Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Dec 10, 2015 at 12:08 PM
    #181
    MotoTundra
    MotoTundra The Ocho
    Don
  2. Dec 12, 2015 at 7:16 PM
    #182
    greynolds2012
    greynolds2012 New Member
    Greg
    Mississippi
    2012 White TSS 4wd CM
    Leveling Kit, Interior LED Kit, LED Puddle Lights
    Lots of Toys I have a question for you! I have a 2012 Tundra Crew Max 4wd and have a 2.25 spacer leveling kit in the front and also have 275/55/20 all terrain tires. The question that I have is my truck is pulling pretty bad to the right and I have had it aligned at Firestone and took it back to have them recheck it because it was still pulling. So I took it back today for the third time due to the fact that it is wearing out my new tires due to the alignment issue and the guy told me today that it could be the tire size because the door sticker says 285/55/20 and when I bought the truck it had 275/55/20 so I put back what was on there. Is this true and if not what could it possibly be causing the pulling issue? Thank you
  3. Dec 12, 2015 at 7:57 PM
    #183
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    They are yanking your chain. Post a picture of the alignment print out
  4. Dec 13, 2015 at 6:33 PM
    #184
    greynolds2012
    Greg
    Mississippi
    They finally have got it taken care of. It was a bad tire from the manufacture so they are getting me new tires. Thanks for all of your help
  5. Dec 14, 2015 at 11:07 AM
    #185
    EdgeWater175
    EdgeWater175 New Member
    2008 Toyota Tundra 4x4 - CrewMax Limited
    Thanks for the reply. I checked the coolant levels and everything is normal. I was running the heater the other day to dry up the carpet and the water was gushing from the bottom right side of the truck again. Far more than I have ever seen when the truck is running with the AC on. I tried the same with the AC and typical small pool of water on the driveway in the center of the truck is not there.
    Is it possible my air conditioner drain is clogged and this is causing the build up under the carpet?
  6. Dec 14, 2015 at 12:48 PM
    #186
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Could be... a/c is ran during defrost as well so keep that in mind
  7. Dec 14, 2015 at 5:59 PM
    #187
    greynolds2012
    Greg
    Mississippi
    I have another problem now with my 2012 Crewmax 4wd! It seems to be that the transmission is slipping now because when it is cold the truck will not hardly shift you have to let off the throttle to get it to shift and the whole truck starts jerking with the RPMs going up and down. But when it warms up it seems to be ok I guess. The truck just doesn't feel right. Is there anything wrong with the transmission or something different
  8. Dec 14, 2015 at 6:18 PM
    #188
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Not sure man... check engine light? I'd have a dealer check it out and maybe do a drain and fill
  9. Dec 14, 2015 at 7:25 PM
    #189
    greynolds2012
    Greg
    Mississippi
    Yeah I took it this afternoon to the dealership and will keep y'all posted
  10. Dec 14, 2015 at 8:17 PM
    #190
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Wow, that doesnt sound good. Hope all is well. Trannys are costly.
  11. Dec 14, 2015 at 8:21 PM
    #191
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Skidmarks, Xray10, jfrd30 and 2 others like this.
  12. Dec 14, 2015 at 8:49 PM
    #192
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @LOTSOFTOYS When it's "cold", doesn't the transmission stay in a lower gear (and avoids converter lock up) to slightly elevate the engine RPMs for the purpose of warming the engine quicker?
  13. Dec 15, 2015 at 9:47 AM
    #193
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah for more reasons than that. When it's cold it runs far different than when it's warm
  14. Dec 15, 2015 at 11:06 AM
    #194
    greynolds2012
    Greg
    Mississippi
    Yes it does but I don't think that the jerking is normal
  15. Dec 16, 2015 at 7:42 PM
    #195
    greynolds2012
    Greg
    Mississippi
    I finally talked to the service department today after 3 days of calling them. They told me that they had no clue or idea what is wrong with my truck. So now I have no idea what to do about the situation at hand. Any suggestions from anyone
  16. Dec 16, 2015 at 7:57 PM
    #196
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Did they duplicate it?
  17. Dec 17, 2015 at 8:04 AM
    #197
    greynolds2012
    Greg
    Mississippi
    Now they're saying that it may have trash in the transmission and wants me to pay $350 to have the transmission flushed and they're not sure if it is going to fix it or not
  18. Dec 20, 2015 at 6:24 PM
    #198
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Is it under warranty?
  19. Dec 21, 2015 at 4:48 PM
    #199
    greynolds2012
    Greg
    Mississippi
    Yes sir it is under warranty. I purchased it as a certified pre owned with a 100k mile warranty
  20. Dec 22, 2015 at 1:11 PM
    #200
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Tell them to flush it then. U are having issues with it, hence the warranty... atleast try, they may rely on saying it's a maintenance item
  21. Dec 22, 2015 at 7:59 PM
    #201
    greynolds2012
    Greg
    Mississippi
    They told me that I had to pay for it out of my pocket that it is not covered under warranty and I really don't have the extra money at this point and time see it being Christmas and with 3 kids (Ages=20,14,8 and a 43 year old wife which is the worst). I am going to take it to another dealership and have them take a look at it to get a second opinion
  22. Dec 23, 2015 at 8:29 AM
    #202
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Ok keep us informed
  23. Dec 28, 2015 at 6:36 PM
    #203
    greynolds2012
    Greg
    Mississippi
    I have another question LotsOfToys. They told me that the transmission was low of fluid. Can this make my truck act up like it has been doing?
  24. Dec 29, 2015 at 12:45 AM
    #204
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah fluid level affects alot
    Virgils12 likes this.
  25. Dec 29, 2015 at 5:42 AM
    #205
    greynolds2012
    Greg
    Mississippi
    Ok thanks for your knowledge and help
  26. Dec 29, 2015 at 8:51 AM
    #206
    bigsapz
    bigsapz New Member
    Beast
    Hey LotsofToys, it's so cool of you to offer help and guidance to us all. GREATLY appreciated!
    How familiar are you with CK LED BULBS and CK sockets on these Tundras?
    For the life of me I cannot get my 3157 CK LEDs to dual function. They either just stay on as DRLs or do not come on at all. I have aftermarket LED/HALO headlights and have already tapped them into the DRLs. I also have the 6ohm load balancers tapped into the DRLs.
    Can I not run both the led 3157 CK bulbs and the LEDs & Halos off the DRLs?
    Thanks so much for any info
  27. Dec 29, 2015 at 3:59 PM
    #207
    Fitz19d
    Fitz19d New Member
    2015 5.7 SR5 Tundra
    Black wheel dip. Prodigy P2 Brake Controller
    Glad I jumped in this thread as I didnt see it's own post elsewhere. Long thread on this on the other big TT forum. Some thoughts @ TruckyTruck as far as them doing the 2 speed fuel pump, I'd think that might be an issue if you ever want to FFV supercharge? Thought I was reading in the ffv sc threads you used stock pump as the one in the kit wouldnt fit? Just something I'd have to be cautious about but wondering if no SC plans that indeed would be a mechanical way to tell the FFV ECU to fuck off with the e85.
    LOTS of toys. I'm @ like 11k Miles, If I bring my truck down to use up my 15k Toyo care in the next couple thousand. (Previous owner used up the 5 early and I did the 10 at like 7.5) Aside from the basic stuff as part of the 15k, could I easily schedule an appt to have you personally look at/do a few things or recommend a tech for it? I need that Service bulletin for the ffv as I've been having the scary cold starts. Also been noticing in the cooler weather that sometimes I'm peppy and fine on the road, but other times doesn't seem like a hill yet acceleration is pretty sluggish unless I'm really putting the pedal down fairly heavily. (Vs the soft touch most of the time.)
    Was also interested in some post of yours where you had recommended some suspension or other parts that get opened up and greased so they don't wear out for an expensive repair at 100 something k miles? Sorry I'm forgetting what it was but hope that rings a bell.
  28. Dec 30, 2015 at 6:48 PM
    #208
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm not familiar with those bulbs sorry.
    Yes just ask the receptionist when u call Stevinson west and ask when I work. They have my schedule. Then just request me. That's fine... warranty work doesn't pay us well, so be nice please;)
  29. Dec 30, 2015 at 6:55 PM
    #209
    Fitz19d
    Fitz19d New Member
    2015 5.7 SR5 Tundra
    I have tips? Dunno which part would be nice. Think the flash is only warranty work. The toyo care I am probably fine farming out to the cheap guys if that's better and they at all more reliable than some places. (I'm right next to Stapp? Toyota on i25 and refuse to go there.) Then that extra lube spot if you know what I'm talking about which would be outside of normal listed warranty/toyo care I'd think and could bill me for that.
  30. Dec 30, 2015 at 9:06 PM
    #210
    This is his favorite;)
