Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 13, 2020 at 7:31 AM
    #1681
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your brake fluid will go to a lower level as your brakes wear. If your adding fluid to turn the light off it's time fo do a brake check and see how much brake pad material you have left. I would do this soon because when the light comes on there usually not much brake friction material left. :monocle:
  2. Aug 13, 2020 at 7:33 AM
    #1682
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Good morning , new to this question and answer stuff, but just noticed when I back my boat in to launch and still in drive the truck 2013 tundra dc sr5, wants to roll back . Is this normal ? Now I have even noticed it on hills , in drive wants to roll back.
  3. Aug 13, 2020 at 7:36 AM
    #1683
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Normal, depends on many things like the load in the truck, the incline and even your idle speed.
  4. Aug 13, 2020 at 7:48 AM
    #1684
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Thanks alot , hoping to hear that.
    Ruggybuggy likes this.
  5. Aug 13, 2020 at 10:01 AM
    #1685
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    At only 42000 miles ??
  6. Aug 13, 2020 at 10:14 AM
    #1686
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sure, why not? Stop and go driving, towing, hilly terrain and even bad driving habits. The only other less likely explanation is a leak or someone has removed some brake fluid.
    GODZILLA likes this.
  7. Aug 13, 2020 at 10:20 AM
    #1687
    purplenova
    Tom
    Ohio
    Guess I will have to give it a closer look.
  8. Aug 13, 2020 at 8:17 PM
    #1688
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    Hey I have a question, I just had an alignment done and truck drives straight but steering wheel clocks to the left a little and really starting to bother me can you tell me if my alignment numbers are ok ive done the coachbuilder trd pro kit and JBA UCA 275 70 18 bfg ko2 . thx.
  9. Aug 13, 2020 at 9:00 PM
    #1689
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My specialty. Done thousands of alignment on Toyotas and others. Numbers are good. I take it that the truck goes down the road straight but the wheel is a little off center all of the time? The last thing done with the alignment is to set the toe and centre the wheel. The tech wasn't careful and didn't center the wheel correctly. Just to note that the wheel can be off on certain roads with different crowns but if the wheel is off most of the time on most roads take it back and have them correct it. Make sure you get a print out for the second alignment. Some techs will cheat and adjust the wheel without putting it on the alignment rack. Asking for the print out forces them to do another alignment.
    Wynnded and NewImprovedRon like this.
  10. Aug 13, 2020 at 9:06 PM
    #1690
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    yes exactly in your first question. thank you for the quick response very much appreciated i will go back and ask them to correct it and get another print out.
  11. Aug 14, 2020 at 8:08 AM
    #1691
    Jota21
    Jota21 New Member
    Hi - i made a thread about this, but didn't get any responses. Thought maybe this would be a better spot for it:
    So my airbag light has been on intermittently for months. When i say intermittently, i mean it'll come one (and stay on until you turn the truck off) maybe 1 out of 100 start-ups. I had my truck to my local guy for inspection today and asked if he had a computer that could scan that code even though the light was currently off. He came back with D1630, but long story, wasn't interested in diagnosing further or attempting to fix. He suggested contacting Toyota to see if this might be a recall/warranty. I'll call tomorrow, but i doubt it. it's a 2015 that i bought from a dealer out of the area a year ago without any additional warranty. I searched for open recalls but didn't find any.
    I feel like it must be a loose connection since it's so infrequent, and my gut is pointing me to the wiring under the manual drivers seat since my wife and i do change the seat position regularly, but as far as i can tell/see, everything looks proper.
    Thanks in advance
  12. Aug 14, 2020 at 8:18 AM
    #1692
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    D1630 is not a known code for Toyota. If you have the light coming on you have a code. That where to start. You maybe surprised and Toyota may pay for the repair because its safety related. Go in and have them checked for codes.
  13. Aug 14, 2020 at 8:38 AM
    #1693
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just checked further but I think you mean code B1630. There is a very long procedure for solving the problem so I think it's best you bring it in.
    Here are a few screen shots.
    NewImprovedRon likes this.
  14. Aug 14, 2020 at 8:40 AM
    #1694
    Jota21
    Jota21 New Member
    that must be it! Thanks so much...
  15. Aug 14, 2020 at 8:50 AM
    #1695
    Jota21
    Jota21 New Member
    any idea how much i'd be on for for that repair???:mad:
  16. Aug 14, 2020 at 8:55 AM
    #1696
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not a clue. It's all diag time so the quicker they find it the less you pay.
  17. Aug 14, 2020 at 9:06 AM
    #1697
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Car has 130k, and is a weekend car so it mainly sits.
    1UZ has bouncing idle, sort of a mystery, it doesn't do it all the time, I can start it and it will idle fine for about 30 seconds to a minute and then it will start bouncing between 2k to 1k rpm. There are times where I will start it and no bouncing will occur. Recently replaced battery for a 2nd time. Car idles fine in gear, R, D, 2, L. But will resume bouncing idle in N and P. I can drive it fine with no issues, and I can pull over and drop in on N or P and it will not bounce, but this is also intermittent. More often than not it will idle fine after its warmed. Its been dealer maintained its whole life cycle until about January swapped out a dead battery and I took it home, killed another battery 2 months ago, besides an oil change and batteries nothing else has been done.
  18. Aug 14, 2020 at 9:55 AM
    #1698
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What year and model? Are there any light on in the dash?
  19. Aug 14, 2020 at 9:59 AM
    #1699
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I like doing these but where the hell is @LOTSOFTOYS :monocle:
    Free advice and no pay, maybe make me a staff member, a moderator, hell I would even take a cookie. :hungry:
  20. Aug 14, 2020 at 10:04 AM
    #1700
    blackdemon_tt
    lol, 93 lexus sc400 no lights
  21. Aug 14, 2020 at 10:12 AM
    #1701
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The battery is likely a draw on the system. You will have to read the amp draw from the negative battery post to the negative connection by installing an amp meter in series. Do a google search on how to test. Also a discharged poor battery can effect idle speed. If you know the battery is good, clean the throttle body out with throttle body cleaner and a tooth brush and make sure you spray into the IAC (idle air control) port. You can YouTube or google how to do this. I'm assuming all other maintainence related items such as spark plugs and air filter have been addressed.
  22. Aug 14, 2020 at 10:16 AM
    #1702
    blackdemon_tt
    Have not address air filter and sparks, since its been stored away for over a year and they were done around the same time, but I will address those as well, I will do the draw test, and Ill clean the car's iac and throttle body. thanks for the advise.
  23. Aug 14, 2020 at 10:18 AM
    #1703
    18" TRD Off Road Wheels
    Pretty sure this is all yours now, @Ruggybuggy :rofl:
    JMB likes this.
  24. Aug 14, 2020 at 10:24 AM
    #1704
    blair_b1
    blair_b1 New Member
    Blair
    2014 Grey Tundra 4.6
    I don't like that air injection system. Whats up with it? On my 2014 4.6.
  25. Aug 14, 2020 at 10:28 AM
    #1705
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Then I want a cookie. :mad:
  26. Aug 14, 2020 at 10:29 AM
    #1706
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why dont you like it?
  27. Aug 14, 2020 at 10:54 AM
    #1707
    You were unclear, and he simply stated he would't discuss removal. You could have easily responded with something like "You've misunderstood me. I'm not looking to delete it, but I am wondering if it is operating properly or if I can do anything to address X,Y,or Z concerns."
    Not hard to be civil.
  28. Aug 14, 2020 at 10:57 AM
    #1708
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Looks to me is he’s here to help. Take the help or move on :notsure:
  29. Aug 14, 2020 at 10:59 AM
    #1709
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    thks
  30. Aug 14, 2020 at 11:11 AM
    #1710
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    ....but now i want two cookies. :hungry:
