a mild hill. I really notice it when I'm in 4 Low... Maybe because I always wheel w the windows down, idk. But now that I've noticed it, I can't stop noticing it... And it's driving me crazy.
    Is it normal? Is it the timing chain? I kinda thought a seal, but I can't hear it if I give it more juice... Of if the rpms are fast/slow.
    Check video here -- https://photos.app.goo.gl/tkAaPcCEVG2FesML6
    Thanks!!
  28. Jul 27, 2021 at 6:33 PM
    #2158
    Tundy19
    Tundy19 New Member
    Devin
    Kailua-Kona
    2019 Black Platinum
    Anyone know much about early 2000s Lexus'?
    Picked up a used 06 gs300 couple months ago as a daughters first cat. Ran and drove great, really started liking it more myself!
    I've read about their issues and recalls and thought I had a gem... Until recently... It developed a hard downshift from 2nd to 1st coming to a stop... Not unheard of in that gen GS world...
    I keep seeing that it's computer related but the Toyota dealer diagnosed it needed a new transmission at the tune of $6600 (in Hawaii so wasn't THAT surprised...). I don't even think the thing books at that anymore? They said they tried reprogramming the trans computer with no luck... Maybe it's bad?
    Anyway, just wondering if someone had more info to maybe save me some money...
    Gonna be looking into other quotes, but don't want to throw in a new (used) trans and have it be the ECM...
    Thanks for any help!!
  29. Jul 27, 2021 at 8:07 PM
    #2159
    SouthWestGA
    SouthWestGA New Member
    Im not an expert but perhaps a new solenoid and complete fluid change will help?
  30. Jul 28, 2021 at 10:03 AM
    #2160
    KHunter11
    KHunter11 New Member
    Glenwood Springs, CO
    2010 Gold Tundra DC 4x4 TRD 5.7L flex
    none
    Any reason I should not just let Grease Monkey replace the driveline fluids/differentials, trany fluid and flush radiator on my 2010 Tundra DC TRD with 104k miles.
    Just seems time for these fluid change outs. Is there something they would do different I should think about. Seems an economical choice…Not realy into paying dealer for such basic things at a much higher cost…
    UPDATE, i did not use grease monkey. used a very reputable local foreign auto repair shop.
