Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Dec 18, 2020 at 8:23 PM
    #1981
    FundraTRD
    FundraTRD New Member
    Seattle
    Snow White
    Trd big brake kit, it’s only on the front 2 wheels. Guess I’m better off wheel shopping I think another post on here lists a few options. For now I’m just gonna ride it out.
    really appreciate the input and help
  2. Dec 18, 2020 at 8:31 PM
    #1982
    18" TRD Off Road Wheels
    I don't know that wheel shopping will really help you if you are already on 20s. Unless you plan to go up in size, and wheels + tires isn't going to be a lot less expensive than just reverting your front brakes back to stock.
  3. Dec 18, 2020 at 8:40 PM
    #1983
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If it's only the front and your trying to keep cost down go to the wreckers for some used calipers and ask for the brake hoses. Throw on some new pads and rotors pads and do the work yourself and it would only be around $400 to $500. The problem with buying new calipers from a parts store is that they will want the core back (old calipers). They expect the same calipers back not the BBK calipers so you will get charged the caliper core. For some reason Tundra caliper cores are worth a lot.
    On the plus side you could sell the bbk kit and get back most of your cash.
    FundraTRD[QUOTED] likes this.
  4. Dec 18, 2020 at 10:23 PM
    #1984
    FundraTRD
    Seattle
    Snow White
    From my research any stock Tundra 20s will do. Per stoptech who manufactures these big brakes for Toyota. I might look into some platinum 20s or some older trd 20s but am in no huge hurry since technically it does fit. Tomorrow I’m gonna take that exact ramp again and try to replicate the noise I heard to see if it was metal on metal or rubber. Other than that I haven’t had any issues. Talked to my buddy and these brakes/rims have been on the truck 50,000+ miles he said
    GODZILLA[QUOTED] likes this.
  5. Dec 18, 2020 at 10:24 PM
    #1985
    FundraTRD
    Seattle
    Snow White
    Good to know. Thanks again
  6. Dec 18, 2020 at 10:30 PM
    #1986
    You should be able to get some 20" takeoffs pretty easily. Lots of people downsize the wheels to get more sidewall for a plusher ride or off road activities.
  7. Dec 18, 2020 at 10:34 PM
    #1987
    FundraTRD
    Seattle
    Snow White
    You are awesome man, I really appreciate your responsiveness and feedback. I am lucky to have found this forum.
    now for something positive. Man my truck drives so nice after the transmission fluid change and requesting 0w-20 oil for the oil change. (Will do on my own going forward, no where to change oil at my current living) but man so smooth in every way and also the engine quieted down a lot. I forgot to ask the buddy what oil he was using. I’ve never owned one and I’ll never go back to driving a regular car unless I have to haha
    thank you as well mr ruggy
  8. Dec 18, 2020 at 10:57 PM
    #1988
    FundraTRD
    Seattle
    Snow White
    I think I just got lucky. Stock Tundra 20” with tires on Craigslist for $360 all 4. All good condition and tires good. I’ll pick this up and if it offers more clearance I’ll use these and sell the existing rims and should be able to recoup cost
  9. Dec 19, 2020 at 4:17 AM
    #1989
    Enzo57
    Enzo57 New Member
    2021 black tundra SR5
    None
    Sometimes aftermarket brake calipers have rough edges and scrape against the rim, providing it's very light. See where is scraping on your caliper and smooth it out with a floppy disk installed on your grinder.T hen use a marker/crayon and mark the calipers edges and go for a test, remove wheel if crayon /marker is all there you good to go if marker rubbed of remove a little bit more in that spot and you saved your money.
  10. Dec 19, 2020 at 5:20 AM
    #1990
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do not follow this advice given. Do not modify calipers by grinding away material even if it's only a slight amount. If there is a failure all liability would fall upon you.
  11. Dec 19, 2020 at 5:26 AM
    #1991
    Enzo57
    Enzo57 New Member
    None
    Caliper is not being modified we talkin about cleaning up rough edges it has been done for many many years and when you're done if it's done nice and clean you will never notice a difference
  12. Dec 19, 2020 at 5:32 AM
    #1992
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your that close in clearance cleaning up the calipers isn't going to give you the clearance needed.
    In the unlikely event that the caliper did fail all liability would still fall on you.
    It's really quite simple. Don't modify or change any manufactured part even to the smallest degree.
    FundraTRD likes this.
  13. Dec 19, 2020 at 5:59 AM
    #1993
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Shop just called and said there were no codes and they drove it for 13 miles without issue or codes re-appearing.
    Even though the last thing i did was take pic of the error code AFTER I cleared it, drove and the code came back.
    So we are going agtet the car and hopefully it "fixed itself".
  14. Dec 19, 2020 at 7:24 AM
    #1994
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe they fixed it instead of admitting a mistake? :notsure:
    FundraTRD and Wynnded like this.
  15. Dec 19, 2020 at 7:31 AM
    #1995
    purplenova
    Tom
    Ohio
    :monocle:
  16. Dec 19, 2020 at 8:34 AM
    #1996
    purplenova
    Tom
    Ohio
    Dumb question here: if code was present when i dropped off the car, would it remain after car sits overnight? Codes dont automatically clear by themselves do they?
  17. Dec 19, 2020 at 8:48 AM
    #1997
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that there are some situations where the ECU will see something minor that is Pending and will only set a code (turn on the CEL) if it sees it a certain number of times within a certain period of time. I think that it's the same for the inverse; if the ECU sees some fault and sets the CEL, but then the issue doesn't continue or self-corrects (like the gas cap wasn't tight enough) the CEL will turn off (but the code could still be in memory). I could see this happening with the TPMS where the ECU looks at the values at whatever interval it's programmed to. At start up when cold, and then for drastic changes when driving, in the case of sudden air loss.
  18. Dec 19, 2020 at 9:51 AM
    #1998
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    Toss the Jounce bumper and plate when installing air bags ? - ok I overthink things and trying not to overthink this. I'm installing air bags and instructions say to cut the rubber off the jounce bumper plate that is captured above the leaf springs by the u bolts so the air bag bracket can no sit there. Of course the airbags become the "jounce". I happen to be replacing the u-bolts whilst installing traction bars and as such doesn't it make sense just to toss the jounce bumpers and plates completely? In other words the jounce plate has no other purpose other than holding the rubber jounce on...or is there any benefit to cutting off the rubber jounce and keeping the plate there as it has some role in aligning the ubolts? THANKS! Pic attached.20201219_113627.jpg
  19. Dec 19, 2020 at 9:53 AM
    #1999
    purplenova
    Tom
    Ohio
    At shop, let car warm up, tpms comes on.
    Upon further review, we find the tpms reset button under steering wheel doesn't reset anything.
    Any thoughts on that and how it relates?
    They kept car and found that intermittently lowering tire pressure would be read by the tpms ecu? And another reading would not be picked up. All seems to follow series of 3 light flashes on dash during startup or the normal light on during startup then go off.
  20. Dec 19, 2020 at 5:13 PM
    #2000
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Pull out your techstream and have a look at the data to see what sensor respond to the tire being deflated. Copy the ID number in techstream that doesn't respond. At the dealership they have a tpms code reader which works very well. Basically they place the code reader next to the valve stem on each wheel and it reads and stores the ID number and gives the battery health. When they have read all four wheels they plug it into the diagnostic connector and it upload the info to the tpms module. That is what the should have done.
    Here some information on the reset button.
    If the Tire Pressure Monitor System senses seriously low pressure in one of your tires, the low tire pressure icon will appear in the instrument display and you'll see a warning message in the Multi-Information Display.
    If the indicator light stays on, check all the tires and refill, repair or replace any that are below the proper pressure.
    Rotating tires, changing tire pressures, or switching tire sizes could trigger the warning.
    To reset the system, first make sure the tire pressures are correct.
    Turn the engine on, then press and hold the reset button. You'll find it low and to the right of the steering wheel on the instrument panel.
    Hold the button down until the TPMS indicator light in the instrument panel blinks slowly 3 three times.
    Wait for several minutes with the engine running, to allow the system to record each tire's pressure, then turn the engine off.
    If the light comes on and blinks when you start the car, something may not be working properly, and you should take it to a Toyota dealership to be inspected.
    NewImprovedRon likes this.
  21. Dec 19, 2020 at 5:16 PM
    #2001
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not sure why they would want the bumper plate in there. The ones I have done you simply remove the bumper and the airbag sits on the spring directly.
    Give the airbag manufacture a call to clarify.
  22. Dec 19, 2020 at 5:30 PM
    #2002
    purplenova
    Tom
    Ohio
    The tech was able to see the same error code on his end, so that's a plus, I guess. The hokey part was when he was deflating and inflating the tires, the system randomly acknowledged the change or didn't acknowledge the change.
    They were not able to pin point what needed repaired or replaced. I don't want to start throwing parts at it either. The tech did think the sensor was ok.
    Looks like im heading up to my local dealership next week.
  23. Dec 19, 2020 at 6:55 PM
    #2003
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry my mistake, I thought you were at the dealer. They will have the tool to read the sensors and it shows the tech the signal strength and battery life with ID numbers. It will show any issues with the sensors.
    I would try the deflate and inflate method with your techstream just to see for yourself.
    If you do go to the dealer have them recorded the sensor IDs and ask for them. Write them down in the back of the owners manual.
    NewImprovedRon and WBW like this.
  24. Dec 19, 2020 at 8:11 PM
    #2004
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Now that is a great idea right there! I shall be doing that on my next visit to the dealer.
    Thank you @Ruggybuggy for all you do here!
  25. Dec 20, 2020 at 6:18 AM
    #2005
    rothmigo
    rothmigo New Member
    DFW TX
    Thanks! Well I ended up cutting off the rubber jounce and leaving the top plate in place. I was going to toss the top plate but it seemed like it gave a bit more meat for the u-bolts and spread the pressure of the bolts more evenly onto the leaf spring. I think I could've probably got rid of the whole thing but then I wouldn't have gotten to use my sawzall and enjoy the smell of burning rubber in the garage lol.
    Leo's first likes this.
  26. Dec 20, 2020 at 6:37 AM
    #2006
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Good that it worked for you. Don't forget to retorque your U bolts after a couple hundred miles (and wheels). Check and make sure the plate hasn't moved.
  27. Dec 20, 2020 at 6:49 AM
    #2007
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wow!
    Your warranty should still apply because your issues with the truck started while you were under warranty.
    Does you truck have a LSD rear diff?
  28. Dec 20, 2020 at 2:52 PM
    #2008
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That little amount is just some sweating. I wouldn't "sweat" it. Sorry I couldn't help myself.
    Changing the struts won't make any difference in the dragging feel.
    To be honest with you it seems you have a number of symptoms that don't really all seem to be connected. It's going to be very hard to do this repair on a forum. Be careful about randomly replacing parts. In the trade we call it "poke and hope". It can lead to alot of wasted money and time.
  29. Dec 20, 2020 at 5:41 PM
    #2009
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Is the OEM drivers side front coil spring longer than the passenger side?
  30. Dec 20, 2020 at 6:09 PM
    #2010
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm not sure if it's longer but the spring rates are different. There is a left and right side. Compensates for the fuel tank and driver's weight.
