Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 14, 2020 at 11:12 AM
    #1711
    18" TRD Off Road Wheels
    Told you, as soon as the girl scouts offer them you get a whole box!
  2. Aug 14, 2020 at 11:13 AM
    #1712
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I will second that motion as a thanks for the assistance.
    Ruggybuggy likes this.
  3. Aug 14, 2020 at 11:14 AM
    #1713
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I send you ome and @AzureNightmare can send the other.
    Ruggybuggy[QUOTED] and GODZILLA like this.
  4. Aug 14, 2020 at 11:29 AM
    #1714
    SeminoleATL
    SeminoleATL New Member
    2014 Limited CM Blue
    Stock... for now
    Trying to resync the actuator motor on a 2014 BW Transfer case motor. Can not find anywhere to show what position the gear needs to be in for 2hi, 4hi, and 4lo so I can sync it back with the switch. 2hi and 4hi seem to work, but it seems it’s not making it all the way to 4lo, which makes me think that I have it off by just a little. Is there schematics somewhere that can help?
  5. Aug 14, 2020 at 3:29 PM
    #1715
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  6. Aug 14, 2020 at 5:36 PM
    #1716
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    This is the only info provided on TIS.
    Wynnded likes this.
  7. Aug 14, 2020 at 6:09 PM
    #1717
    SeminoleATL
    Stock... for now
    Thanks! Will give it a shot and see if I can make something of this in the morning.
    Ruggybuggy[QUOTED] likes this.
  8. Aug 15, 2020 at 9:21 AM
    #1718
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    2016 5.7 flex
    Only does this periodically on cold start after idling for a couple of minutes.
    Thought it was a tensioner or pully but have changed those and belt.
    It’s loudest on the drivers side.
    https://youtu.be/frHsOj0uRDM
    After belt and tensioner change.
    Still making the same noise for 10-30 seconds after cold start up.
    https://youtu.be/ppXN1qzG0-w
  9. Aug 15, 2020 at 1:12 PM
    #1719
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Tundra 5.7 is a fairly loud motor. The noise you are hearing sound like a lifter noise. When is the last time you changed the oil and what grade? My suggestion is to change the oil using 5W30 and see if it's better. If it's still there but better add .5L of ATF to the crankcase and run it until the next oil change. ATF has detergents that will help clean out oil passages and lifters. Once the noise is gone you can return to 0W20 for winter.
    Hightide[QUOTED] likes this.
  10. Aug 15, 2020 at 7:10 PM
    #1720
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    He only has 13 posts and 11 of them were a meltdown. I appreciate the backup from everyone. :thumbsup:
    JMB, Ely010606 and NewImprovedRon like this.
  11. Aug 15, 2020 at 8:35 PM
    #1721
    Hightide
    Abalama
    Magic School Bus
    About 2200 miles into an oil change.
    Dealer, Toyota synthetic. I believe 0w20 or 30 but not sure.
    I did notice that it stopped after the last oil change and only started back recently.
    Not much of a winter for me in Alabama.
    Any links on recommend ATF?
  12. Aug 15, 2020 at 8:46 PM
    #1722
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Dealer would have used OW20. You can use any Dexron III but only .5L/quart or use a dedicated lifter/engine cleaner like Marvel M13R Mystery oil which works well.
  13. Aug 15, 2020 at 9:20 PM
    #1723
    Hightide
    Abalama
    Magic School Bus
    I’ll give that a try.
    Thanks!
  14. Aug 16, 2020 at 12:33 PM
    #1724
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I'm asking this question in a few spots. I've also posted a thread here with more info: https://www.tundras.com/threads/201...hvac-control-lights-stereo-not-dimming.72831/
    2014 SR5 crewmax. I've blown an interior fuse labeled "panel". I replaced the fuse and it blew again immediately. I noticed the blown fuse after troubleshooting my radio not dimming and my HVAC control lights not coming on with the headlights. I'm assuming the blown fuse is related, but how do I diagnose what is causing the fuse to blow? Stock electronics other than aftermarket trailer brake controller.
    I've only had the truck for a month. So I can't say when this problem started.
  15. Aug 16, 2020 at 8:27 PM
    #1725
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've seen this before with a bad 7 way trailer connector at the rear bumper. Open the door and look for damage or corrosion. You can also disconnect it from the harness to eliminate it from the circuit. I've included a wiring diagram of the circuit and a description of the fuse panel circuits. This information is for the floor shifted trucks. There is a different wiring diagram for the column shifted trucks.
    NewImprovedRon and Wynnded like this.
  16. Aug 18, 2020 at 2:59 AM
    #1726
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I need a quick info about replacing the rear sway bar on a 2nd gen Sequoia. Do I have to remove the propeller shaft to do the swap?
    Thanks!
  17. Aug 22, 2020 at 4:37 PM
    #1727
    swallace
    Steven
    Tri-Cities, WA
    @Ruggybuggy thank you for the quick reply. I disconnected the 7-way trailer connector from the harness to eliminate it from the circuit. Fuse still blew. Based on the fact that the "panel" fuse circuit diagram that you sent includes trailer towing, it seems to me that the next step would be for me to take apart the aftermarket trailer break wiring. Do you agree? Any other thoughts on how to proceed?
  18. Aug 22, 2020 at 4:48 PM
    #1728
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would definitely be looking at the aftermarket brake controller. Should be easy to unplug if they wired it in correctly.
  19. Aug 22, 2020 at 10:46 PM
    #1729
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    So recently Ive noticed alot of shaking through the steering wheel while breaking coming down winding hill. Assumed it my rotors that is warped. Truck has about 44k miles. Looking to replace the rotors and pads with oem. Should I replace the rears as well?
    Ely010606 likes this.
  20. Aug 22, 2020 at 10:58 PM
    #1730
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    How are your tires?
  21. Aug 22, 2020 at 11:01 PM
    #1731
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    They seem to have decent tread left. Ill have to double check to see if there’s any uneven wear in the am.
  22. Aug 22, 2020 at 11:13 PM
    #1732
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I just installed a c4 front bumper on 2015 and in the process disconnected the front two PDC sensors and after reinstalling them the sensors the truck is now giving me an error. Does the PDC system have to be reset and can this only be done at the dealer?
  23. Aug 23, 2020 at 5:42 AM
    #1733
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you feel a pulsing in the brake pedal as you apply the brakes?
  24. Aug 23, 2020 at 5:53 AM
    #1734
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is no reset for the proximity sensors. I have no experience with the C4 bumper that you installed. Check and make sure you plugged them in correctly. The sensors can be a pain because they don't show up on the data stream in Techstream. When I encountered this problem I had a known good sensor that I would swap out. I doubt you have a sensor issue because they worked before. Make sure the connector's terminals are OK and that you didnt accidentally pull the wires partially out of the connector.
    I've included the repair info from Toyota. Good luck.
  25. Aug 23, 2020 at 8:25 AM
    #1735
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    My friend truck was doing the same thing, I helped him do the front brakes And change the rotors , and when we checked the rear brakes the pads were still more than 50%, so he decided not to change it. Just doing the front rotor and brake the shaking/pulsing from the steering wheel stopped when braking.
  26. Aug 23, 2020 at 9:01 AM
    #1736
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    not really just the steering wheel
  27. Aug 23, 2020 at 9:14 AM
    #1737
    TemujinNomad
    TemujinNomad New Member
    Hello all,
    this question is regarding transmission fluid check level. My driveway is at an slight incline but using a jack I have it so it shows level on the belly of the transmission pan. Should I be good? Thanks in advance.
  28. Aug 23, 2020 at 9:30 AM
    #1738
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your not feeling a pulsing in the brake pedal at all then it's a tire or rim issue, possible loose lug nuts. Normally and tire and wheel problem would be noticed all the time, just not braking.
    NewImprovedRon likes this.
  29. Aug 23, 2020 at 9:35 AM
    #1739
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Use the level on the frame and not the trans pan. The transmission sits at a slightly downward slope. The instructions from Toyota is a level truck.
    GODZILLA and NewImprovedRon like this.
  30. Aug 23, 2020 at 10:05 AM
    #1740
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Yeah not noticing all the time. Was just with alot of downhill braking. Its due for a rotation and prob do balance too.
