Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Dec 7, 2020 at 1:07 PM
    #1891
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota fuel pumps are very reliable. Most issue that come up with the fuel pumps not working is a wiring issue between the pump module and pump. If seen a few pumps replaced needlessly. As far as the amount of fuel in the tank cooling the pump I think many are over thinking it. My feeling is that the Tundra just has a larger reserve than most.
  2. Dec 9, 2020 at 12:59 PM
    #1892
    13tundradude
    13tundradude New Member
    LOS ANGELES
    2012 TUNDRA
    2013 4.6 ENGINE AND TRANS. COUPLED WITH A 5.7 REAR END LSD
    I am going to clear erase and rescan and post again soon.
    This scan was ran without the radiator, no power steering fluid and no brake fluid.
    Probably a dumb question but will a working computer disable the car from running as a safety feature?
    Report
    12/07/2020 01:55 PM
    General Information
    VIN: 5TFRM5F15DX064122
    Vehicle: 2013 TOYOTA TUNDRA
    Engine: V8, 4.6L; DOHC; 32V
    Mileage Reported: 45,000
    Report#: 101
    Date of Report: 12/07/2020 01:55 PM
    Engine/Transmission Diagnostic Trouble Code Information
    MIL DTC
    P0118
    Engine Coolant Temperature Circuit High Input
    Severity Level: Moderate ico_info_974e2b0114ea8e17f6fb6951c1e82420ec4824a8.png
    Quick Code Summary:
    Code P0118 indicates that the Engine Coolant Temperature electrical circuit input signal had high voltage for a predetermined period of time.
    This condition will prevent the vehicle from running at its optimum efficiency and fuel economy may suffer.
    The engine coolant temperature input helps cold start and running and will inhibit operation when overheated.
    Technical Service Bulletins:
    There are currently no TSBs for P0118.
    Stored Codes
    P0013
    "Camshaft Position ""B"" Actuator Circuit /Open (Bank1)"
    P0023 "Camshaft Position ""B"" Actuator Circuit /Open (Bank 2)"
    P0102 Mass Air Flow Circuit Low
    P0113 Intake Air Temperature Sensor System Open/High
    P0118 Engine Coolant Temperature Circuit High Input
    P0121 Throttle Position Sensor Range Malfunction
    P0123 "Throttle/Pedal Position Sensor/Switch ""A"" Circuit High Input"
    P1613 Secondary Air Injection System Driver
    Pending Codes
    P0013
    P0419 "Secondary Air Injection System Relay ""B"" Circuit"
    P0705 Transmission Range Sensor Circuit
    Freeze Frame Information
    Parameter Description
    Results
    DTC for which Freeze Frame was Stored
    P0118
    Fuel System 1 Status
    Open Loop
    Fuel System 2 Status
    Open Loop
    Calculated LOAD Value
    0.00 %
    Engine Coolant Temp
    -40.00 °F
    Short Term Fuel Trim - Bank 1
    0.00 %
    Long Term Fuel Trim - Bank 1
    0.00 %
    Short Term Fuel Trim - Bank 2
    0.00 %
    Long Term Fuel Trim - Bank 2
    0.00 %
    Intake Manifold Absolute Pressure
    29.61 inHg
    Engine RPM
    0.00 rpm
    Vehicle Speed Sensor
    0.00 mph
    Ignition Timing Advance #1 Cylinder
    5.00 °
    -40.00 °F
    Air Flow Rate Mass Air Flow Sensor
    0.25 lb/min
    Absolute Throttle Position
    100.00 %
    Commanded Secondary Air Status
    Atmosphere / Off
    Oxygen Sensor Output Voltage (B1-S2)
    0.00 V
    Short Term Fuel Trim (B1-S2)
    99.22 %
    Oxygen Sensor Output Voltage (B2-S2)
    0.00 V
    Short Term Fuel Trim (B2-S2)
    99.22 %
    Time Since Engine Start
    0 sec
    Monitor Status
    Monitor Name
    Monitor Icon
    Status
    MIL (Check Engine Light)
    ON
    Misfire Monitoring
    Complete
    Fuel System Monitoring
    Complete
    Comprehensive Component Monitoring
    Complete
    Catalyst Monitoring
    Not complete
    Heated Catalyst Monitoring
    Not Supported
    Evaporative System Monitoring
    Not complete
    NMHC Monitoring
    Not Supported
    NOxAdsorber Monitoring
    Not Supported
    Secondary Air System Monitoring
    Not complete
    Oxygen Sensor Monitoring
    Not complete
    Oxygen Sensor Heater Monitoring
    Not complete
    EGR System Monitoring
    Not complete
    Boost Pressure System Monitoring
    Not Supported
    Exhaust Gas Sensor Monitoring
    Not Supported
    PM Filter Monitoring
    Not Supported
    Copyright © 2020 IEC. All Rights Reserved.(V1.0.0.0).
  3. Dec 9, 2020 at 1:12 PM
    #1893
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    Do I need to install the 4.6 gas pedal? I noticed its electronic.
    I have this pedal and from what I remember it was easy to remove.
    The chevy LS swap requires the Pedal to be installed with the engine.
  4. Dec 9, 2020 at 2:07 PM
    #1894
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Modules don't normally shut the engine down unless you have an immobilizer issue.
    The P0123 circuit A sounds like a pedal issue. They have two circuits for safety, one goes high and the other goes low. Switch out the pedals. It's very easy to do, just undo two bolts and it falls out. Be careful not to bang it or drop it. They are sensitive and can be damaged.
    Clear all your codes and just turn the key on but don't try to start. Read the codes that come up.
    13tundradude[QUOTED] likes this.
  5. Dec 9, 2020 at 3:16 PM
    #1895
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    awesome the pedal I removed a few years ago has defintly been handled rough I am hoping it still works, im having a programmer stop by within the next few days.
    Thank you for your help I really appreciate it.
  6. Dec 9, 2020 at 3:38 PM
    #1896
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    NP and good luck.
  7. Dec 9, 2020 at 4:13 PM
    #1897
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    I met a guy today who showed me some pictures of his friends 2019 voodoo blue pro. The engine caught fire! A couple days ago his friend was driving down the road. He said he heard a pop. Next thing he knew there where flames coming out of the wheel well. His insurance company is looking in to it. I won't be able to find out from him what happened. I don't know him. Has anybody ever heard of this before? My guess would be fluid caught fire.
  8. Dec 9, 2020 at 8:24 PM
    #1898
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The only fires I've heard of was some block heaters had a problem. Never heard of a engine issue fire in a Tundra or any Toyota product.
  9. Dec 10, 2020 at 3:52 AM
    #1899
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ooo, I have a block heater. Do you recall what the problem was? Just as a precaution. Thanks.
  10. Dec 10, 2020 at 5:23 AM
    #1900
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you get a letter in the mail? A couple of years ago there was a fire in Calgary where a Toyota parked in an attach garage burnt the house down. I believe it was an install issue but Toyota started looking hard at the block heater. We even had a couple of Toyota guys come to our dealership and ask us about our installs. I remember one of the techs had not routed the cord exactly as per Toyota's instructions. Shortly after Toyota change the design of the heaters. The cords now are very thick and look like a heavy extension cord. The wattage on the heater was reduced and the routing in the engine bay changed.
    If you take a picture of the block heater cord in the engine bay I can tell you if you have the old or new design.
    Wynnded[QUOTED] likes this.
  11. Dec 10, 2020 at 9:51 AM
    #1901
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine was a self-install vs. the dealer. I'll double-check my cord routing and try to get a picture of it. I did this probably 6 years ago, so I don't know where that falls in the timeline. I don't recall off the top of my head, but for some reason I want to say it was 400 watts...or maybe that's the one we put in our diesels...o_O
  12. Dec 10, 2020 at 10:16 AM
    #1902
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    400W sound right. Do you know the part number? The recall should still be in effect regardless if you installed it yourself. I dont think the Tundra ones were a problem but I would call the dealer with the part number to find. They did change the design of the heaters a couple of years ago for a reason.
  13. Dec 10, 2020 at 11:49 AM
    #1903
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I used to have the part number in my notes in case someone else was interested in ordering one. I deleted it some years later after reading that the part number was superseded by another and that others were told by dealers in the U.S. (that's where I am too) that they couldn't get one because the part was Canada only.
    I was able to find my eBay email receipt, with that I was only able to glean the price that I paid ($50) and the selling dealership (Metro Toyota in Ohio). Here's an image of the item as presented currently in some eBay ads. It's the same image as in my email receipt:
    Here's the picture that I took of the power cord of mine. It's a flat three conductor cord.
    Mine differs from the advertised image in that the main run of the cord isn't covered in corrugated loom, but rather a smooth sheath more akin to larger diameter and heavier heat shrink tubing. It's routed behind the headlamp to the firewall, behind the brake booster then down. I may alter that slightly as the route down has it between the heat shield that's just below the hard A/C lines that go through the firewall and the driver side bank of engine cylinders. I'll probably tuck it behind the heat shield.
  14. Dec 10, 2020 at 1:27 PM
    #1904
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Just out of curiosity when would I need to replace the timing chain on a 2014 5.7L V8 Tundra?
  15. Dec 10, 2020 at 2:18 PM
    #1905
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There isn't a maintenance interval for the timing chain.
    vanthesupreme[QUOTED] likes this.
  16. Dec 10, 2020 at 3:37 PM
    #1906
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The heater in the picture is the old style that was used only on cars and SUV's. Both the old and new Tundra heaters had a door flap on the outside. Toyota give you an extension that fits into the door. The heater you have definitely looks like the old style heater and probably is under the recall. The new style heaters use a conduit covering but the wiring is also a lot heavier and uses a separate ground to the body of the vehicle.
  17. Dec 10, 2020 at 3:39 PM
    #1907
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What was already said. If your not having issues as in noise your fine. Maybe your thinking of a timing belt that was used on the 4.7 Tundra motor.
  18. Dec 10, 2020 at 3:49 PM
    #1908
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    New guy here looking to beat a dead horse: what in your opinion is the limiting factor (component) or most critical combination of factors (components) that are to blame for the Tundra's payload capacity, or lack there of.
    Disclaimer: for research purposes only, info not to be used to justify breaking the low and towing/carrying over weight limits.
  19. Dec 10, 2020 at 4:09 PM
    #1909
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Huh, maybe I'll reach out to some of the dealers in the more northerly climes to see if I can get a P/N. Maybe I'll get lucky and find a picture of one as well. Thanks for the information!
    Ruggybuggy[QUOTED] likes this.
  20. Dec 10, 2020 at 9:06 PM
    #1910
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The rear suspension. The leaf spring are very weak for a full size truck. Brakes on the truck are very good with 4 piston caliper and big rotors. None of the domestics 1/2 tons are using 4 caliper pistons. I run a set of Sumospring in the rear and this summer had 2K of flooring in the truck and it rode level and load was hardly noticeable.
    Also if you plan on towing over 6K with your 2021 on a regular basis consider a ambient cooler if you trans temps exceed 230F.
  21. Dec 11, 2020 at 5:24 AM
    #1911
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Can you tell us more about the Sumosprings? How do they affect the ride when not loaded?
  22. Dec 11, 2020 at 5:36 AM
    #1912
    Carlos22
    Carlos22 New Member
    Blacked out 4x4
    Hello toyota mechanic
    I have a problem I'm having problems fueling up
    The gas tank is not allowing the gas to go down the hose,every 2,3 sec the pump stop like if it was full
    Can u please help
  23. Dec 11, 2020 at 6:33 AM
    #1913
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Not a mechanic, but I have also installed Sumosprings on my Tundra. I bought the black ( 1500lb ) springs and have been very happy with them. With my 4500lb boat hitched to the back, my wife and I in the truck and the back seat area and truck box full of vacation stuff, only 1.5 inch of squat. Add to that the ride quality was great, firm but not harsh.
    For me I didn't feel the empty truck ride quality suffered much at all, on bigger bumps and dips maybe somewhat. Went hunting with a friend in October 500+ mile trip and he thought the truck rode fine. YMMV as they say, but I love the fact that once installed they are completely self sufficient, with no compressor, or plumbing to fail or require maintenance.
    Super Springs International ( manufacturer of Sumosprings ) has end of year sale that I think is still on.
    Ruggybuggy likes this.
  24. Dec 11, 2020 at 6:42 AM
    #1914
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I have the black ones which are in the middle for stiffness. I pull a trailer that has a 550lbs of tongue, the reason why I use them. The black Sumospring effected the ride very little and really can't tell much of a difference. I was going to do air bags but like the idea of install and forget. Some have reported a harsher ride using the yellow Sumospring which are the HD spring.
  25. Dec 11, 2020 at 7:00 AM
    #1915
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Probably the failed check valve in the tank.
    Have a read.
  26. Dec 13, 2020 at 10:20 AM
    #1916
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Can a cracked or improperly working ignition coil cause a P0171 lean code by chance? I've been fighting this code and have changed my fuel filter, cleaned MAF, checked vacuum lines and jumped my fuel pump resistor to no avail. Starting to run out of options that I can think of.
  27. Dec 13, 2020 at 11:34 AM
    #1917
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Unlikely. You should get a misfire code for the coil.
    How does it idle? You took the tank down fo change the fuel filter? What method did you use to clean the MAF sensor? How many miles on the truck.
    Common causes for P0171 are
    • Dirty or faulty mass air flow sensor
    • Vacuum leaks – PCV hose, vacuum hoses, intake manifold gasket.
    • Weak fuel pump
    • Clogged or dirty fuel injectors
    • Exhaust leak
    Filthyphil[QUOTED] likes this.
  28. Dec 13, 2020 at 12:23 PM
    #1918
    Filthyphil
    Phil
    So for the past 6 months or so every time I go up a steep incline and im 50% in the throttle I get surging but only on steep hills. I have a 2000 4.7 with 168,000 miles and the filter is on the frame rail so it was a easy change. Also since this light has been coming on I have a rough idle, nothing drastic but you can feel the truck kind of shaking a bit however when driving it feels perfectly fine and at idle is when I seem to get the pending code on my scan gauge.
    • I cleaned the MAF with MAF cleaner and ohm'd it out and it was within spec
    • Replaced bank 1 sensor 1 O2.
    • I don't hear any leaks I went through lines and cut off cracked ends of hoses. " Did get a starter last year so new intake gasket " and I sprayed around with brake cleaner listening for idle changes.
    • I ohm'd out my fuel pump resistor and it was .9 ohms spec is .7 though .76.
    • Placed a jumper on the fuel pump resistor and surging is totally gone but I still get the code.
    • Fuel injectors are original.
    • Slight exhaust leak on manifold when cold and a couple pin holes in muffler and resonator.
    • I checked all coils this morning and 3 have cracks down the bodies.
  29. Dec 13, 2020 at 12:25 PM
    #1919
    Filthyphil
    Phil
    I have noticed some oil residue around the PCV, I have taken it out and can blow through it and the float moves on its own however if you think the gasket and PCV could be the issue I would give it a try also.
  30. Dec 13, 2020 at 2:27 PM
    #1920
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The cracks in the boots could cause issues especially in humid weather. Change the boots out on all banks. The 4.7 was known to have a problem with cracking the exhaust manifold. This can cause bad O2 reading and effect drivability. I have successfully welded them up. Did you check the plugs? Take them out and read them and see which cylinders are running lean. Replace the plugs when you have them out.
    If the PCV is moving when you shake it it's probably fine. You can spray some brake clean though it to clean it out. A little oil residue is fine as long as there are no leaks.
    Filthyphil likes this.
